Return problemer i integert variabel
Hallo.
Når jeg prøvde å lage en liten cfg fil gikk alt dårlig.
Dette er koden jeg hadde før
	public int GetCLAttack(int ItemID) {
	if (ItemID == -1) {
		return 1;
	String ItemName = GetItemName(ItemID);
	String ItemName2 = ItemName.replaceAll("Bronze", "");
	ItemName2 = ItemName2.replaceAll("Iron", "");
	ItemName2 = ItemName2.replaceAll("Steel", "");
	ItemName2 = ItemName2.replaceAll("Black", "");
	ItemName2 = ItemName2.replaceAll("Mithril", "");
	ItemName2 = ItemName2.replaceAll("Adamant", "");
	ItemName2 = ItemName2.replaceAll("Rune", "");
	ItemName2 = ItemName2.replaceAll("Granite", "");
	ItemName2 = ItemName2.replaceAll("Dragon", "");
	ItemName2 = ItemName2.replaceAll("Crystal", "");
	ItemName2 = ItemName2.trim();
	if (ItemName2.startsWith("claws")
	 || ItemName2.startsWith("dagger")
	 || ItemName2.startsWith("sword")
	 || ItemName2.startsWith("scimitar")
	 || ItemName2.startsWith("mace")
	 || ItemName2.startsWith("longsword")
	 || ItemName2.startsWith("battleaxe")
	 || ItemName2.startsWith("warhammer")
	 || ItemName2.startsWith("2h sword")
	 || ItemName2.startsWith("harlberd")) {
		if (ItemName.startsWith("Bronze")) {
			return 1;
		} else if (ItemName.startsWith("Iron")) {
			return 1;
		} else if (ItemName.startsWith("Steel")) {
			return 5;
		} else if (ItemName.startsWith("Black")) {
			return 10;
		} else if (ItemName.startsWith("Mithril")) {
			return 20;
		} else if (ItemName.startsWith("Adamant")) {
			return 30;
		} else if (ItemName.startsWith("Rune")) {
			return 40;
		} else if (ItemName.startsWith("Dragon")) {
			return 60;
	} else if (ItemName.startsWith("Granite")) {
		return 50;
	} else if (ItemName.endsWith("whip") || ItemName.endsWith("Ahrims staff") || ItemName.endsWith("Torags hammers") || ItemName.endsWith("Veracs flail") || ItemName.endsWith("Guthans warspear") || ItemName.endsWith("Dharoks greataxe")) {
		return 70;
	return 1;
public int GetCLDefence(int ItemID) {
	if (ItemID == -1) {
		return 1;
		//It's a weapon, weapons don't required defence !
	} else if (ItemName.startsWith("Ahrims") ||  ItemName.startsWith("Karil") || ItemName.startsWith("Torag") || ItemName.startsWith("Verac") || ItemName.endsWith("Guthan") || ItemName.endsWith("Dharok")) {
		if (ItemName.endsWith("staff") || ItemName.endsWith("crossbow") || ItemName.endsWith("hammers") || ItemName.endsWith("flail") || ItemName.endsWith("warspear") || ItemName.endsWith("greataxe")) {
			//No defence for the barrow weapons
		} else {
			return 70;
	} else {
			return 1;
			return 1;
			return 5;
			return 10;
			return 20;
			return 30;
			return 40;
			return 60;
	return 1;
public int GetCLStrength(int ItemID) {
	if (ItemID == -1) {
		return 1;
		return 50;
	} else if (ItemName.startsWith("Torags hammers") || ItemName.endsWith("Dharoks greataxe")) {
		return 70;
	return 1;
public int GetCLMagic(int ItemID) {
	if (ItemID == -1) {
		return 1;
	if (ItemName.startsWith("Ahrim")) {
		return 70;
	return 1;
public int GetCLRanged(int ItemID) {
	if (ItemID == -1) {
		return 1;
	if (ItemName.startsWith("Karil")) {
		return 70;
	if (ItemName.startsWith("Crystal")) {
		return 90;
	return 1;
Jeg endret dette til:
	WieldHandler.GetCLAttack();
	return 1;
	WieldHandler.GetCLDefence();
	return 1;
	WieldHandler.GetCLStrength();
	return 1;
	WieldHandler.GetCLMagic();
	return 1;
	WieldHandler.GetCLRanged();
	return 1;
og lagde en ny *.java fil kallt WieldHandler.java
Inni der er dette:
import java.io.*;
import java.util.StringTokenizer;
public class WieldHandler {
public static String FirstLine;
public static String LastLine;
public static int lvlReq;
public static void GetAttack(int itemID)
	String line = "";
	String token = "";
	String token2 = "";
	String token2_2 = "";
	String[] token3 = new String[5];
	boolean EndOfFile = false;
	int ReadMode = 0;
	BufferedReader characterfile = null;
	try
		characterfile = new BufferedReader(new FileReader("GetAttack.cfg"));
	} catch(FileNotFoundException fileex)
		misc.println("GetAttack.cfg: file not found.");
	try
		line = characterfile.readLine();
	} catch(IOException ioexception)
		misc.println("GetAttack.cfg: error loading file.");
	while(EndOfFile == false && line != null)
		line = line.trim();
		int spot = line.indexOf("=");
		if (spot > -1)
			token = line.substring(0, spot);
			token = token.trim();
			token2 = line.substring(spot + 1);
			token2 = token2.trim();
			token2_2 = token2.replaceAll("\t\t", "\t");
			token2_2 = token2_2.replaceAll("\t\t", "\t");
			token3 = token2_2.split("\t");
