Kopi av den nye patchen
Er på jobb innesperret av brannmurer.
Er det noen som kunne tatt en kopi/paste av den nye patchnotes og limt inn her, så jeg har litt å lese på :)
Takk for hjelpen.
Gjest Slettet-p4PIYwb6
Vær så god. :)
Klikk for å se/fjerne innholdet nedenfor
The Black Temple
The Temple of Karabor was the center of draenei worship until its priests were slaughtered by demonically corrupted orcs. In the massacre's aftermath the warlocks of the Shadow Council seized the structure and gave it a new name: the Black Temple.
When the Alliance invaded Draenor after the Second War, the orc shaman Ner'zhul hastily opened several dimensional portals in order to escape. The resulting magical backlash ripped the world apart. Drawn by these portals, the pit lord Magtheridon arrived in what had come to be known as Outland and took the temple as his seat of power.
His dominion over Outland remained unchallenged until the arrival of Illidan the Betrayer. The pit lord proved no match for the wielder of the Twin Blades of Azzinoth. Today Illidan occupies the temple, awaiting any and all who would challenge his rule.
Druid Epic Flight Form Introduced
The Druid Epic flight form will be available through a series of quests, similar to the Warlock and Paladin Epic mount quests before it. This quest series will also open up a new boss in Sethekk Halls, and ultimately lead to the epic flight form.
Ethereum Prison
Players in good standing with the Consortium will be tasked to deal with the most recent activities of the nefarious Ethereum. With new quests, items, and content for the solo and small-group level 70 player, the Ethereum Prison will be the proving grounds for many aspiring to greatness.
Skettis
The Skyguard, Sha’tari warriors specializing in their command of the skies above Shattrath, have taken the offensive directly to the Arakkoa capital city, Skettis. Perched high in the mountains of Terrokar, and only accessible with use of a flying mount, Skettis holds new and exciting content for the solo or small-group level 70 player. All new quests, 5-person bosses, rare and epic items, and a new type of flying mount await those willing to lend their sword or stave to the battle.
Nether Drake
The Netherwing faction and quest line continues and the long awaited Nether Drake becomes available. The Nether Drake is a special 280% speed epic flying mount that is obtainable through solo and small-group play. The quest to obtain one will be difficult, but the reward will surely show your dedication to the Netherwing cause as you soar through the skies of Outland on your very own ethereal drake.
Ogri’la
The ogre plateau of enlightenment opens to those who prove their worth in Blade’s Edge Mountains. Level 70 players will be able to help the ogres of Ogri’la battle invading forces and engage in new and exciting quests, such as a repeatable and ever popular bombing-run, this time using your own flying mount but with a dangerous twist! Featuring tons of new quests, the Ogri’la faction, 5-person bosses, and rare and epic items, Ogri’la is a place we’re hoping all will aspire to enter.
The Ruins of Lordaeron Arena
For those combatants engaging in the Steamwheedle Cartel’s gladiatorial combat, an arena nestled within the Ruins of Lordaeron has been added to the mix of venues. Players taking part in either rated battles or skirmishes may now find themselves battling for glory within the new arena.
General
* The Black Temple is now available for play and Illidan awaits. Are you prepared?
* The Consortium and Protectorate need your help! Players with Honored or higher reputation with the Consortium should seek out Protectorate Advisor Rahim at the Stormspire in Netherstorm or Commander Ameer at the Protectorate Watch Post in Netherstorm to get a briefing on the most recent nefarious activities of the Ethereum.
* Skettis is now available. Players will need a flying mount to reach this new area.
* Nether Drakes are now in the game and can be gained by continuing the Netherwing faction and quest line.
* Ogri'la is now available. Level 70 players can find this new quest line in Blade's Edge Mountains.
* Glancing Blows have significantly less of a chance to occur during a player’s melee attacks when targets are near the player’s level.
* Magtheridon and Kael'thas now drop items that may be turned in for rewards.
* Spell Haste: The amount of spell haste rating needed per percentage of haste has been increased substantially. However, spell haste will now affect channeled spells, increasing the rate of their effects and decreasing their total duration. The same amount of damage/healing per casting will occur, but will take less time.
* Chance to break crowd control from damage: The increased chance for a spell to break from taking a critical strike has been removed. Instead, all targets over level 60 have a slightly larger chance to break out of crowd-controlling effects when they take damage.
* Screenshots captured using the Print Screen key are now saved in JPG format.
* Inspect distance has been increased to 30 yards (from 10 yards).
* The amount of parry rating needed to get 1% parry has been reduced by 25%.
* Many set bonuses did not work properly when combined with an item or enchantment that had the exact same effect at the exact same magnitude. That issue has been corrected on all set bonuses.
* Taunts: The taunt system has been adjusted so that Warrior Taunt, Druid Growl, and Paladin Righteous Defense will now grant the player the correct amount of threat even when the creature or its target is crowd controlled.
* Dodge Rating: Low level players now calculate dodge from dodge rating at the same rate as level 34 players.
PvP
* Arenas
o The Ruins of Lordaeron Arena is now available for play.
o The Shadow Sight buff now allows players to see other stealthed players at a greater range.
* Battlegrounds
o The new battleground matchmaking system is now implemented and active. This system allows the battleground to select teams of similar equipment quality and organizational level to battle each other. For now, the system will be very forgiving about creating matchups in order to keep queue times low. However, the parameters will be adjusted as necessary when more organized teams become active in the battlegrounds.
Druids
* The Druid Epic Flight Form is now available through a series of quests.
