Insomniatic Skrevet 31. august 2008 Skrevet 31. august 2008 (endret) Etter at jeg oppgraderte til Firefox 3 så vises bokmerkene i adressefeltet når jeg søker, hvordan slår jeg av dette? Slik ser det ut. Jeg vet ikke om dette er riktig postet, fordi firefox er jo internett osv... Endret 31. august 2008 av Latterkongen
Svenni212000 Skrevet 31. august 2008 Skrevet 31. august 2008 Kan denne løsningen være til hjelp? http://www.mydigitallife.info/2008/06/19/d...on-address-bar/ To revert to old style and working format of Firefox 2 Location Bar where only typed URLs or location addresses is shown and displayed in Firefox 3 Location Bar, configure and set the matchOnlyTyped to True. To do so, type about:config in the Location Bar, confirm you know what you’re doing by clicking on I’ll be careful, I promise! button. Then locate browser.urlbar.matchOnlyTyped preference name. By default, it will has the value of “false”. Double click on the link to change the value to true. Now, only typed URL will be taken into consideration in Location Bar.
Skagen Skrevet 31. august 2008 Skrevet 31. august 2008 Tråden var feilpostet og har blitt flyttet til riktig kategori. (Vennligst ikke kommenter dette innlegget. Reaksjoner på moderering gjøres pr. PM/melding)
Trynemjoel Skrevet 31. august 2008 Skrevet 31. august 2008 https://addons.mozilla.org/en-US/firefox/addon/6227
Insomniatic Skrevet 1. september 2008 Forfatter Skrevet 1. september 2008 Kan denne løsningen være til hjelp?http://www.mydigitallife.info/2008/06/19/d...on-address-bar/ To revert to old style and working format of Firefox 2 Location Bar where only typed URLs or location addresses is shown and displayed in Firefox 3 Location Bar, configure and set the matchOnlyTyped to True. To do so, type about:config in the Location Bar, confirm you know what you’re doing by clicking on I’ll be careful, I promise! button. Then locate browser.urlbar.matchOnlyTyped preference name. By default, it will has the value of “false”. Double click on the link to change the value to true. Now, only typed URL will be taken into consideration in Location Bar. Tusen takk, det hjalp ------------------------- Tråden kan stenges nå.
