Silicon Graphics 1600SW
eggi
Noen som har kjennskap til disse? skal i hovedsak brukes til foto/video
Det er jo en gammel skjerm så hvordan yter den i forhold til nyere lcd skjermer?
Link til en gammel test:www.geek.com
Jeg ser den selges for rundt 400 $ brukt
Kopiert fra webside:
"Silicon Graphics 1600SW 17" Flat Panel - NICE!
Number Nine 32Mb PCI Revolution IV Included!
Your bid is for (1) highly sought after Silicon Graphics 1600SW 17" , photo quality, flat panel monitor and matching PCI card.
This is THE ultimate professional flat panel monitor
The Silicon Graphics 1600SW flat panel monitor redefines the state of the art for LCD monitors, delivering the best image quality of any LCD or CRT monitor on the market. The value is immediately apparent when viewing images that appear more like photographic transparencies than pixels on a screen. With 110 dpi and three times the brightness and five times the contrast of CRTs, images come to life as never before and data jumps off of the screen. The Active Matrix LCD (AMLCD) ensures fast pixel response for real-time video playback and animation with none of the common LCD artifacts. With the Silicon Graphics 1600SW flat panel LCD monitor there is never any flicker-making eyestrain and headaches a thing of the past.
The SuperWide aspect ratio of the display is unique to SGI and enables the simultaneous display of two pages of information side by side. Combine that with the market-leading 1600x1024 resolution, and you see every detail in true, 24-bit color. The all-digital interface ensures the sharpest image possible.
This level of quality must be seen to be believed. The monitor has won 16 international awards from leading publications like PC Computing (MVP Breakthrough 1998), PCWorld (World Class Award 1999), Computer Graphics World (Innovation Award 1999), and Imaging Magazine (Product of the Year 1998).
Whether the application is financial trading, desktop publishing, or game development, the Silicon Graphics 1600SW flat panel monitor will maximize return on investment due to reduced power usage, efficient desk space utilization, and, most of all, improved user comfort and productivity.
Features
-Exclusive, ergonomic SuperWide screen displays two side-by-side pages
-Stunning 1600x1024 resolution
- 3X brightness of CRTs
- 5X contrast of CRTs
- The first photo-realistic monitor, providing the finest dot pitch available (110 dpi)
- Large 17.3" diagonal viewing area
- Fastest pixel response available for video playback
- All-digital interface for the ultimate in image quality
- Leading-edge styling, space-saving design
Included Number Nine PCI Revolution IV for 1600SW
This video card is the card of choice for the Silicon Graphics 1600SW Flat-Panel Monitor.
Features
· Pure 128-Bit Graphics Power
· 32MB of SDRAM
· World's First 128-bit Memory bus to SDRAM
· Integrated 250 MHz Palette DAC
· Hot 3D, Awesome 2D Performance
· Full-Screen, 30 Frames/second Video Playback
· True Color (32-bit) to 1600 x 1200 @ 92Hz
· Extensive 3D Features for Direct3D and OpenGL APIs
· Ultimate Performance for Professional and Consumer Markets
Specifications
· Graphics Processor: Number Nine "Ticket to Ride IV"
· Memory Configuration: 32MB SDRAM
· Maximum Dot Clock: 250 MHz
· Horizontal Sync Signals: 31.5-121 KHz
· Vertical Refresh: 60-150 Hz
· Video Output Signal:
· Analog
· Video Connectors: Standard 15-pin D-shell and 1600SW Connector
· Bus Architecture PCI
· Approvals: FCC Class B certified, CISPR22, TUV, CE mark, WHQL
· Monitors Supported: Standard and multi-frequency
· Resolutions Supported:
· 2D True color (32-bit) up to 1920 x 1080
· 2D High color (16-bit) up to 1920 x 1080
· 3D High color (16-bit) up to 1920 x 1080
· 3D True color (32-bit) up to 1280 x 1024
· 3D True color (32-bit) up to 1600 x 1200 (32MB version only)
The Revolution IV PCI card provides plenty of space to store and process massive textures, large images, and more, while maintaining flicker-free refresh rates at ultra-high resolutions. With rock solid display and driver quality and support for the stunning Silicon Graphics 1600SW digital flat panel monitor, Revolution IV will satisfy the most critical graphics professional, business user, and games enthusiast.