* Barkskin now reduces all damage taken, with its duration reduced to 12 seconds and cooldown reduced to 1 minute. The tooltip has been adjusted to indicate this ability can be used while frozen, incapacitated, or cowering in fear. That functionality was already present, but not listed in the tooltip.
* Bear Form and Dire Bear Form: The bonus health from shapeshifting into these forms will again be removed correctly when shifting out of these forms.
* Bestial Wrath: The immunity granted by thtis ability now lasts the full duration of the ability. Bestial Wrath now grants immunity to Cyclone. Cyclone will no longer prevent the immunities from being granted.
* Celestial Focus: The delay on the stun effect for Starfire has been reduced.
* Cyclone: This ability will no longer work on hunters with The Beast Within active or hunter pets with Bestial Wrath active.
* Feral Charge now suppresses all Slowing effects while charging the target.
* Fixed a data error that caused Swiftmend to generate more threat than intended.
* Force of Nature: These pets will now come into the game with full health, including that gained from a percentage of their master's stamina.
* Force of Nature: The Treants summoned by this spell will now correctly attack your target even if it is neutral or non-aggressive.
* Gift of the Wild, ranks 1 and 2, are now available on trainers.
* Gift of the Wild: Rank 3 of this ability now has the same range as ranks 1 and 2.
* Improved Leader of the Pack: This ability will no longer generate threat.
* Lacerate: The tooltip has been adjusted to indicate it does initial bleed damage when the ability first lands.
* Lifebloom: Each additional application of this spell will now include the full bonus from effects which increase healing. The final heal, however, is still unaffected by stacking multiple applications of this spell.
* Mangle(Bear): Damage increased by 15%, but bonus threat reduced so that overall threat generation will be unchanged.
* Nature's Grace: This talent is now triggered by Swiftmend and Lifebloom, and is triggered by and affects Cyclone.
* Nature's Grasp: The mana cost has been removed from all ranks as intended.
* Omen of Clarity: This spell is no longer castable in Tree of Life Form or Moonkin Form.
* Prowl will now be broken correctly by damage shields such as Oil of Immolation.
* Rake: The tooltip has been adjusted to indicate the initial damage done is bleed damage. In addition, Rake can now always be re-applied, even when Mangle is active.
* Shapeshifting will no longer remove the Rotting Putrescence creature debuff.
* Subtlety(Restoration Talent) now applies to all spells, not just healing spells.
* Swiftmend: This ability will now be correctly penalized for casting low rank Rejuvenations and Regrowths just as other healing spells are penalized.
* Swiftmend: The button for this ability will now be greyed out when your current target does not have Rejuvenation or Regrowth.
* Teleport: Moonglade: This spell is no longer castable in Tree of Life Form.
* Tree of Life Form: The tooltip has been corrected to indicate Nature's Swiftness and Rebirth are castable in this form.
Hunters
* A new Avoidance ability can now be taught to hunter pets. This effect reduces the damage they take from area of effect spells and abilities.
* A new Cobra Reflexes ability can now be taught to hunter pets. This effect increases attack speed but reduces damage.
* Arcane Shot: Casting lower ranks of Arcane Shot than your maximum rank will now reduce the bonus you receive from attack power.
* Aspect of the Cheetah/Pack: Wand damage will again correctly daze players with this effect active.
* Clever Traps now affects Snake Trap.
* Entrapment (Survival): Effect duration reduced to 4 seconds and is now subject to diminishing returns in PvP.
* Entrapment: The tooltip has been corrected to indicate it works on Snake Trap.
* Expose Weakness: The chance for this talent to trigger has increased to 33/66/100% chance at 1/2/3 talent points.
* Ferocious Inspiration: This ability will now trigger Kill Command correctly.
* Flare cooldown increased to 20 seconds, and duration reduced to 20 seconds.
* Frenzy: This talent can now trigger from Kill Command.
* Frost Trap: This trap no longer breaks stealth from its slowing effect.
* Go for the Throat no longer causes additional threat.
* Hunter's Mark: This ability now becomes stronger each time the target is struck by a ranged attack.
* Improved Hunter's Mark: Adjusted the tooltip to indicate this talent only grants melee attack power equal to the base ranged attack power on the Hunter's Mark.
* Kill Command has been removed from the global cooldown. The shout animation has been removed.
* Kill Command: This ability will now still work even when your pet is out of your line of sight.
* Readiness: Now resets the cooldown on Misdirection.
* Revive Pet: The tooltip has been adjusted to indicate the pet returns with a percentage of its base health. It will not get an increased percentage of the bonus health it receives from a percentage of its master's stamina.
* Scatter Shot: This ability will now trigger Kill Command when it critically strikes.
* Scorpid Poison: Ranks of this ability now appear in correct order in the pet training window.
* Survival Instincts now also increase attack power by 2/4%.
* The quest creature, Death Ravager, is no longer able to be tamed.
* The Razorfang Ravager can now be tamed.
* Hunter Mend Pet/Improved Mend Pet Changes:
o Replaced the current Mend Pet channel spell with an instant cast heal over time.
o No combat reset, resets global cooldown
o The mana cost has been reduced and the heal value increased.
o Duration on Heal Over Time increased to 15 seconds in 3 second increments.
o Changed the graphic to better represent the Heal Over Time effect on the pet.
o The Mend Pet heal over time buff is now able to be dispelled.
o Bonus healing gear will no longer effect Mend Pet.
o Added a 10% and 20% reduction to the mana cost of Mend Pet in Improved Mend Pet talent (Beast Mastery).
Mages
* Added a new rank of Ice Barrier to mage trainers.
