SilverBlade Skrevet 25. november 2010 Skrevet 25. november 2010 Hei skal bygge meg en stasjonær pc, men vet ikke hvilken jeg bør gå for? trenger hjelp til å velge. Alt av deler er hentet fra komplett.no PC nr 1: •518692 AMD Phenom II X4 965 Black Edition Quad Core, 3,4Ghz, AM3, 8MB, 125W, Boxed •593865 ASUS Crosshair IV Formula, Socket-AM3 ATX, AMD890FX+SB850, DDR3, 4xPCIe(2.0)x16, SATA 6Gb/s, USB 3.0, SupremeFX X-FI •340676 Corsair TX 650W PSU ATX 12V V2.2, 80 Plus, Standard. 2x 6+2-pin PCIe, 8x SATA, 120mm Vifte •491282 Corsair XMS3 DDR3 1600MHz 4GB CL9 Kit w/2x 2GB XMS3 modules, CL9-9-9-24, for Core i5 and i7, 1.65V, Intel XMP •336044 D-Link DWA-140 Wireless N USB adapter, 802.11n (draft 2.0) •585861 Fractal Design 120mm Silent Vifte 120 x 120 x 25mm, 1000 RPM, 38.3 CFM, 15 dBA, 3-pin •605521 Fractal Design Define R3 Black Pearl Vifter: 1x 120mm Front, 1x 120mm Bak, Lydabsorberende, ATX, mATX, mITX •499989 Microsoft Windows 7 Home Premium NO OEM, 64bit •573264 Samsung DVD±RW burner, SH-S223C 22x DVD, DVDRAM, SATA, Black, Bulk •496258 Samsung SpinPoint F3 1TB 7200RPM, SATA 3.0 Gbps, 3,5", 32MB Cache, 8.9ms •614349 XFX Radeon HD 6870 1GB GDDR5 PCI-Express 2.0, 2xDVI, HDMI, 2xmini-DisplayPort, 900MHz PC nr 2: •513218 ASUS P7P55D-E PRO, Socket-1156 ATX, P55, DDR3, 2xPCIe(2.0)x16, GbLAN, SATA 6Gb/s, USB 3.0 •340676 Corsair TX 650W PSU ATX 12V V2.2, 80 Plus, Standard. 2x 6+2-pin PCIe, 8x SATA, 120mm Vifte •491282 Corsair XMS3 DDR3 1600MHz 4GB CL9 Kit w/2x 2GB XMS3 modules, CL9-9-9-24, for Core i5 and i7, 1.65V, Intel XMP •336044 D-Link DWA-140 Wireless N USB adapter, 802.11n (draft 2.0) •585861 Fractal Design 120mm Silent Vifte 120 x 120 x 25mm, 1000 RPM, 38.3 CFM, 15 dBA, 3-pin •605521 Fractal Design Define R3 Black Pearl Vifter: 1x 120mm Front, 1x 120mm Bak, Lydabsorberende, ATX, mATX, mITX •604498 Intel Core™ i5 Quad Processor i5-760 Quad Core, 2.80Ghz, Socket 1156, 8MB, 95W, Boxed w/fan •499989 Microsoft Windows 7 Home Premium NO OEM, 64bit •573264 Samsung DVD±RW burner, SH-S223C 22x DVD, DVDRAM, SATA, Black, Bulk •496258 Samsung SpinPoint F3 1TB 7200RPM, SATA 3.0 Gbps, 3,5", 32MB Cache, 8.9ms •614349 XFX Radeon HD 6870 1GB GDDR5 PCI-Express 2.0, 2xDVI, HDMI, 2xmini-DisplayPort, 900MHz er der noe dere vil bytte ut?? så si fra tar i mot all kritik takk
Hårek Skrevet 25. november 2010 Skrevet 25. november 2010 Ingen vits å opprette 4 tråder om det samme. Fortsett i denne: https://www.diskusjon.no/index.php?showtopic=1277803