Included in package:
1600sw flat panel monitor
12v brick style power supply
Number Nine Revolution IV PCI Card
All in excellent working and cosmetic condition. "
Syntes det hørtes litt "dodgy" ut.. det _var_ sikkert en super skjerm, men kilden din sier jo ikke noe om tekniske spesifikasjoner.. oppgir jo ting som 2 ganger ditt og 5 ganger datt.. det er ikke noe bra mål på ting ;) Når det gjelder skjermen så kan du håpe at oyvind_dahle dukker opp i posten din (aspirerende LCD-guru (ikke LSD-)) evt send ham en PM.. En så gammel LCD skjerm har vel også noe høyere responstid, så det begrenser jo bruksområdene. (testet i 99?)
Det skjermkortet er vel ikke noe å samle på lengre.. skal du ha noe bra i 2D så går du for feks Matrox.. skal du ha noe i 3D så står du veldig fritt til å velge mellom de ledende merkene..
$400 for det der høres ut som blodpris, men det er min mening.
Jeg tolker det ut i fra posten din at dette er en økonomisak, så å kjøpe et nytt skjermkort og ny skjerm blir for dyrt..
film... vel for 24 bilder pr sek så blir det 1000ms/24= 41.67ms pr bilde.
Om dette er reelt vet jeg ikke. For hhv 25 og 30 bilder pr sek ser det ikke så lovende ut.
Monitoren var sikkert helt unik i sin tid. Det er jo langt hyggeligere oppløsning på den enn på nye skjermer i dag.
Dette er en veldig god skjerm, til video og grafikk er SGI overlegen.
Når det gjelder skjermkortet er det nok bra ilag med skjermen, husk
dette er ikkje kort laget for spilling.
Disse proff kortene er laget for video og grafikk, har selv et 10 års
gammelt PCI 12" kort (ThunderColor), dette er også et spesialkort
som ikkje er egnet for spilling, men er fortsatt helt i toppen når det gjelder
farger. Kostet over 20 000 nytt dette, vil anta at det som er prat om
her ligger på samme nivå.
For å si det kort, dette er en skjerm og kort som ikkje er egnet til spilling,
men er glimrende til grafikk og video.
Om du besøker SGI vil du se at alt er
bygd andeledes enn vanlige PC... Helt annen tenkemåte på det meste:
Optimalisert til tung tv/video
Endret av kvikks
Det er vel ingen som sier noe om spilling her ;)
Han har jo sagt hva han skal bruke det til. Jeg holder fremdeles fast på at et Matrox-kort (P650 eller p750) vil være en fornuftig oppgradering fra det aldrende PCI kortet.
edit: fant en test...
http://www.billsworkshop.com/comdex/sgi1600sw.html
"LCDs are inherently brighter than CRT's, but the 1600SW takes it to a new level with brightness of 235cd/m2 maximum (about 3 times a CRT) with contrast as high as 350:1 (5 times a CRT). The ability to display high-contrast images without loss of detail in gray, shadow areas was remarkable. As with other LCD's, the image is totally flicker-free; however, the 1600SW shows no observable ghosting, a problem with other LCD's. Ghosting is the result of the relatively slow refresh rate of LCD panels, with most limited to a maximum of 10Hz regardless of signal. The 1600SW pixels refresh at 30Hz."
Til sammenligning så ligger dagens LCD skjermer på 250 cd/m2 og har kontrastforhold på rundt 400-750:1. Det som virkelig er beundringsverdig er oppløsningen.. 1600x1024.
Endret av hart