			if (token.equals("Item"))
				if (itemID == Integer.parseInt(token3[0]))
					if (Integer.parseInt(token3[1]) != -1)
						FirstLine = (token3[1]);
					else
						FirstLine = "Unknown";
					if (Integer.parseInt(token3[2]) != -1)
						LastLine = (token3[2]);
					else
						LastLine = "Unknown";
					if (Integer.parseInt(token3[3]) != -1)
						lvlReq = Integer.parseInt(token3[3]);
					else
						lvlReq = 1;
		else
			if (line.equals("[EOF]"))
				try
					characterfile.close();
		try
		catch(IOException ioexception1)
			EndOfFile = true;
	try
public static void GetDefence(int itemID)
	String line = "";
	String token = "";
	String token2 = "";
	int ReadMode = 0;
	try
		characterfile = new BufferedReader(new FileReader("GetDefence.cfg"));
		misc.println("GetDefence.cfg: file not found.");
	try
		misc.println("GetDefence.cfg: error loading file.");
		line = line.trim();
		if (spot > -1)
					else
					else
					else
						lvlReq = 1;
		else
				try
		try
			EndOfFile = true;
	try
public static void GetStrength(int itemID)
	String line = "";
	String token = "";
	String token2 = "";
	int ReadMode = 0;
	try
		characterfile = new BufferedReader(new FileReader("GetStrength.cfg"));
		misc.println("GetStrength.cfg: file not found.");
	try
		misc.println("GetStrength.cfg: error loading file.");
		line = line.trim();
		if (spot > -1)
					else
						lvlReq = Integer.parseInt(token3[2]);
					else
						lvlReq = 1;
		else
				try
		try
			EndOfFile = true;
	try
public static void GetMagic(int itemID)
	String line = "";
	String token = "";
	String token2 = "";
	int ReadMode = 0;
	try
		characterfile = new BufferedReader(new FileReader("GetMagic.cfg"));
		misc.println("GetMagic.cfg: file not found.");
	try
		misc.println("GetMagic.cfg: error loading file.");
		line = line.trim();
		if (spot > -1)
					else
					else
						lvlReq = 1;
		else
				try
		try
			EndOfFile = true;
	try
public static void GetRanged(int itemID)
	String line = "";
	String token = "";
	String token2 = "";
	int ReadMode = 0;
	try
		characterfile = new BufferedReader(new FileReader("GetRanged.cfg"));
		misc.println("GetRanged.cfg: file not found.");
	try
		misc.println("GetRanged.cfg: error loading file.");
		line = line.trim();
		if (spot > -1)
					else
					else
						lvlReq = 1;
		else
				try
		try
			EndOfFile = true;
	try
	client c = (client) server.playerHandler.players[ItemID];
	if (ItemID == -1) {
		return 1;
	String ItemName = c.GetItemName(ItemID);
	String ItemName2 = ItemName.replaceAll(FirstLine, "");
	if (ItemName2.startsWith(LastLine)) {
		if (ItemName.startsWith(FirstLine)) {
			return lvlReq;
	return 1;
	if (ItemID == -1) {
		return 1;
		if (ItemName.endsWith(LastLine)) {
			return lvlReq;
	return 1;
	if (ItemID == -1) {
		return 1;
		return lvlReq;
	return 1;
	if (ItemID == -1) {
		return 1;
		return lvlReq;
	return 1;
	if (ItemID == -1) {
		return 1;
		return lvlReq;
	return 1;
Hva har jeg gjort feil?
Håper noen har tid til å svare.
- Marius
Endret av Izzane
før hadde jeg dette:
	if (ItemID == -1) {
		return 1;
		return 50;
		return 70;
	return 1;
i den nye fila har jeg nå dette
	if (ItemID == -1) {
		return 1;
		return lvlReq;
	return 1;
og den gamle koden gjorde jeg bare til dette
	return 1;
Ser du en eller annen feil?
- Marius
Må stille meg på siden til steingrim og si at det er vanskelig å forstå hva du egentlig vil.
Vi vet du har hatt mye kode før, og har kanskje mer, kanskje mindre kode nå. Vi vet ingenting om koden før virket, eller om koden nå fungerer. Langt mindre vet vi hva koden skal.
Så: Vennligst svar på samtlige spørsmål:
  • Hva for et program vil du lage?
  • Hva feiler? Kompilering eller logisk feil? Exceptions? NullPointer?
  • Hvorfor henviser du til gammel kode? Fungerte den? Og i så tilfelle, hvorfor har du byttet den ut?
Jeg skumleste koden din nå, og ble mer forvirret enn før jeg leste den. Hvorfor returnerer alle metodene dine 1? Og du bør vurdere å kommentere metodene dine slik:
/** Gets strength to m and returns it as an integer
* @param m the mage to find strength
* @return the mage's strength
public int getStrength(Mage m) {
  return m.getStrength();
Denne havner på min topp-10 liste over elendige feilbeskrivelser i denne gruppa. Dessuten gikk musehjulet mitt en smule varmt pga all scrollingen som måtte til for å finne reply-knappen.
Les forumregler, og kom tilbake når du har lært deg god forumskikk.
Werner
Cut him some slack! Han prøvde jo tross alt bare å lage en liten cfg-fil, men alt gikk dårlig.
