Kan noen fortelle meg hvorfor jeg ikke får installert MS flight simulator X?
Hei. Jeg får denne feilmeldingen under installasjon av microsoft flight simulator X deluxe edition:
Error 1935.An error occured during the instalation of assembly Microsoft.FlightSimulator.SimConnect, publicKeyToken="67c7c14424d61b5b",version="10.0.60905.0",type="win32",processorArchitecture="x86". Please refer to Helpand Support for more information. HRESULT: 0x800736E7.
Error: -1603 Fatal error during installation. Consult Windows Installer Help (Msi.chm) or MSDN for more information.
Noen som har hatt det samme problemet som har en løsning?
Endret av Mountain dew
Hvis du bruker XP er det mulig dette funker.
when the 1935 error apear, open the procces viewr and kill all the proces realted with the installation.
download the msxml4 SP2 from the micrsoft page and install it.
http://www.microsoft.com/downloads/details...;DisplayLang=en
then open the note pad and copy this into it:
<?xml version='1.0' encoding='UTF-8' standalone='yes'?>
<assembly xmlns='urn:schemas-microsoft-com:asm.v1' manifestVersion='1.0'>
<dependency>
<dependentAssembly>
<assemblyIdentity type='win32' name='Microsoft.MSXML2' version='4.20.9818.0' processorArchitecture='x86' publicKeyToken='6bd6b9abf345378f' />
</dependentAssembly>
</dependency>
<dependency>
<dependentAssembly>
<assemblyIdentity type='win32' name='Microsoft.MSXML2R' version='4.1.0.0' processorArchitecture='x86' publicKeyToken='6bd6b9abf345378f' />
</dependency>
</assembly>
save the document as " msxml4.manifest " and paste him into the FX folder, then the FX mast run , it works to me, i hope it works to you.
Dette er et vanlig problem, du finner tonnevis av løsninger i google.
http://tinyurl.com/m34fhu
