NMI Index Store Svr.exe
Får opp beskjed om at et eller annet program ikke fungerer og må lukkes, NMIIndexStoreSvr.exe? Hva er dette? Kan noen hjelpe meg?
Trond :hmm:
Trond :hmm:
9097857[/snapback]
Har du Nero? Isåfall så ta en titt her å se om det kan hjelpe deg :)
EDIT: Sakser dette fra linken jeg skrev så du slipper å lete ;)
I finally got an answer from Nero on this problem, I haven't tried it yet, but I thought I would pass it along to you...
There are two possibilities to fix this problem:
1.)
Please rename the file NMIndexStoreSvr.exe to NMIndexStoreSvr.old.
Afterwards reboot your system.
2.)
Disable Nero Scout.
Open Windows Explorer, click on 'My Computer' to display the program, and select Nero Scout. Press the right mouse button to open the context menu and select the 'Options' command.
Check the 'Disable Nero Scout' box to deactivate the database functionality of Nero Scout.
Click on 'Exit' to save settings and close the window.
Restart your PC.
If you have any further questions, please don't hesitate to contact us again.
Endret av generalbjartish