* Arcane Brilliance, rank 1, is now available from trainers.
* Arcane Brilliance: Rank 2 of this ability now has the same range as rank 1.
* Arcane Missiles: Rank 3-11 will now consistently pulse 5 shots of arcane damage.
* Arcane Missiles: This spell is now affected by Spell Haste.
* Arctic Winds (Frost Talent) now also increases all Frost damage caused by 1-5%.
* Cold Snap: The tooltip has been adjusted to indicate it only resets cooldowns caused by Frost spells. e.g.: Cold Snap will not reset the cooldown caused by Dragon's Breath.
* Conjure Mana Emerald: This spell now triggers a global cooldown as intended.
* Counterspell duration reduced to 8 seconds, and the cooldown reduced to 24 seconds.
* Fixed some data errors that caused Arcane Blast, Ice Lance and Molten Armor to generate more threat than intended.
* Frostbite effect is now subject to diminishing returns in PvP.
* Frostbolt: Damage on rank 12 has been increased slightly to ensure it did more damage than rank 11 at all levels.
* Hypothermia: If this debuff would prevent you from casting a spell on a given target, the button for that ability is now grayed out.
* Ice Armor:Rank 5 will now still trigger when all damage received is prevented by a damage shield, such as Mana Shield.
* Ice Block: This ability no longer makes mages immune to Weakened Soul from Power Word: Shield. However, using this ability now causes Hypothermia, making the mage unable to cast Ice Block again for 30 sec.
* Improved Fire Ward: This talent will now work correctly with rank 6 of Fire Ward.
* Invisibility: Clarified the tooltip on this ability to indicate any action breaks the invisibility affect.
* Molten Armor: This ability will no longer be triggered erroneously by some non-melee attacks, such as Feral Faerie Fire. It will also no longer break crowd controlling affects such as Polymorph.
* Spell Steal: Stolen buffs that affect specific spells from the original target's class will no longer have any effect for the mage.
* The Arcane Blast debuff can no longer be dispelled.
* Water Elemental: This pet will now come into the game with full health and mana, including that gained from a percentage of its master's stamina and intellect.
Paladins
* Ardent Defender (Protection) now reduces damage taken by 6-30% when below 35% health.
* Avenger's Shield no longer has a minimum range. It may be used on any target within 30 yards.
* Avenger's Shield: The damage portion of this ability will now be applied even if the victim is immune to snare.
* Blessing of Light: Paladins can now cast this as intended when they have Greater Blessing of Light on themselves.
* Consecration: Corrected a tooltip typo. Low ranks of this ability being cast by high-level players are now being properly penalized.
* Divine Shield: This ability no longer removes or prevents the Weakened Soul debuff.
* Eye for an Eye: Some spells did not trigger Eye for an Eye correctly. That has been fixed.
* Fixed some data errors that caused Seal of Command and Seal of Blood to generate more threat than intended.
* Forbearance: It is no longer possible to use a macro to gain the benefit of Avenging Wrath and Divine Shield at the same time.
* Forbearance: If this debuff would prevent you from casting a spell on a given target, the button for that ability is now grayed out.
* Greater Blessing of Kings: The cost for this blessing is now twice the cost of Blessing of Kings, instead of a fixed cost of 150.
* Greater Blessing of Sanctuary 2: The range on this spell was incorrectly set to 30 yards. It has been changed to 40 yards.
* Greater Blessing of Wisdom 3: The range on this spell was incorrectly set to 30 yards. It has been changed to 40 yards.
* Hammer of Wrath: Rank 4, damage increased.
* Illumination: This talent now only gives 60% of the mana cost of the critical heal. It also now returns the correct amount of mana when used with ranks 4 and 5 of Holy Shock.
* Improved Concentration Aura (Protection Talent) no longer increases resistance to Interrupt/Silence mechanics, but instead reduces the duration of Interrupt/Silence mechanics by 10/20/30%.
* Improved Seal of Righteousness: The percentage increase in damage from this talent is now applied after all bonuses from items and effects which increase your spell damage.
* New Protection Talent added: Improved Holy Shield, 2 ranks: Increases damage caused by Holy Shield by 10/20% and increases the number of charges of Holy Shield by 2/4.
* One-Handed Weapon Specialization(Protection): Now increases all damage caused by the paladin by 1-5% while a one-handed weapon is equipped.
* Sanctity Aura now increases all damage caused by affected targets by 1/2% and no longer increases healing done to affected targets.
* Seal of Blood: This seal will no longer cause additional chances for weapon procs to trigger.
* Seal of Righteousness: This seal will no longer cause additional chances for weapon procs to trigger.
* Seal of the Crusader: The rank 7 tooltip has been fixed to read the same as other ranks of this spell.
* Spiritual Attunement: First-aid generated healing will no longer trigger this ability. However, Lifebloom, Earth Shield, and Improved Leader of the Pack will now trigger it correctly. The tooltip has been adjusted to indicate it only works on healing from spells. It will also now work correctly when you are mounted or sitting.
* Spiritual Attunement: Mana is no longer healed if the paladin is at full health.
* Stoicism (Protection) should now properly affect all magic effects cast by the Paladin and no longer applies double its intended benefit to Blessing of Might and Blessing of Wisdom.
* Vengeance (Retribution) now increases Holy and Physical damage by 1/2/3/4/5% for 15 seconds following a critical hit, but the effect now stacks up to 3 times.
* Vindicator Aesom at Blood Watch will now correctly train a full range of paladin spells.
Priests
* Binding Heal: The mana cost has been reduced by 32%. The tooltip has been adjusted to indicate it is a low threat spell, which was already the case.
