haffi Skrevet 2. august 2007 Skrevet 2. august 2007 (endret) Need for speed carbon virker ikke, når jeg åpner det kommer dette. Hva skal jeg gjøre!? Endret 2. august 2007 av haffi
BigJaffa Skrevet 2. august 2007 Skrevet 2. august 2007 Prøv den øverste du. Vist det ikkje virker kan du prøve å instalere det på nytt...
-sparks- Skrevet 2. august 2007 Skrevet 2. august 2007 (endret) Gi oss flere detaljer, hvor intreffer feilen, hva maskinvare har du, har du oppdatert grafikkortdriverne, har du oppdatert spillet osv osv.... Her er hva EA sier om carbon+vista: The unpatched PC version of the game has compatibility issues when playing under Windows Vista and crashes after the EA Logo screen, although most issues have been resolved in patch version 1.4. According to EA's Website Support page,[7] they have not released any games that are supported under Windows Vista and suggest changing the compatibility mode to play EA games if necessary. In versions prior to 1.4, the game will load with both 32 bit and 64 bit editions of Windows Vista if the compatibility mode is changed to either Windows 98 or 95. However, the game still crashes frequently. Deleting or renaming the MOVIES folder, however, alleviates the problem. This has also been linked to the 1.3 upgrade patch. Some users have also successfully run the game out of the box on Vista 32-Bit RTM, suggesting that the issue may have been related to issues in Vista's pre-release code. In version 1.4 of the game these conflicts with Windows Vista are solved, according to EA.[8] Prøv å laste ned denne 1.4 patchen og se om det løser problemene dine: http://www.gamershell.com/download_19592.shtml Endret 2. august 2007 av -sparks-
