Speedtouch 510i. Åpne port. Feil ip?
Har et Thompson speedtouch 510i (tele2). Har sett at det er flere som har hatt trøbbel med denne routeren. Det som skjer når jeg skriver ip-adressen til routeren (10.0.0.138) i nettleseren min er.... nada. Er dette feil ip?
Jeg er ganske grønn på dette, og klarer ikke finne noen svar ut i fra de andre innleggene som gjelder samme router.
Skal bruke emule. Dersom det skulle ha noe å si for hvilke(n) port som skal opp...
Håper noen tar seg tid til å svare på dette under innkjøringen til påska
God påske
Edit: skriveleif
Endret av jaymz
porter som skal åpnes er følgende
Ports
The following list shows the ports used by eMule when using it's default settings. If you change anything in Preferences -> Connection you will have to take the changes into account when configuring your firewall or router.
1) Local Port: 4662
Remote Port: any
Protocol: TCP
Direction: incoming
Purpose: Client Port / Connections from other clients, Client to Client Source Exchange
Note: You can change this port in Preferences -> Connection -> Client Port
This port has to be forwarded in a router. Changing this port in Preferences you must also change the forwarding in the router
2) Local Port: any
Remote Port: 4662
Protocol: TCP
Direction: outgoing
Purpose: Client Port / Connections to other clients, Client to Client Source Exchange
Note: 4662 is the default port, but other clients may have different settings. Change the remote port to any when configuring a firewall
3) Local Port: 4672
Remote Port: any
Protocol: UDP
Direction: incoming
Purpose: Clients source asking / extended eMule protocol, Queue Rating, File Reask Ping
Note: This port has to be forwarded in a router. Changing this port in Preferences you must also change the forwarding in the router.
If you are not able to forward this port check the disable box in Preferences -> Connection -> UDP Port
4) Local Port: any
Remote Port: 4672
Protocol: UDP
Direction: outgoing
Note: 4672 is the default port, but other clients may have different settings. Change the remote port to any when configuring a firewall
5) Local Port: any
Remote Port: 4661
Protocol: TCP
Direction: outgoing
Purpose: Connection to server
Note: 4661 is the default port of a server. Many server use different ports. Configuring a firewall the remote port again changes to any.
6) Local Port: any
Remote Port: 4665
Protocol: UDP
Direction: outgoing
Purpose: Source asking on servers
Note: Servers using the default port 4661 TCP (see #5) automatically set their port for source asking to 4665 UDP. If a server uses a different port in #5 the corresponding UDP port is set to [Connection Port + 4]. For firewalls the remote port here is any.
7) Local Port: 4711
Remote Port: any
Protocol: TCP
Direction: incoming
Purpose: Webserver
Note: This is the default port for the web interface. When using a router this port has to be forwarded or no connection to the webserver will be possible
Er ikke disse satt opp som brigde når Tele2 bruker dem, da har de ikke noen porter og åpne i og med allt passerer rett igjenom.
Takk for svar.
Hvordan kan jeg finne ut om "alt passerer igennom". Vil det si at jeg bare kan installere emule og kjøre det uten å gjøre noe mer?
Edit: Hvilken versjon av emule anbefaler dere?
Endret av jaymz