* Blackout: The delay on the stun effect has been reduced.
* Circle of Healing (Holy) effect increased.
* Empowered Healing and Holy Concentration now affect Binding Heal.
* Focused Power (Discipline) now also increases the chance to hit with Mass Dispel, reduces the cast time of Mass Dispel but no longer increases the damage against feared targets.
* Holy Fire: The rank 9 tooltip has been corrected to indicate it does Holy damage.
* Holy Nova: Rank 2 will no longer receive double the intended increase in range from Holy Reach.
* Mass Dispel mana cost reduced.
* Mind control no longer has a 100 yard range limitation in instances.
* Pain Suppression now reduces damage taken by 65% and increases resistance to Dispel mechanics by 65% for the duration.
* Power Infusion: This ability is now unuseable on Rogues or Warriors.
* Power Word: Shield: The Weakened Soul effect will no longer sometimes be re-applied while zoning with this buff on.
* Prayer of Fortitude: The range on rank 3 has been changed to match all other ranks of this spell.
* Prayer of Fortitude, ranks 1 and 2, are now available on trainers.
* Prayer of Mending: This spell is now affected by Silent Resolve, Amplify Magic, and Dampen Magic.
* Prayer of Shadow Protection, rank 1, is now available on trainers.
* Reflective Shield: When this effect is triggered, the priest will no longer be forced to stand up.
* Shadowfiend: This pet will now come into the game with full health and mana, including that gained from a percentage of its master's stamina and intellect.
* Shadowfiend: The Shadowfiend will now correctly attack your target even if it is neutral or non-aggressive.
* Shadowguard: The rank 7 tooltip is now consistent with all other ranks of Shadowguard.
* Shadow Weaving (Shadow): Effect reduced by 1% per rank and Mana Burn will now correctly trigger this talent.
* Shadow Word: Death: Cooldown increased to 12 sec and will now properly damage the casting Priest when it is reflected.
* Silent Resolve: Some priest spells were unaffected by this talent. They should now all be affected.
* Spirit of Redemption and Spiritual Guidance now work while the priest is in Shadowform.
* Spirit Tap: This ability will no longer be triggered by killing some creature-cast totems.
* Spiritual Guidance: This talent now works while the Priest is in Shadowform.
* Surge of Light: Smite spells triggered by this talent will no longer sometimes critically strike. In addition, the free Smite granted will not consume the effect of Inner Focus. Holy Nova heals can now trigger Surge of Light as well.
* Touch of Weakness: This spell can now activate Surge of Light.
* Vampiric Touch: This spell now consumes the Inner Focus buff.
* Weakened Soul: If this debuff would prevent you from casting a spell on a given target, the button for that ability is now grayed out.
Rogues
* Added a new double-attack animation for Mutilate.
* Blade Twisting: The delay on the daze effect has been reduced.
* Cloak of Shadows: The tooltip has been adjusted to indicate this ability removes hostile effects, rather than dispels them. Cloak of Shadows does not count as a dispel, and will not interact with dispel resistance or effects triggered by dispelling. This ability no longer removes the Weakened Soul debuff.
* Deadly Throw: This ability will now damage hunters and their pets when they are affected by The Beast Within or Bestial Wrath. Those targets will still be immune to the movement impairing portion of Deadly Throw.
* Fixed a data error that caused Ghostly Strike and Riposte to generate more threat than intended.
* Fixed a bug where the Silence effect on Garrote was getting resisted too often.
* Gouge: This ability will no longer trigger poisons (and thus break itself).
* Insignia of the Alliance/Horde and Medallion of the Alliance/Horde now remove Fear, Stun and Polymorph effects and no longer remove Charm effects.
* Improved Sap (Subtlety) renamed Dirty Tricks: Increases the range of your Sap and Blind abilities by 2/4 yards and reduces the energy cost of your Sap and Blind abilities by 25/50%.
* Increased the frequency and amount of Blinding Powder found in pickpocketed junk boxes.
* Mutilate: This ability will now always consume the Cold Blood buff when it strikes an opponent.
* Poisons: The difficulty of dispelling these is now based off the level of the player, not the level of the weapon the poison is applied to.
* Reduced the reagents required to create most poisons.
* Remorseless Attacks (Assassination): Hemorrhage added to the buff tooltip. This ability will no longer trigger from killing totems.
* Rogue poisons no longer have charges.
* Sap no longer removes you from stealth when used.
* Shadowstep (Subtlety): The cooldown has been reduced to 15 seconds.
* Stealth will now be broken correctly by damage shield such as Oil of Immolation.
* Surprise Attacks (Combat): This talent now correctly prevents Envenom from being dodged.
* Sword Specialization: This ability now grants extra yellow attacks instead of extra white attacks. This change will make Sword Specialization no longer reset the weapon swing timer when it triggers off special attacks, and results in a net increase in damage dealt.
Shaman
* Earth Elemental Totem: This pet will now come into the game with full health, including that gained from a percentage of its master's stamina.
* Earth Shield: Adjusted the tooltip to indicate this ability works against all types of attacks, not just melee. This ability will also now properly trigger only from taking direct damage effects.
* Earth Shock: Rank 8 is now properly considered an Interrupt effect for talents and abilities that affect interrupts.
* Elemental Focus: This talent now reduces the cost of the next damage spell by 60%. It will also now trigger from bonus spells cast by Lightning Overload.
* Eye of the Storm (Elemental): Clarified the tooltip on this talent to indicate it only works with Shaman spells.
