Nye C&C Generals Zero Hour er her!
Nå blir det beste rts til dags dato endelig patchet!
Slutt på ubalanse, hacks og cheats. Anbefaler alle som spiller eller har spilt dette om å gå hit og laste ned :
http://cncreplays.com/forum/index.php?showtopic=17685
Dette kommer til å bli råbra!
For de rts fans som ikke ser det store med trollmenn, trær og gud veit hva, men som liker tanksbattles, dogfights og mer moderne krigføring...sats på Zero Hour!
Dette spillet har potensiale til å bli det største noensinne...
Oppdatering: Nå har de sluppet aceton0.3, det er mye mer balansert nå:)
Du kan faktisk spille mot alle generalene og ha en sjans nå. Masse justeringer.
Endret av kåre
Stemmer:)
Her er modifiseringene så langt:
V0.3 - July 2004
General:
- Infantry General tooltips changed
Balance Changes:
China Infantry General:
Attack Outpost:
- Decreased prize from 1400 to 1000
- Decreased build time from 17 to 15 seconds
- Reduced included Tank Hunter from 4 to 3
- Decreased HP from 350 to 300
- Decreased heal rate non upgraded to 1% and when upgraded to 2% (It was 4% and 4%)
Advanced Troop Crawler:
- Decreased heal rate non upgraded to 2% and when upgraded to 4% (It was 4% and 4%)
Bugfixes:
- Fixed a problem which was caused by BalanceMod 0.2. King Raptors now got the correct damage back
- Raptors and King Raptors now get the correct +25% damage when upgraded to Laser Missiles.
In Zero Hour 1.1 it was less than 25%.
- Removed the Mig Code from 0.2. Theres was a Problem with the Napalm graphik effect
- You can now aim at airtargets with the Humvee
V0.2 - July 2004
General:
- Added language support for the Polish, Brazilian and Chinese version
Balance Changes:
All USA:
Ambulance:
- Decreased heal rate to vehicles from 8 to 5 HP/sec
Battledrone:
- Increased heal rate from 5 to 10 HP/sec
Flashbangs:
- Increased primary damage from 25 to 35
All China:
Gatling Tanks:
- Increased Gatling Tank expierience to 0 - 80 - 200 - 300
All GLA:
Technicals:
- The primary weapon now use gat damage and no more commanche vulcan
USA:
- Composite Armor for Crusader increased back to +40%
USA Super Weapon General:
Aurora Alpha Bomber:
- Secondary attack damage decreased from 1000 to 900
- Secondary attack range decreased from 100 to 70
China Tank General:
- removed sublimial messaging from the Emperor Tank
Bugfixes:
- Aurora Alpha Bomber now got the right Design
- The Hellfire, Spy and Battle Drone now gets the correct armor when upgrading to "Drone Armor".
- Raptors and Stealth Fighters aren't recharged in the air anymore when buying the laser missile upgrade.
- Migs aren't recharged in the air anymore when buying the napalm upgrade.
- The easy visible bomb truck concealed as an avenger bug is fixed.
- The computer didn't always recognise the battlebus as a unit - this bug is now fixed.
- The rockets of the Commanche Upgrade RocketPod now are red if the commanche has reached
elite status.
- The map was sometimes slightly uncovered when building an avenger. This bug is now fixed.
V0.1 - June 2004
General:
Balance Changes:
All USA:
Sentry Drone:
- Drone Armor upgrade now works (+25% armor)
All China:
Outpost:
- Speed (not damaged) decreased from 40 to 35
- Speed (damaged) decreased to 25 (was 30)
Attack Outpost:
- Increased prize from 1000 to 1400
- Increased build time from 15 to 17 seconds
- Decreased slots from 10 to 6
- Number of included minigunners reduced from 8 to 6
- Decreased slots from 8 to 6
Miniguner:
- Increased prize from 350 to 400
- Decreased damage to airunits from 12 to 10
Helix:
- Increased prize from 1500 to 1600
Bugfixes:
- ScudStorm Bug fixed
- Locomotor of sw, laser and air avenger corrected (they had the crusader locomotor)
- Armor of the crusader with composite armor upgrade corrected
- Emperor's propaganda tower influence now works
- The correct Rangers now appear when a building from the Superweapon,
Laser or Airforce General is destroyed
You can now aim at airtargets with:
- the Avenger
- the Outpost
- the Battlebus
Corrected UpgradeCameos:
All USA:
- Structures
- Chinook
- Pilot
- Paladin
- SpyDrone
- Humvee
- Sentry Drone
- Tomahawk
- Avenger
- SupplyCenter
- Ambulance
- MicrowaveTank
- Combat Chinook
- King Raptor
- Commanche
All China:
- Structures
- Speaker Tower
- Helix
- Battlemaster
- Overlord
- Nuklear Overlord
- MiG
- Helix
- Minigunner
- Attack Outpost
- Assault Troopcrawler
- Assualt Helix
- Tank Hunter
All GLA:
- Structures
- Rebel
- Bomb Truck
- SCUD Storm
- Scorpion
- RPG Trooper
- Toxin Terrorist
- Bomb truck
- Demo Trap
- SCUD Launcher
- Angry Mob
Demolitation General:
- Demolitations Ability Cameo added to all Units
Det blir de største forandringene nå opp til 0.6, så får en se om det trengs finjusteringer...
Jokke: Jada, over alt :whistle:
invictus: SW blir fikset, må ta det litt etappevis dette her :p Han er ikke så veldig vanskelig egentlig, nesten ingen som spiller det. Grunnen er at han er ganske så hjelpeløs early game, så et rush mot SW-generalen tar som regel knekken på ham.
Prøv deg med vanlig usa mot usaf, så ser du hva som virkelig er ubalansert :thumbdown: Men, alt dette blir fikset uansett :w00t:
Da har jeg installert. Men det var ikke mange online som har lagt til dette. Fant bare to spill. Håper det blir flere etter hvert, for dette så bra ut.
Oppdatering: Nå har aceton blitt oppdatert igjen, mange cheats som har blitt fikset. Umulig å fuske nå lenger :yes:
AK47: Jeg ser at der er en del som bruker aceton uten mod enda. Venter kansje til balanseringen er ferdig. Enkleste er vel å velge hva du selv vil spille, med eller uten mod, men alltid med aceton.
Så lager du et spill som du kaller aceton(uten mod) eller acetonmod(med mod) alt etter hva du vil spille. Tror ikke det skal ta så lang tid før folk kommer inn :thumbup:
