Trenger virkelig hjelp på dedicated servers
jeg har Maxmodx å d......men d er en liste som kommer når jeg har prøv meg fram og skal starte server....og den er slik:
L 07/06/2007 - 17:39:40: -------- Mapchange to cs_assault --------
L 07/06/2007 - 17:39:41: [AMXX] Plugin file open error (plugin "Map")
L 07/06/2007 - 17:39:41: [AMXX] Plugin file open error (plugin "Enable")
L 07/06/2007 - 17:39:41: [AMXX] Plugin file open error (plugin "amxmod_compat.amxx")
L 07/06/2007 - 17:39:41: [AMXX] Plugin file open error (plugin "Custom")
L 07/06/2007 - 17:39:41: [AMXX] Plugin needs newer debug version info (plugin "firstblood.amx")
L 07/06/2007 - 17:39:41: [AMXX] Plugin needs newer debug version info (plugin "bullet_damage.amx")
L 07/06/2007 - 17:39:41: [AMXX] Plugin needs newer debug version info (plugin "countdown.amx")
L 07/06/2007 - 17:39:41: [AMXX] Plugin needs newer debug version info (plugin "bomb_events.amx")
L 07/06/2007 - 17:39:41: [AMXX] Plugin needs newer debug version info (plugin "camper_detector.amx")
L 07/06/2007 - 17:39:41: [AMXX] Plugin needs newer debug version info (plugin "dod_admin_menu.amx")
L 07/06/2007 - 17:39:41: [AMXX] Plugin needs newer debug version info (plugin "dod_humiliation.amx")
L 07/06/2007 - 17:39:41: [AMXX] Plugin needs newer debug version info (plugin "headshot_deluxe.amx")
L 07/06/2007 - 17:39:41: [AMXX] Plugin needs newer debug version info (plugin "high_ping_kicker.amx")
L 07/06/2007 - 17:39:41: [AMXX] Plugin needs newer debug version info (plugin "tfc_admin_plugin.amx")
L 07/06/2007 - 17:39:41: [AMXX] Plugin needs newer debug version info (plugin "dod_tk_manager.amx")
L 07/06/2007 - 17:39:41: [AMXX] Plugin needs newer debug version info (plugin "ut_sounds.amx")
L 07/06/2007 - 17:39:41: [AMXX] Plugin needs newer debug version info (plugin "ut_killing_spree.amx")
L 07/06/2007 - 17:39:41: [AMXX] Plugin needs newer debug version info (plugin "map_extend_vote.amx")
L 07/06/2007 - 17:39:41: [AMXX] Plugin needs newer debug version info (plugin "list_maps.amx")
L 07/06/2007 - 17:39:41: [AMXX] Plugin file open error (plugin "csdm_main.amxx")
L 07/06/2007 - 17:39:41: [AMXX] Plugin file open error (plugin "csdm_equip.amxx")
L 07/06/2007 - 17:39:41: [AMXX] Plugin file open error (plugin "csdm_spawn_preset.amxx")
L 07/06/2007 - 17:39:41: [AMXX] Plugin file open error (plugin "spawn_editor.amxx")
L 07/06/2007 - 17:39:41: [AMXX] Plugin file open error (plugin "csdm_misc.amxx")
L 07/06/2007 - 17:39:41: [AMXX] Plugin file open error (plugin "csdm_protection.amxx")
L 07/06/2007 - 17:39:41: [AMXX] Plugin file open error (plugin "csdm_ffa.amxx")
L 07/06/2007 - 17:42:46: -------- Mapchange to cs_backalley --------
L 07/06/2007 - 17:42:46: [AMXX] Plugin file open error (plugin "Map")
L 07/06/2007 - 17:42:46: [AMXX] Plugin file open error (plugin "Enable")
L 07/06/2007 - 17:42:46: [AMXX] Plugin file open error (plugin "amxmod_compat.amxx")
L 07/06/2007 - 17:42:46: [AMXX] Plugin file open error (plugin "Custom")
L 07/06/2007 - 17:42:46: [AMXX] Plugin file open error (plugin "csdm_main.amxx")
L 07/06/2007 - 17:42:46: [AMXX] Plugin file open error (plugin "csdm_equip.amxx")
L 07/06/2007 - 17:42:46: [AMXX] Plugin file open error (plugin "csdm_spawn_preset.amxx")
L 07/06/2007 - 17:42:46: [AMXX] Plugin file open error (plugin "spawn_editor.amxx")
L 07/06/2007 - 17:42:46: [AMXX] Plugin file open error (plugin "csdm_misc.amxx")
L 07/06/2007 - 17:42:46: [AMXX] Plugin file open error (plugin "csdm_protection.amxx")
L 07/06/2007 - 17:42:46: [AMXX] Plugin file open error (plugin "csdm_ffa.amxx")
L 07/06/2007 - 17:42:46: [AMXX] Plugin "headshot_deluxe.amx" failed to load: Plugin uses an unknown function (name "get_user_wstats") - check your modules.ini.
L 07/06/2007 - 17:42:47: This usage of the native pause() has been deprecated!
L 07/06/2007 - 17:42:47: [AMXX] Run time error 10 (plugin "firstblood.amx") (native "pause") - debug not enabled!
L 07/06/2007 - 17:42:47: [AMXX] To enable debug mode, add "debug" after the plugin name in plugins.ini (without quotes).
L 07/06/2007 - 17:42:47: Invalid event (name "RoundState") (plugin "dod_tk_manager.amx")
L 07/06/2007 - 17:42:47: [AMXX] Run time error 10 (plugin "dod_tk_manager.amx") (native "register_event") - debug not enabled!
couldn't exec addons/amx/menu.cfg
] amx_menu
L 07/06/2007 - 17:46:56: -------- Mapchange to cs_assault --------
L 07/06/2007 - 17:46:56: [GEOIP] Database info: GEO-106FREE 20060901 Build 1 Copyright © 2006 MaxMind LLC All Rights Reserved
L 07/06/2007 - 17:46:56: [AMXX] Plugin file open error (plugin "Map")
L 07/06/2007 - 17:46:56: [AMXX] Plugin file open error (plugin "Enable")
L 07/06/2007 - 17:46:56: [AMXX] Plugin file open error (plugin "amxmod_compat.amxx")
L 07/06/2007 - 17:46:56: [AMXX] Plugin file open error (plugin "Custom")
L 07/06/2007 - 17:46:56: [AMXX] Plugin needs newer debug version info (plugin "firstblood.amx")
L 07/06/2007 - 17:46:56: [AMXX] Plugin file open error (plugin "csdm_main.amxx")
L 07/06/2007 - 17:46:56: [AMXX] Plugin file open error (plugin "csdm_equip.amxx")
L 07/06/2007 - 17:46:56: [AMXX] Plugin file open error (plugin "csdm_spawn_preset.amxx")
L 07/06/2007 - 17:46:56: [AMXX] Plugin file open error (plugin "spawn_editor.amxx")
L 07/06/2007 - 17:46:56: [AMXX] Plugin file open error (plugin "csdm_misc.amxx")
L 07/06/2007 - 17:46:56: [AMXX] Plugin file open error (plugin "csdm_protection.amxx")
L 07/06/2007 - 17:46:56: [AMXX] Plugin file open error (plugin "csdm_ffa.amxx")
L 07/06/2007 - 17:46:56: [AMXX] Plugin "headshot_deluxe.amx" failed to load: Plugin uses an unknown function (name "get_user_wstats") - check your modules.ini.
L 07/06/2007 - 17:46:57: This usage of the native pause() has been deprecated!
L 07/06/2007 - 17:46:57: [AMXX] Run time error 10 (plugin "firstblood.amx") (native "pause") - debug not enabled!