* Fire Elemental Totem: This pet will now come into the game with full health and mana, including that gained from a percentage of its master's stamina and intellect. It will also now properly get increased stamina from a percentage of its master's stamina.
* Flametongue Weapon: This effect will no longer trigger while you are disarmed.
* Frostbrand Weapon: Rank 6 now properly receives increased effect from spell damage bonuses.
* Healing Focus: The tooltip has been adjusted to indicate it only works with Shaman spells. e.g.: Does not work with Gift of the Naaru.
* Healing Way: This talent now correctly modifies the healing done after all bonus effects have been applied.
* Heroism: Training cost increased to match the cost of Bloodlust.
* Lightning Shield: Ranks 8 and 9 of this spell now trigger correctly while mounted.
* Magma Totem: This totem will now correctly do damage on its 10th tick, right before despawning.
* Mana Spring Totem: Duration increased to 2 minutes.
* Mana Tide Totem: This totem will no longer sometimes grant mana after it has been destroyed. It will also consistently grant mana 4 times instead of sometimes 3 and sometimes 5.
* Healing Stream Totem: Duration increased to 2 minutes.
* Mental Quickness: This talent now correctly reduces the cost of Purge, Flame Shock, Frost Shock, Earth Shock, Bloodlust, Heroism, Lightning Shield, Cure Poison, and Cure Disease.
* Nature's Guardian (Restoration): Some spells and abilities did not trigger this talent. That has been fixed.
* Restorative Totems (Restoration): This talent no longer gives a bonus to a variety of jewelcrafting items.
* Trainer Animations: All new Shaman abilities will now correctly play the training animation when learned.
* Water Shield: When a Shaman with this spell active is afflicted with Cyclone, the charge burned will now grant mana.
* Windfury Weapon: Mixing two different ranks of Windfury Weapon while dual-wielding will no longer increase the number of Windfury Weapon procs.
* Windfury Weapon: A bug with this spell was making off-hand procs receive less bonus damage than intended. It is now fixed.
Warlocks
* Aftermath: The delay on the daze effect has been reduced.
* Amplify Curse: This ability is now consumed correctly by a Curse of Doom casting.
* Conflagrate: The button for this ability will now be greyed out when your current target does not have Immolate.
* Create Healthstone: These abilities will now be sorted in rank order in your spellbook.
* Create Spellstone: These abilities will now be sorted in rank order in your spellbook.
* Curse of the Elements and Curse of Shadow now have a duration of 2 minutes when used on PvP targets.
* Curse of Tongues now has a 12 second duration when used on PvP targets.
* Dark Pact: This ability is now unuseable while the mana and health of a pet are being adjusted by pet scaling.
* Death Coil is now is now subject to diminishing returns in the Horror category. Currently, only Death Coil is in this category.
* Demonic Knowledge: This ability will now work with enslaved demons.
* Enslave Demon: The health bar and mana bar for enslaved demons will no longer appear to go down when they become enslaved.
* Felguard: This pet will periodically check to see if you know the talent which allows you to summon it, and die if you do not know the talent.
* Fixed some data errors that caused Soul Leech and Conflagrate to generate more threat than intended.
* Improved Drain Soul: This talent will no longer trigger when a creature other than the one you are draining dies.
* Insignia of the Alliance/Horde and Medallion of the Alliance/Horde now remove Fear, Stun and Slowing effects and no longer remove Charm and Polymorph effects.
* New art added for Ritual of Souls channeling focus and Soulwell created by the spell.
* Ritual of Souls no longer consumes a Soul Shard when cast in arenas.
* Seed of Corruption: This spell will now interact properly with town guards when bystanders are hit by its detonation in a duel.
* Shadowfury now properly benefits from the Intensity talent.
* Spell Lock (Felhunter) duration reduced to 5 seconds (rank 1) and 6 seconds (rank 2), and cooldown reduced to 24 seconds.
* Soulwell now plays a sound and visual effect when you create a Healthstone through using it.
* Soul Link: Adjusted tooltip to explain that the damage transferred to the pet cannot be prevented. The functionality remains unchanged. This ability will now work with enslaved demons.
* Unholy Power: The tooltip has been corrected to indicate it works with the Imp's Firebolt.
Warriors
* Bloodrage: It is no longer possible to gain extra rage from this ability by using tradeskills to keep you in combat
* Charge, Intercept and Intervene now suppress all Slowing effects while charging the target.
* Charge: This ability will now properly cause the warrior to go into combat with its target.
* Commanding Shout: This ability now increases your max health, but keeps your percentage health constant.
* Death Wish and Enrage effects no longer stack.
* Execute: When used with Sweeping Strikes, ranks 6 and 7 of this ability will no longer cause full damage to secondary targets who are not wounded.
* Flurry: Ranks 1-4 will no longer trigger from ranged critical strikes.
* Flurry (Fury) now increases attack speed by 5/10/15/20/25%, reduced from 10/15/20/25/30.
* Heroic Strike: The rank 10 tooltip now includes specific values for the bonus damage against dazed targets.
* Improved Hamstring: The delay on the immobilize effect has been reduced.
* Improved Revenge: Reduced the delay on the stun landing from a successful Revenge.
* Insignia of the Alliance/Horde and Medallion of the Alliance/Horde now removes Immobilizing, Stun and Polymorph effects and no longer remove Slowing effects.
* Revenge: This ability has been modified to do substantially more damage. The threat bonuses have been adjusted so that the threat generated remains relatively unchanged.
* Shield Slam: Rank 3 of this ability no longer gets its cost reduced twice by the Focused Rage talent (Protection).
* Spell Reflection no longer has a global cooldown.
* Sweeping Strikes: This ability will no longer be modified erroneously on additional targets by percent modifiers to your damage.
* Sword Specialization: This ability now grants extra yellow attacks instead of extra white attacks. It also grants rage based on the speed of your weapon. This change will make Sword Specialization no longer reset the weapon swing timer when it triggers off special attacks, and results in a net increase in damage dealt.
* Victory Rush: The tooltip has been adjusted to calculate the damage it deals correctly, 45% of Attack Power, not 35%.
Pets
* Abilities and items that are triggered when you kill a target are also now triggered when your pet kills a target.
* Fixed the amount of happiness lost when you dismiss a Nether Ray pet.
* Voidwalkers will stop while they are consuming shadows.
* Warlock and Hunter pets will now be automatically dismissed when you summon a mount. These pets will return on dismount. This does not affect pet happiness for Hunters.
* Warlock and Hunter pets will now be automatically dismissed when you untalent.
Items
* All epic items of Tier 5 and beyond quality have been upgraded to reflect their intended power.
* Armor: All Burning Crusade items that spent part of their budget on increased armor have been re-evaluated. Some gained additional armor, while others gained other additional bonuses.
* Common unique items will not drop for you if you already have them in your inventory.
* Items which start quests you've already completed will show the correct feedback if you try to use them.
* Heroic difficulty instances end bosses will now always drop an epic item, in addition all bosses in Heroic difficulty instances will have a chance to drop an epic gem!
* Additional darkmoon cards can now be found on high level outland creatures. They can be turned in to the darkmoon faire to make powerful new darkmoon card trinkets. Look for Lunacy, Storms, Furies and Blessings cards.
* Serpent-coil Braid: The bonus spell damage from this trinket is now removed if the trinket is unequipped.
* Argussian Compass: A bug where this trinket sometimes caused all the damage from an attack to be absorbed has been fixed.
* Health Regeneration: This effect on random property items has been renamed to Health per 5 sec.
* Khorium Lockboxes will now drop occasionally off creatures over level 65.
* Devilsaur Tooth: This item has been reverted to pre-Burning Crusade design, granting an automatic critical strike to your pet's next attack.
* Nethershard, Ceremonial Kris, Illidari-Bane Mageblade, Summoner's Blade, Thunderlord Scalpel, Vibro Dagger, Vibro Sword, and Revered Mother's Crysknife: These weapons can now only be used in the main hand.
* The Serpentshrine Shuriken can now be sold to vendors.
* Xavian Stiletto can now be sold to vendors.
* Wand of Biting Cold can now be sold to vendors.
* Bloodseekernow can now be sold to vendors.
* The Ironscale War Cloak can now be disenchanted.
* Boots of the Infernal Coven can now be disenchanted.
* Crown of Endless Knowledge can now be disenchanted.
* Valanos' Longbow can now be disenchanted.
* Ravager's Cuffs can now be disenchanted.
* Deep Core Lantern can now be disenchanted.
* The Devilshark Cape can now be disenchanted.
* Demon Hide Spaulders can now be disenchanted.
* Gladiator's Heavy Crossbow can no longer be disenchanted.
* Tranquilien Reputation Items: Some of the items on this vendor were disenchantable. They no longer are disenchantable.
* Gladiator's Endgame can no longer be disenchanted.
* Corrected a typo in the tooltip of The Hammer of Destiny's proc.
* Corrected a typo in the tooltip of Anesthetic Poison in regards to the number of charge applied.
* Malefic Raiment: Corrected a tooltip calculation error.
* Bangle of Endless Blessings: Fixed tooltip error on Meditation effect.
* Cataclysm Harness: Fixed a tooltip error on Invigorated effect.
* Updated the tooltip for Vengeance of the Illdari to clarify that it increases spell damage.
* Blade of Eternal Darkness: The tooltip has been adjusted to indicate it only works with direct damage spells.
* Wushoolay's Charm of Nature: The tooltip has been corrected to indicate it grants spell haste.
* Corrected a naming inconsistency with Windchanneller's items.
* Figurine of the Colossus corrected a typo in the tooltip of the buff provided by this item.
* Marsh Lichen: This food is now considered a fungus.
* Stromgarde Muenster is now correctly considered cheese for the purposes of feeding pets.
* Edible Fern now triggers a global cooldown on use.
* Rumsey Rum, Rumsey Rum Light, Rumsey Rum Dark, Rumsey Rum Black Label, Halaani Whiskey, Gordok Green Grog, Raptor Punch, Stormstout, Trogg Ale, and Thunderbrew Lager: The stat bonuses from these drinks no longer stacks with stamina bonuses from other foods.
* Felguard Annihilators will now drop the proper loot in Heroic difficulty.
* Khorium Lockboxes will now contain loot of the appropriate level.
* Aeonus will now properly drop a Primal Nether in Heroic Difficulty.
* Coilfang Collaborators will now drop the proper loot in Heroic Difficulty.
* Demon Hunter Supplicants now drop the proper loot.
* Auchenai Death-Speakers and Doomsayers will now drop the appropriate loot.
* Netherstrike armor has had it's socket bonuses changed.
* PvP Set Bonuses: Set bonuses of 35 resilience rating will now stack correctly if received from two different sets.
* Alliance Shaman PvP Sets: These sets now have set bonuses as intended.
* General’s Dreadweave Boots: Now available for purchase from the PvP vendor as intended.
* Assassination Set: The haste bonus from this set will no longer be triggered if your attack does not land on the target.
