Takler denne pcen crysis på graphic high/very high?
Denne?
PC 1:
Hovudkort:
XFX nForce-650i Ultra Socket 775
LGA775/DDR2/PCIe/GB LAN/SATAII
Prosessor (CPU):
Intel Core 2 Duo E6850 3.0GHz, 1333FSB
4MB cache, 1333MHz FSB, 65nm, S775
Prosessorkjøler:
Zalman CNPS9700 NT CPU Kjøler
Ultra Quiet, Socket 775,754,939,940,AM2
OCZ Freeze Extreme Kjølepasta
Non-silver compound, ikke ledende
Minne (RAM):
OCZ Gold XTC 4096MB (4GB RAM) DDR2 PC6400 KIT
2048MB x 2, 800MHz, CL5, "5-5-5-18"
Kabinett:
Apevia X-Plorer Midi Tower m/sidevindu
ATX, Uten power, 2x80mm vifte, SORT
Harddisk:
Samsung SpinPoint 500GB 3.5" SATA2
SATA2, 7200 RPM, 16MB cache
CD /DVD-ROM:
NEC AD-7170S DVD±RW 18x - SATA
Intern, Sort, Bulk
Skjermkort:
XFX GeForce 7600GS 256MB Skjermkort
DDR2, PCI-Express, HDMI/DVI/HDTV/HDCP
Tastatur/Mus:
Logitech Cordless Wave Desktop
Sort
Skjerm:
HP Pavilion W1907 19" wide TFT Monitor
Analog/Speaker/Silver/5ms/TCO-03
Strømforsyning:
OCZ 600W GameXStream Strømforsyning
20+4+8pin, 115-230v, PowerWhisper
Nettverkskort:
D-Link Rangebooster PCI kort
Draft 802.11n, 3 antenner
Høytalere:
Logitech X-530 5.1 høyttalersystem
Sort, 5 satelitt +subwoofer, 70W RMS
EDIT:
Eller denne?
PC 2:
Hovedkort:
Asus P5K, P35, Socket-775, DDR2, ATX, GbLAN, PCI-Ex16
Prosessor:
Intel Core 2 Duo E6850 3.0GHz 1333Mhz Socket LGA775, 4MB, BOXED m/vifte
Minne:
Kingston ValueR. DDR2 PC5300 4096MB CL5, Kit w/two matched ValueRAM 2048MB DDR2
Kabinett:
Cooler Master Centurion 534, Sort, Aluminium Front (Uten Strømforsyning)
Harddisk:
Seagate Barracuda 7200.10 500GB SATA2 16MB 7200RPM
CD/DVD-ROM:
NEC DVD-brenner AD-5170 IDE White OEM DVD+R/+RW/DVD-R/-RW (Dual layer)
Skjermkort:
XFX GeForce 8800GTS 650M 512MB GDDR3, PCI-Express 2.0, 2xDVI/HDTV/HDCP,650Mhz
Tastatur:
Microsoft Wired Keyboard 500, PS/2
Mus:
Microsoft IntelliMouse Explorer 3.0 PS2/USB
Skjerm:
LG 19" LCD L194WT TCO-03, Silver 1440x900, 5ms, 2000:1, DVI/VGA
Endret av SSSeeevvviii
Er det 1 ting som er sikkert, så er det det at du ikke bør spare på kruttet når det kommer til skjermkort... Hva med å gå ned til en Q6600 eller en E6600 og et 8800GT/GTS/GTX kort?
Lol, den greier nok ikke Crysis på no bedre enn Low med det grafikkkortet:p
Med det skjermkortet klarer du kanskje cs med alt på high ;D
det grafikkkortet er ikke så elendig men det holder ikke til high
mitt 7950GX2 holder akkurat til high
