GTA4 Fryser Randomly etter et par minutters spill
Specs:
AMD X4 940 PhenomII
ASUS M3A H/HDMI
Gainward GeForce 260GTX Core216
2x Samsung Spinpoint 500gb RAID0
8GB 6400 Mushkin RAM
Windows Vista Home Premium 64
GTA4 Retail med Patch2 innstallert.
182.08 Skjermkort Drivere
Problem:
Starter spillet helt fint.Spiller vanlig et par minutt opp til et kvarter. Så Fryser alt (inkludert lyd) Behøver ikke restart av systemet,men spillet må lukkes via taskbar. Ingen feilmeldinger.
Dette skjer uansett hvilken innstillinger jeg kjører med.
Noen med slike problemer med tips?
Google-søk gir massevis av treff på lignende problemer, så jeg legger ved et par lenker som kan være av interresse ;)
http://www.gtaforums.com/index.php?showtopic=390498
http://www.gtaforums.com/index.php?showtopic=390733
http://www.google.no/search?hl=no&q=GT...3%B8k&meta=
I tillegg fant jeg dette på et forum, noe å prøve?
Yesterday I found that in order to prevent RESC10 crashes on all Nvidia drivers, I had to disable the setting for "pre-rendered frames".
This is a poor workaround, as overall fps suffers, but the game doesn't crash.
Now I have found that due to the way GTA4 is coded, it cannot run properly with a common XP and Vista memory "tweak".
google: DisablePagingExecutive
It is somethiing which is set by many pointless programs such as Registry Mechanic and TuneUp Utilities etc etc.
Reset this value to 0, which is how XP and Vista are at default and GTA plays much better with "pre-rendered frames".
Most games play fine with or without this tweak but, at least on my system, GTA4 does not.
This could very well be something Rockstar never tested for....
Moral of the story is - You really can over "optimize" your pc to death.