* Avatar Regalia Set: Tooltips corrected on the Shadow Word: Pain set bonus to indicate the triggered bonus works on the next spell cast only. The bonus also now correctly affects healing spells.
* Black Dragonscale Set: The hit rating bonus from this set now stacks properly with hit rating bonuses from other effects.
* Black Dragon Mail Set: The hit rating and critical strike rating set bonuses from this set will now stack correctly with other sources of those ratings.
* Cataclysm Harness Set: The cast time reduction to Lesser Healing Wave will now be displayed correctly as 1.5 sec in the Invigorated tooltip.
* Cenarion Raiment Set: The spell critical strike rating set bonus will now stack properly with other effects that give spell critical strike rating.
* Defiler's Purpose Set: The critical strike rating rom this set bonus will now be applied properly.
* Defiler's Resolution Set: The critical strike rating from this set will now stack correctly with other bonuses to critical strike rating.
* Devilsaur Armor Set: The hit rating bonus from this set now stacks properly with hit rating bonuses from other effects.
* Devilsaur Set: The hit rating set bonus will now stack correctly with hit rating bonuses from other items.
* Earthfury Set: The set bonus that increases totem radius now works on Wrath of Air Totem.
* Ebon Netherscale Set: The hit rating bonus from this set will now stack correctly with other hit rating bonuses.
* Frostfire Set: The 4 piece set bonus now works correctly with rank 4 mage Armor.
* Frozen Shadoweave Set: The set bonus from these items will no longer have its tooltip modified by the Vampiric Embrace talent and can no longer cause a critical strike heal.
* Hallowed Raiment Set: The Binding Heal set bonus on this set has been changed to 30% chance to resist losing casting time off Binding Heal when taking damage.
* Imbued Netherweave Set: The critical strike rating set bonus now stacks correctly with other effects that grant critical strike rating.
* Incanter's Set: Corrected precision error in display of cast time reduction in Flamestrike. The actual value is unchanged; it was displaying a rounded-off value before.
* Justicar Armor Set: The bonus to Seal of Vengeance now functions correctly.
* Malefic Raiment Set: The set bonus granting heals from periodic spells can longer get critical strikes.
* Netherblade Set: The set bonus giving a chance to gain combo points on finishers now works correctly with Slice and Dice and Deadly Throw.
* Overlord's Resolution Set: The dodge rating bonus from this set now stacks correctly with all other dodge rating effects.
* Voidheart Set: This set bonus will now trigger correctly from all shadow and fire spells.
* Warbringer Armor Set: The Revenge set bonus will no longer apply an excessive bonus to Heroic Strike.
* Wyrmhid Set: Adjusted the tooltip on Moonfire cost reduction to indicate it is a reduces by a percentage of the base cost, not the talented cost.
* Nordrassil Regalia: The Regrowth set bonus will now correctly be consumed by the first casting of Regrowth.
* Clefthoof Hide Leggings: There were two items with this name. The world drop item has been renamed as Elekk Hide Leggings.
* Fathom-Brooch of the Tidewalker: Healing spells and spells which are not critical strikes can now trigger this trinket.
* Heavenly Inspiration no longer shares a cooldown with other trinkets which temporarily increase spell damage.
* The Talon of Al'ar: This trinket now applies correctly to Scatter Shot and Silencing Shot.
* Energized Wristwraps: This item was incorrectly set to superior quality. It has been changed to good quality with the stat bonuses unchanged.
* Murloc Eggs: These pet-summoning items are now set to superior quality.
* Swift Flying Mounts: All the swift flying mounts will now display as epic items, rather than superior-quality items.
* The Twin-Bladed Rippericon has been changed.
* The Netherwhelp's Collar now has it's own unique icon.
* The Lightsworn Hammer icon has been changed to a mace icon.
* Replaced the placeholder art for Zeth'gor Shield and Dragonscale Shield with permanent art.
* Staff of Prehistoria: A placeholder icon will no longer become visible when creating this staff.
* Corrected the stats of Girdle of the Endless Pit.
* Corrected the stats of Supple Leather Boots.
* Scroll of Strength V will now give the proper stat increase.
* Corrected many issues with helmets displaying and not displaying hair correctly.
* The Stealther's Helmet of Second Sight will now properly hide facial hair.
* Warmaul Helmet: This helmet no longer displays facial hair clipping through the helm.
* The Citrine Pendant of Golden Healing should now properly work on players of all levels.
* Removed the level requirement on Battle Scarred Leggings.
* The Consortium Combatant's Robes level requirement has been removed.
* The Spellfire and Shadoweave tunics have been changed to robes.
* Robes of Insight will again correctly have its effect consumed by casting Blink.
* Masquerade Gown will now be triggered correctly by any spell, not just critical strikes.
* Adamantite Weight Stones now work on staves and fist weapons.
* Fel Weightstone now works on fist weapons.
* Spymaster's Crossbow can now be used by non-hunters.
* The Azerothian Longbow will now properly display it's firing animation.
* Halaa Ammo has been reduced in damage and soulbound, but you can carry any number of them.
* Draenic Light Crossbow now correctly uses arrows and has had it's firing animation corrected.
* Lead Slug Shotgun: Correct sounds and animations are now attached.
* Longbeard Rifle now has a gun animation and sound.
* Dragonbreath Musket, PC-54 Shotgun, Sporting Rifle, and Tauren Runed Musket all now have a gun sound and animation instead of crossbow.
* The Night Blade: The chance for the effect on this item to trigger has been reduced.
* The Flarethorn will now display properly when sheathed.
* Aldor Guardian Rifle will now work correctly.
* Mag'hari Light Recurve will now work correctly.
