Her kan shaman diskuteres..
Hello alle sammen.. har rolla en shaman.. vart litt lei av hunteren min.. så jeg trenger litt info here.. for build, weapon, armor, og ikke mist hvilken stats i burde focusere mest på.. str, sta, agi eller int..
har prøvd* å sotten sammen en build:
Elemental Combat Talents (22 points)
Concussion - 5/5 points
Increases the damage done by your Shock spells by 5%.
Convection - 5/5 points
Reduces the Mana cost of your Shock spells by 10%.
Reverberation - 5/5 points
Reduces the cooldown of your Shock spells by 1 second.
Elemental Focus - 1/1 point
Gives you a 10% chance to enter a Clearcasting state after casting any Fire, Frost, or Nature damage spell. The Clearcasting state reduces the mana cost of your next damage spell by 100%.
Call of Thunder - 5/5 points
Increases the critical strike chance of your Lightning spells by 6%.
Elemental Fury - 1/1 point
Increases the critical strike damage done by your Fire, Frost, and Nature spells by 100%.
Enhancement Talents (22 points)
Ancestral Knowledge - 4/5 points
Increases your maximum Mana by 4%.
Shield Specialization - 5/5 points
Increases your chance to block attacks with a shield by 5%.
Thundering Strikes - 5/5 points
Improves your chance to get a critical strike with your weapon attacks by 5%.
Two-Handed Axes and Maces - 1/1 point
Allows you to use Two-Handed Axes and Two-Handed Maces.
Flurry - 5/5 points
Increases your attack speed by 30% for your next 3 swings after dealing a critical strike.
Improved Windfury Weapon - 2/2 points
Increases the Attack Power bonus of your Windfury Weapon effect by ?.
Restoration Talents (7 points)
Improved Healing Wave - 5/5 points
Reduces the casting time of your Healing Wave spell by 0.5 seconds.
Improved Self-Reincarnation - 2/2 points
Reduces the cooldown of your Self-Reincarnation spell by 20 minutes.
her ser dere hva jeg har tenkt på.. sier ikke at det kommer til å bli min build, men som dere ser så velger jeg melee istedenfor whannabe mage.. tror ikke jeg trenger noe mer på elemental enn det jeg har her..
håper vi kan diskutere litt her:)
edit: lage en "bedre" build no:p
Endret av MysticoN
rart, jeg har akkurat laga 2 shaman tråder :p
Men gidder noen å sette opp en melee build?
Og er bedre air totem viktig?
EDIT: her ;)
Endret av chokke
Elemental Combat Talents (14 points)
Reverberation - 4/5 points
Reduces the cooldown of your Shock spells by 0.8 seconds.
Enhancement Talents (37 points)
Ancestral Knowledge - 5/5 points
Increases your maximum Mana by 5%.
Anticipation - 5/5 points
Increases your defense skill by 10.
Flurry - 5/5 points
Improved Rockbiter Weapon - 2/2 points
Increases the Attack Power bonus of your Rockbiter Weapon by 10%.
Parry - 1/1 point
Gives a chance to parry melee attacks.
Toughness - 5/5 points
Increases your armor value from items by 10%.
Stormstrike - 1/1 point
Gives you an extra attack. In addition, the next 2 sources of Nature damage dealt to the target are increased by 20%. Lasts 12 seconds.
Restoration Talents (0 points)
None
ka du synest om denne??
Hva synes dere om denne?
Restoration Mastery
Rank 5/5
Reduces the casting time of your Healing Wave spell by 0.5 sec.
Improved Reincarnation
Rank 2/2
Reduces the cooldown of your Reincarnation spell by 20 min.
Ancestral Healing
Rank 5/5
Increases your target's armor value from items by 25% for 15 sec after getting a critical effect from one of your healing spells.
Totemic Focus
Rank 2/5
Reduces the Mana cost of your totems by 4%.
Combat Endurance
Rank 1/1
Allows 10% of your Health regeneration to work while in combat.
Improved Lesser Healing Wave
Rank 5/5
Gives you a 75% chance to avoid interruption caused by damage while casting Lesser Healing Wave.
Tidal Mastery
Rank 5/5
Increases the critical effect chance of your healing and lightning spells by 5%.
Nature's Swiftness
Rank 1/1
Instant 3 min cooldown
When activated, your next Nature spell with a casting time less then 10 sec. becomes an instant cast spell.
Restoration Total: 26
Enhancement Mastery
Ancestral Knowledge
Rank 5/5
Thundering Strikes
Rank 5/5
Improved Ghost Wolf
Rank 2/2
Reduces the cast time of your Ghost Wolf spell by 2 sec.
Rank 1/1
Anticipation
Rank 5/5
Increases your Defense skill by 10.
Flurry
Rank 5/5
Rank 2/2
Increases the Attack Power bonus of your Windfury Weapon effect by 22%.
Enhancement Total: 25
Total
Total Points Spent: 51
Level Required: 60
Er det bare jeg som ikke leser templates'ene som legges ut lenger?
Etterhvert så finnes alt du trenger om Shaman templates på wow-europe forumet, og akkurat DIN build har HELT sikkert vært postet der...
Men den alltids interessante diskusjonen om WF eller RB er morsom å diskutere!
Hva er best etter din mening? RB på rask dagger+shield eller WF på treg max dps axe? Selv heller jeg mer og mer over til WF uansett!
Som en på wow-europe forumet sier, så er den overraskende skaden som WF+slow 2hander ubetalelig i pvp. Problemet er den "overskytende" skaden. (Eks: Targetet ditt har igjen 200 HP, WF proccer med våpenet ditt og du gjør 800 i skade. Da har du plutselig 600 i skade som er unødvendig.)
WF på en rask dagger gjør at denne overskytende skaden ikke blir så stor, og gjør at flurry kicker inn langt oftere (som igjen gir oftere WF proccs...) Glem alt du har hørt om en cap på WF proccs i minuttet, WF kan i ekstreme tilfeller procce på alle "vanlige" melee attacks (ikke WF attacks selvfølgelig).
Kjør debatt!
Fin build der ja, skal prøve den på min shaman (chokke's siste template)
/cheer :p
Det eneste jeg er usikker på er om jeg skal ta mer mana eller mer blokk med skjold :)
