dette å få til all lyden? hvordan?
jeg tok å instalerte amxmodx en gang til på Dedicated servers og nå etter jeg hadde lastet ned noen pluggins komm det bare slik :
L 07/06/2007 - 20:53:48: -------- Mapchange to cs_italy --------
L 07/06/2007 - 20:53:49: [AMXX] Plugin file open error (plugin "connect_sound.amxx")
L 07/06/2007 - 20:53:49: [AMXX] Plugin file open error (plugin "sound_download_management.amxx")
L 07/06/2007 - 20:53:49: [AMXX] Plugin file open error (plugin "dod_humiliation.amxx")
L 07/06/2007 - 20:53:49: [AMXX] Plugin file open error (plugin "advanced_damage_report.amxx")
L 07/06/2007 - 20:53:49: [AMXX] Plugin file open error (plugin "ultimate_sound.amxx")
L 07/06/2007 - 20:53:49: [AMXX] Plugin file open error (plugin "sound_files_upload.amxx")
L 07/06/2007 - 20:53:49: [AMXX] Plugin file open error (plugin "live_damage_report.amxx")
L 07/06/2007 - 20:53:49: [AMXX] Plugin file open error (plugin "firstblood.amxx")
L 07/06/2007 - 20:53:49: [AMXX] Plugin file open error (plugin "countdown.amxx")
L 07/06/2007 - 20:53:49: [AMXX] Plugin file open error (plugin "multikill.amxx")
L 07/06/2007 - 20:53:49: [AMXX] Plugin file open error (plugin "camper_detector.amxx")
L 07/06/2007 - 20:53:49: [AMXX] Plugin file open error (plugin "mp3.amxx")
L 07/06/2007 - 20:53:49: [AMXX] Plugin file open error (plugin "high_ping_kicker.amxx")
L 07/06/2007 - 20:53:49: [AMXX] Plugin file open error (plugin "headshot_deluxe.amxx")
[AMXX] Loaded 1 admin from file
L 07/06/2007 - 20:53:49: [nextmap.amxx] WARNING: Couldn't find a valid map or the file doesn't exist (file "mapcycle.txt")
Executing AMX Mod X Configuration File
Scrolling message displaying frequency: 10:00 minutes
hvordan få plugins til å virke? kan noen gi meg et svar og si meg hvordan?
Du har nok noen feil i modules.ini - lim inn den òg, så ser jeg kanskje feilen. :]
9018659[/snapback]
; AMX Mod X plugins
; Admin Base - Always one has to be activated
admin.amxx ; admin base (required for any admin-related)
;admin_sql.amxx ; admin base - SQL version (comment admin.amxx)
; Basic
admincmd.amxx ; basic admin console commands
adminhelp.amxx ; help command for admin console commands
adminslots.amxx ; slot reservation
multilingual.amxx ; Multi-Lingual management
; Menus
menufront.amxx ; front-end for admin menus
cmdmenu.amxx ; command menu (speech, settings)
plmenu.amxx ; players menu (kick, ban, client cmds.)
;telemenu.amxx ; teleport menu (Fun Module required!)
mapsmenu.amxx ; maps menu (vote, changelevel)
; Chat / Messages
adminchat.amxx ; console chat commands
antiflood.amxx ; prevent clients from chat-flooding the server
scrollmsg.amxx ; displays a scrolling message
imessage.amxx ; displays information messages
adminvote.amxx ; vote commands
; Map related
nextmap.amxx ; displays next map in mapcycle
mapchooser.amxx ; allows to vote for next map
timeleft.amxx ; displays time left on map
; Configuration
pausecfg.amxx ; allows to pause and unpause some plugins
statscfg.amxx ; allows to manage stats plugins via menu and commands
; Counter-Strike
;restmenu.amxx ; restrict weapons menu
statsx.amxx ; stats on death or round end (CSX Module required!)
;miscstats.amxx ; bunch of events announcement for Counter-Strike
;stats_logging.amxx ; weapons stats logging (CSX Module required!)
; Enable to use AMX Mod plugins
amxmod_compat.amxx ; AMX Mod backwards compatibility layer
; Custom - Add 3rd party plugins here
connect_sound.amxx
ultimate_sound.amxx
firstblood.amxx
countdown.amxx
multikill.amxx
mp3.amxx
anticamping.amxx
search_maps_plugin.amxx
welcome_hudmsg.amxx
soundcheck.amxx
;streak_mode ab
;bomb_mode abcdefghi
;hekill_mode abcd
;kniff_mode abc
;hs_mode ab
;lastman_mode abc
dette er det siste jeg har fått nå når jeg har ordna littegrand :
L 07/06/2007 - 23:38:25: -------- Mapchange to cs_assault --------
L 07/06/2007 - 23:38:25: [AMXX] Plugin file open error (plugin "sound_download_management.amxx")
L 07/06/2007 - 23:38:26: [nextmap.amxx] WARNING: Couldn't find a valid map or the file doesn't exist (file "mapcycle.txt")
L 07/06/2007 - 23:38:26: This usage of the native pause() has been deprecated!
L 07/06/2007 - 23:38:26: [AMXX] Run time error 10 (plugin "firstblood.amxx") (native "pause") - debug not enabled!
L 07/06/2007 - 23:38:26: [AMXX] To enable debug mode, add "debug" after the plugin name in plugins.ini (without quotes).
[AMXX] SQL error: can't connect: 'Can't connect to MySQL server on '127.0.0.1' (10061)'
vet du hvordan jeg får for eks. mp3 til å virke.....få inn alle slike småe lyder? slik som hedshot og mye diverse?......d hadde vert supert om du kunne ha hjulpet/guidet meg gjennom denne vanskelige fasen :p
først :
L 07/07/2007 - 00:08:39: [AMXX] Run time error 10 (plugin "firstblood.amxx") (native "pause") - debug not enabled!
L 07/07/2007 - 00:08:39: [AMXX] To enable debug mode, add "debug" after the plugin name in plugins.ini (without quotes).
etter:
L 07/07/2007 - 00:11:00: [AMXX] Plugin needs newer debug version info (plugin "firstblood.amxx")
jeg blir snart frustrert
Guider om CS er vel ikke egentlig veldig vanskelig å finne på nettet. Prøv Google, eller et CS-forum.
9019735[/snapback]
ja kansje d......men er ikke mye du finner til å få lyder på dedicated servers og på når du tar new game på cs 1.6......jeg vil ha lyd...masse kule lyder og mye annet
men d er noe jeg ikke får til :hrm::nei::no:
Emnetittelen i denne tråden er lite beskrivende for trådens innhold og det er derfor ingen god emnetittel. Jo bedre og mer beskrivende emnetittelen er, jo lettere er det for andre å skjønne trådens innhold og det vil være lettere å treffe den riktige forumbrukeren med det rette svaret. Ber deg derfor om å endre emnetittel slik at du unngår at en moderator stenger tråden. Vennligst forsøk å ha dette i tankene neste gang du starter en tråd, og orienter deg om hva vår nettikette sier om dårlig bruk av emnetitler.
Bruk p_edit.gif-knappen i første post for å endre emnetittelen.
(Dette innlegget vil bli fjernet ved endring av emnetittel. Ikke kommenter dette innlegget, men p_report.gif gjerne dette innlegget når tittelen er endret, så vil det bli fjernet..)
jeg sjønte ikke helt d der med re-complite :no:
jeg har ikke en mappe som heter examples....og det var ett bilde som ikke komm opp.....
jeg er såpass dumm at jeg trenger ganske god hjelp :hrm:
