Få opptil 20% mer ytelse på lokalt nettverk
Fant en genial artikkel på TweakXP. Måtte nesten ta den med her, da den faktisk fungerte :p
Traffic flow can be managed very well in Windows XP using the Quality of Service (QoS) Resource Reservation Protocol (RSVP). However, programs must be designed to take advantage of this QoS API. The traffic from programs that are not QoS-aware are sent directly to a different API called TCI. These programs have to fight for bandwidth because unlike the QoS API, there is no bandwidth reservation. If you use a lot of QoS-aware programs and would like to change the percent of the bandwidth that is reserved for the program, read below.
  1.
  2. Make sure your logged on as Administrator. Do not log on with any account that just has administrator privileges.
    To log in as Administrator:
    - Click on start->logoff->logoff
    - At the logon screen hold Ctrl+Alt+Del.
    - In the user field type 'Administrator'
    - In the password field type the password for the administrator (if you don't have one leave blank) and press OK
  3. Click on the Start button and select run.
  4. Type gpedit.msc in the text box and click OK
  5. Once the program loads, expand the Computer configuration branch.
  6. Expand the Administrative templates branch.
  7. Expand the Network branch.
  8. Highlight the QoS Packet Scheduler in left window.
  9. In right window double click the limit reservable bandwidth setting
  10. On setting tab check the enabled option.
  11. Where it says Bandwidth limit %, change it to read what ever percent you want to reserve for QoS-aware applications.
  12. Click OK and exit the group policy editor.
  13. Go to your Network connections (start->my computer->my network connection-> view network connections).
  14. Right click on your connection, choose properties then under the General or the Networking tab (where it lists your protocols) make sure QoS packet scheduler is enabled.
  15. Now just reboot your computer and you are all done.
When a QoS-aware program is in use it will reserve the allocated amount of bandwidth and that will take away form other non QoS-aware programs. However, once the QoS-aware application is closed or closes the network connection, the bandwidth reservation is released. This is done by a series of PATH and RESV refresh messages sent back and fourth over the connection. Once these messages are no longer detected, the data flow is closed and the reservation of bandwidth is eliminated.
For mer informasjon om QoS Traffic Control i win2k, se her.
For mer informasjon om QoS Traffic Control i winxp, se her.
For mer informasjon om kontroll/reservasjon av båndbredde, se her.
edit; la til en link.
Endret av jallakim
Du får ikke 20% bedre ytelse...men du får tilgang til 100% av båndbredden istedetfor 80%. Det er 2 forskjellige ting det. ;)
Ikke nødvendigvis 20% bedre ytelse, men 20% mer ytelse. Sorry min dårlige forumlering da..
:roll:
Det er klart at dette avhenger hvilken forbindelse man har. Hvis du sitter med et 56.6kbs modem eller ISDN vil frigjøring av 20% båndbredde gi en god forbedring. Har man derimot et LAN med 100Mbit så spørs det om man kan merke noe forskjell.