L 07/06/2007 - 17:46:57: [AMXX] To enable debug mode, add "debug" after the plugin name in plugins.ini (without quotes).
L 07/06/2007 - 17:46:57: Invalid event (name "RoundState") (plugin "dod_tk_manager.amx")
L 07/06/2007 - 17:46:57: [AMXX] Run time error 10 (plugin "dod_tk_manager.amx") (native "register_event") - debug not enabled!
L 07/06/2007 - 17:49:54: -------- Mapchange to de_dust --------
L 07/06/2007 - 17:49:54: [AMXX] Plugin file open error (plugin "AMX")
L 07/06/2007 - 17:49:54: [AMXX] Plugin file open error (plugin "Admin")
L 07/06/2007 - 17:49:54: [AMXX] Plugin file open error (plugin "Basic")
L 07/06/2007 - 17:49:54: [AMXX] Plugin file open error (plugin "Menus")
L 07/06/2007 - 17:49:54: [AMXX] Plugin file open error (plugin "Chat")
L 07/06/2007 - 17:49:54: [AMXX] Plugin file open error (plugin "Map")
L 07/06/2007 - 17:49:54: [AMXX] Plugin file open error (plugin "Configuration")
L 07/06/2007 - 17:49:54: [AMXX] Plugin file open error (plugin "Enable")
L 07/06/2007 - 17:49:54: [AMXX] Plugin file open error (plugin "Custom")
L 07/06/2007 - 17:49:54: [AMXX] Plugin needs newer debug version info (plugin "firstblood.amx")
L 07/06/2007 - 17:49:54: [AMXX] Plugin file open error (plugin "csdm_main.amxx")
L 07/06/2007 - 17:49:54: [AMXX] Plugin file open error (plugin "csdm_equip.amxx")
L 07/06/2007 - 17:49:54: [AMXX] Plugin file open error (plugin "csdm_spawn_preset.amxx")
L 07/06/2007 - 17:49:54: [AMXX] Plugin file open error (plugin "spawn_editor.amxx")
L 07/06/2007 - 17:49:54: [AMXX] Plugin file open error (plugin "csdm_misc.amxx")
L 07/06/2007 - 17:49:54: [AMXX] Plugin file open error (plugin "csdm_protection.amxx")
L 07/06/2007 - 17:49:54: [AMXX] Plugin file open error (plugin "csdm_ffa.amxx")
L 07/06/2007 - 17:49:54: [AMXX] Plugin "headshot_deluxe.amx" failed to load: Plugin uses an unknown function (name "get_user_wstats") - check your modules.ini.
[AMXX] Loaded 0 admins from file
L 07/06/2007 - 17:49:56: [nextmap.amx] WARNING: Couldn't find a valid map or the file doesn't exist (file "mapcycle.txt")
L 07/06/2007 - 17:49:56: This usage of the native pause() has been deprecated!
L 07/06/2007 - 17:49:56: [AMXX] Run time error 10 (plugin "firstblood.amx") (native "pause") - debug not enabled!
L 07/06/2007 - 17:49:56: [AMXX] To enable debug mode, add "debug" after the plugin name in plugins.ini (without quotes).
L 07/06/2007 - 17:49:56: Invalid event (name "RoundState") (plugin "dod_tk_manager.amx")
L 07/06/2007 - 17:49:56: [AMXX] Run time error 10 (plugin "dod_tk_manager.amx") (native "register_event") - debug not enabled!
Executing AMX Mod X Configuration File
Scrolling message displaying frequency: 10:00 minutes
[AMXX] SQL error: can't connect: 'Can't connect to MySQL server on '127.0.0.1' (10061)'
kann noen vere så snill å si meg hva jeg skal gjøre
jeg har sittet i 3 dager nå å :hmm: men er like :hrm::nei: som første dagen jeg fikk det
kan noen vere så snill å si meg hva jeg skal gjøre og hvordan
jeg ska vente tolmodig på et svar :ermm:
Gjest
