stian90_2 Skrevet 7. februar 2008 Forfatter Skrevet 7. februar 2008 (endret) Her er den nye xorg.conf filen som ble laget Section "ServerLayout" Identifier "X.org Configured" Screen 0 "Screen0" 0 0 InputDevice "Mouse0" "CorePointer" InputDevice "Keyboard0" "CoreKeyboard" EndSection Section "Files" RgbPath "/usr/share/X11/rgb" ModulePath "/usr/lib/xorg/modules" FontPath "/usr/share/fonts/misc" FontPath "/usr/share/fonts/100dpi:unscaled" FontPath "/usr/share/fonts/75dpi:unscaled" FontPath "/usr/share/fonts/TTF" FontPath "/usr/share/fonts/Type1" EndSection Section "Module" Load "extmod" Load "dbe" Load "record" Load "GLcore" Load "dri" Load "xtrap" Load "glx" Load "freetype" EndSection Section "InputDevice" Identifier "Keyboard0" Driver "kbd" EndSection Section "InputDevice" Identifier "Mouse0" Driver "mouse" Option "Protocol" "auto" Option "Device" "/dev/input/mice" Option "ZAxisMapping" "4 5 6 7" EndSection Section "Monitor" #DisplaySize 340 270 # mm Identifier "Monitor0" VendorName "JEN" ModelName "JT178x1" ### Comment all HorizSync and VertRefresh values to use DDC: HorizSync 30.0 - 83.0 VertRefresh 50.0 - 75.0 Option "DPMS" EndSection Section "Device" ### Available Driver options are:- ### Values: <i>: integer, <f>: float, <bool>: "True"/"False", ### <string>: "String", <freq>: "<f> Hz/kHz/MHz" ### [arg]: arg optional #Option "NoAccel" # [<bool>] #Option "SWcursor" # [<bool>] #Option "ColorKey" # <i> #Option "CacheLines" # <i> #Option "Dac6Bit" # [<bool>] #Option "DRI" # [<bool>] #Option "NoDDC" # [<bool>] #Option "ShowCache" # [<bool>] #Option "XvMCSurfaces" # <i> #Option "PageFlip" # [<bool>] Identifier "Card0" Driver "i810" VendorName "Intel Corporation" BoardName "82815 Chipset Graphics Controller (CGC)" BusID "PCI:0:2:0" EndSection Section "Screen" Identifier "Screen0" Device "Card0" Monitor "Monitor0" SubSection "Display" Viewport 0 0 Depth 1 EndSubSection SubSection "Display" Viewport 0 0 Depth 4 EndSubSection SubSection "Display" Viewport 0 0 Depth 8 EndSubSection SubSection "Display" Viewport 0 0 Depth 15 EndSubSection SubSection "Display" Viewport 0 0 Depth 16 EndSubSection SubSection "Display" Viewport 0 0 Depth 24 EndSubSection EndSection Endret 7. februar 2008 av stianiquniez
stian90_2 Skrevet 1. mars 2008 Forfatter Skrevet 1. mars 2008 Jeg ga opp og prøve på den gammle pentiumenen, så jeg testa det ut på laptopen.. Her får jeg ikke opp "gnome-session" samme feil som tidligere ? :S Men jeg kan bruke "startx" da får jeg opp en stor X som pus, og et svart vindu, og noen ganger starter gnome i noe som kalles xterm eller noe, det ser ikke akuratt så bra ut. Noe forslag ?
rocknrolf77 Skrevet 1. mars 2008 Skrevet 1. mars 2008 Har du installert gdm? Hvis ikke kan du jo installere og starte gdm ved å rett og slett skrive gdm som root. Eller legge til gdm under daemons i /etc/rc.conf
stian90_2 Skrevet 1. mars 2008 Forfatter Skrevet 1. mars 2008 gdm er innstalert, prøvde og starte gdm men kommer ikke langt, kommer opp en error der det står "The greeter application appears to be crashing. Attempting to use a diffrent one."
rocknrolf77 Skrevet 2. mars 2008 Skrevet 2. mars 2008 Prøv etter å ha installert disse pakkene : xf86-input-keyboard, fx86-input-mouse og xf86-video-vesa.
DevilsDecoy Skrevet 2. mars 2008 Skrevet 2. mars 2008 Hver gang jeg har fått den feilen er det fordi /tmp ikke har riktige rettigheter. Hvis det rocknrolf sa ikke fungerer, sjekk /tmp: $ ls -l / drwxrwxrwt 14 root root 4096 2008-03-02 11:49 tmp Hvis den første delen mangler noen bokstaver er det nok det som er problemet, chmod a=rwx /tmp bør fikse det
