Kan du hjelp meg med å koble pc og xbox?
jeg fant jeg fant:
What you need to do next is configure your computers ip address’s.. so go into your computer network connections and go into the properties of the nic that is connected to the internet. check off obtain a IP address automatically.
now for the nic that is connected to the xbox. going into the properties. check off use the following IP.
Next, where it says IP address, enter: 192.168.0.1. Where it says Subnet Mask, enter: 255.255.255.0. , and where it says default gateway enter 192.168.0.1
next while still in the properties of the nic. click on the configure button.. then click on the advanced tab. then click on network media and set it to 10baseT full duplex.
now your computer should all be good to go.
now you want to startup evolution x and go into the system settings a get your IP address. its usually 192.168.0.3 something like that. make note of it.
now you want to fire up flashfxp
Flash FXP:
1. Download this program
2. Open it up and click on “Site Manager” then click “new site”
3. Name the new site whatever you want, (My Xbox, Xbox, etc.)
4. Go to IP and enter the IP you got from evolution x system setting menu
5. The port should always be 21
6. your username and password will both be “xbox”
7. Hit the “Options” tab and click off passive mode COMPLETELY.
8. now apply. and the connect
