[Løst]Age of Conan-Problem [LØST]
Hei alle sammen. Etter en oppdatering til nyeste versjon av Age of Conan ble jeg møtt av dette her:
Har noen forslag til hva jeg kan gjøre for å rette opp dette?
Har aldri hatt problemer med spillet før nå. Kjører Vista Ultimate på maskinen. Her er noen spesifikasjoner fra velkomstsenter :)
Om mer informasjon skulle behøves så er det bare å si fra :)
Vennlig Hilsen Fra SpecialForce
Endret av SpecialForce
AoC Forum: http://forums-eu.ageofconan.com/showthread.php?t=100034
To install the update, do the following (thanks go to Tarkadahl for writing these instructions):
1. Create a new folder on your desktop, call it something like "DirectX November" or something like that. The name doesn't matter. Just make sure it's something you can find easily.
2. Download the Directx update to your desktop (or somewhere you can find it).
Right click the link below and select "Open in new window" to go to the website to download the Directx Update:
http://www.microsoft.com/downloads/d...8-9f20f1244a8e
Once it's downloaded, double click the file and when asked, browse to the new folder you created and click OK to begin extracting the files.
NOTE: At this point it hasn't actually installed it yet, it just extracted (unzipped) the contents of the downloaded file to your new folder.
3. Once it's finished "extracting" (unzipping) the files, open the folder you created. You'll see a lot of files in there now. Find the file called "DXSETUP" (or "DXSETUP.exe") in there, and then double click it to install update.
Once it's installed, and if you want, you can now delete that folder you created because it, and the files within it, are no longer needed.
Problemet er at oppdateringen ikke ville installere seg. Skal prøve på nytt tho.
Edit: Da ser det ut til at vi er oppe og går igjen. Tusen takk for all hjelp :)
