Amd - Puma - brukbart ?
hva med å kunne koble et ekternt 3870 til laptoppen, spennende
Taking the GPU out of the notebook
Speaking of high-end graphics, AMD has one further trick up its sleeve. For most of the past two decades, the visual quality and capability of any given laptop has been constrained by any number of factors, including weight, cost, power consumption, available screen size, and fundamental limitations on display quality. Many of these factors are finally being addressed, but a consumer who wants to balance an occasional need for a high-powered graphics solution against a general desire for long battery life may still have trouble finding a notebook that meets both needs. Technologies like PowerXpress are a partial solution to this problem, but why not go a step further, and eliminate the need for a discrete GPU within the laptop case itself?
AMD plans to take a shot at liberating the discrete GPU from the notebook form factor with its ATI External Graphics Platform, for XGP. As the name implies, XGP is a full-featured graphics card that would sit outside the notebook in its own, separate, enclosure. The XGP would connect to the laptop via a PCIe 2.0 x8 external connector (4.0GB/s of bidirectional bandwidth). All of the XGP's cooling requirements would be handled by the enclosure; power would presumably be provided by the external PCIe 2.0 linkage. The RS780M chipset is already designed to take advantage of this feature, but notebook OEMs will have to build the appropriate connectors into their designs, while ATI and its partners offer the equivalent external modules.
http://www.tomsguide.com/us/slideshow/AMD4...-3-0-ajpg-.html
kilde
Synes Puma virker spennende. Har troe på AMD som et alternativ til Intel.
Her er noen bilder av Puma lappiser fra MSI.
Min personlige favoritt:
12 tommer med 3450 og hybrid grafikk. Interresangt alternativ.
Ja jeg har også tenkt på puma
her er det jeg vet så langt
Alle AMD Puma bærbare har
AMD Turion X2 Ultra cpu
AMD 780G Chipset (Radeon HD 3200 IGP)
Blu-Ray Disc maskinvare dekoding via UVD innebygd i IGPen
WLan 802.11n
Andre ting er
HyperTransport 3.0 (bedre cpu/minne/skjermkort ytelse)
Split Power Planes (forsjelig strøm nivåer i chipset/cpu)
Støtte for Hybrid Crossfire, så du kan kjøre HD 3200+3470, HD 3200+3650
Opptil 4 timer med batteri
ATI PowerXpress (skrur av dedikert skjermkort når du tar ut strømen for bedre batteri levetid)
Noen har støtte for XGP (externt skjermkort av typen Radeon HD 3870)
som FSC sin 13" Sa 3650
http://www.fujitsu-siemens.no/home/products/design.html (FSC 3000 serie)
http://www.fujitsu-siemens.no/home/product...lo_sa_3650.html
Endret av wiak
Når vil maskiner med denne prosessoren være tilgjenglig for oss forbrukere? Noen som vet?
juli vis ikke jeg tar feil
Puma ikke bare i bærbare
puma er 780G chipset med en cpu som er laget for mindre strøm og har hypertranport 3.0 ;)
Endret av wiak
  • 2 uker senere...
Vi vite mer! Skal kjøpe bærbar nå i løpet av sommeren/starten av skoleåret. Puma ser fristende ut.
Noen som kan forklare dette med skjermkortene? Sånn som jeg forstår nå er det to skjermkort. Et integrert som er reltivt dårlig som går til vanlig, og i tilleg så han man et dedikert man kan bruke når man vil spille? Hvordan er det dedikerte i forhold til andre bærbare grafikkort?
Har lyst på bærbar som også har litt grafikkytelse uten at den blir "slepbar". Håper Puma kan hjelpe der.
Butikken der jeg jobber har vi HP-maskiner med puma i bestilling. Forventet levert medio juli, kanskje noe tidligere.
Endret av Nuffern
  • 2 uker senere...
Det er vel ikke dv5z modellen vel? Den ser meget bra ut, alt du kan tenke deg av I/O's og en bra skjerm, ivertfall på den som er testet på notebookreview.com. Noen som vet pris på denne her jemme?
Veldig bra maskin i følge testen! Det eneste som skuffer er at den mangler Firewire. Det burde være standard på alle maskiner over 4500 kroner i dag spør du meg.
Puma kommer til å gjøre rent bord i lavprissegmentet, ytelesen på grafikken og strømsparefunksjonene er midt i blinken. Maskinen i testen skåret allikevel dårlig på batterilevetid, lurer på om det er isolert for den maskinen eller om andre reviews kommer til å vise det samme.
Min erfaring er at de aller fleste forbrukermodellene fra HP har dårlig battertid. Sjeldent mer enn 1,5 t til 2,5 t battertid. Gjerne ned mot 1t 45 min.
Endret av Nuffern
Ifølge den første linken der så er Puma veien å gå hvis man er ute etter en budsjett-bærbar.
Men sånn som jeg forstår det så må det jo komme noen ganske bra bærbare ut fra denne plattformen. Hybrid CrossFire legger jo grunnlaget for å kunne få ganske bra grafikk hvis man putter inn et godt dedikert grafikkort ved siden av? Eller har jeg misforstått?
Er det de relativt lave klokkefrekvensene på porosessorene som gjør at dette blir budsjett-PCer?
Og er det noen som vet om noen kommende bærbare modeller med denne plattformen, med et godt grafikkort?
MSI har også en 13,3" på 1,9 kg med Puma - EX310:
Ser ut til å være midt i blinken for meg, med ATI HD3450, HDMI og 2,0 MP cam.
Men: Hvor blir den av? Har AMD leveringsproblemer, eller vil den ikke komme til Norge?
  • 5 uker senere...