* Ragehammer again grants increased damage instead of attack power.
* Searing Needle: The damage effect from this item is fixed and now works correctly.
* The Illidari-Bane Mageblade is now correctly a sword as intended.
* Atiesh (Greatstaff of the Guardian): The party aura from these items will now be reapplied correctly when a player logs into the game while already mounted.
* Hammer of Destiny: The mana restoring effect from this item will now display in the combat log.
* Earthwarden: Damage when not shapeshifted reduced on this weapon; this was intended to be reduced like other feral weapons, but was overlooked.
* The Silver Star: This low-level quest reward has been fixed to match the new system for thrown weapons. For technical reasons, all old Silver Stars are now listed as Broken and cannot be used. New ones gained will work correctly.
* Grunt's Waterskin: This item now has the same effect as Footman's Waterskin.
* The Decapitator should no longer give an immune message when used on certain creature types.
* The Discombobulator Ray no longer works on flying targets.
* Goblin Rocket Launcher: When this item stuns a warrior opponent, it can now trigger Second Wind.
* Cosmic Infuser: This item now works with Gift of the Naaru and Holy Nova. It does not work with affects which cause a target to heal themselves, Earth Shield, Lifebloom, Prayer of Mending, etc., or which are caused by draining life or vampirism. Health potions and other consumables will no longer trigger it either.
* Mana Thistle: Picking this herb will no longer case abilities such as Lightning Shield to trigger and burn changes.
* Nightmare Vine: The poison from picking this herb is now considered Nature damage instead of Physical damage.
* Pendant of the Violet Eye will no longer trigger from spells with no mana cost. It will also no longer get double procs from some Paladin spells.
* Pendant of Golden Healing: This item no longer gains benefit from bonus healing effects.
* Bangle of Endless Blessings will no longer proc off of tradeskills.
* Bogslayer Bracers now make the proper sound when moved in your inventory.
* Reduced the Silence and Interrupt reduction provided by Talisman of the Breaker.
* Band of the Eternal Champion: This item is no longer triggered from being hit by ranged attacks.
* Band of the Eternal Defender: The effect from this item now only affects the wearer, instead of the whole party.
* Eye of Gruul has been redesigned to give a chance of healing discount each time a heal is cast.
* Occulus of the Hidden Eye: The tooltip for this item now specifies the user must kill a creature to gain its benefit.
* Lesser Rune of Warding: This effect will now continue to work correctly after the target dies and resurrects.
* Greater Rune of Warding: This effect will now continue to work correctly after the target dies and resurrects.
* Mark of Conquest: The mana energizing effect from this item now correctly occurs on dealing ranged damage instead of taking it.
* Glyph of Renewal: The mana regeneration from this enchantment will now stack correctly with all other mana regeneration effects.
* Libram of Eternal Rest was causing Judgement of the Crusader not to refresh on each hit. That has been fixed.
* Auslese's Light Channeler: Avenger's Shield will now consume the effect from this item.
* Hazza'rah's Charm of Healing now provides haste rating as intended, instead of a fixed reduced cast time.
* Aegis of Preservation: This item will now correctly heal the user; it was showing up in the log, but not increasing actual health.
* Mystical Skyfire Diamond: The triggering rate on this item has been increased, but it now only reduces the cast time on spells by half; and Warlocks casting Corruption with maximum ranks in Improved Corruption will no longer consume the Focus buff from this gem.
* Lifegiving Gem: This item will now only increase maximum and current health of the user by 1500. It will not also heal the user for 1500.
* Enraged Fel Sparks now properly drop Motes of Fire instead of Motes of Shadow.
* Primal Nethers may now be purchased from G'eras for Badges of Justice.
* Oracle Belt of Timeless Mystery: The On Use effect changed to On Equip as intended.
* Abyssal Cloth Slippers: There were two items with this name. The ones from the Burning Crusade have been renamed Abyssal Cloth Footwraps.
* Updated the General's Leather Boots to properly reflect the Alliance counterpart.
* Area 52 Defender's Pants: Arcane resistance on this item was unintended and has been removed.
* Brood Mother Leggings: Now has a spell price and can be worn by non-hunters.
* Razaani-Buster Leggings: This item can now be sold to a vendor.
* Mok'Nathal Hero's Pantaloons now has a sell price and can be worn by non-hunters.
* Enchant Boots - Vitality: The health regeneration from this enchantment will now work in combat.
* Enchant Weapon- Spellsurge: The mana gained from this enchantment will now show up in the combat log.
* Malorne Raiment and Malorne Regalia: These sets no longer erroneously apply a reduction in cost to some Druid spells.
* Cyclone Regalia: The chance for a mana cost reduction to occur has been reduced.
* Warrior Tier 4 Tanking Set: The Blade Turning Bonus now prevents the correct amount of damage, 200.
* Priest Tier 5 Shadow Set: The Sadist buff will no longer be consumed when casting a spell which does neither damage nor healing.
* Priest Tier 4 Shadow Set: Mind Flay will now benefit correctly from the 4 piece bonus.
* Shaman Tier 5 Spell Damage Set: The 4 piece bonus will no longer be triggered by Shocks and Chain Lightning.
Professions
* Alchemy
o The chance of a discovery occurring while making potions has been substantially increased.
o Elixirs now stack in two categories, Battle (Offensive) and Guardian (Defensive) Elixirs. You can only have one of each type of Elixir up at a time. As a result Elixirs now stack with class abilities such as Arcane Intellect.
o Elixirs now stack to 20.
o Four new defensive elixirs have been added. Two are on trainers, one is in Halaa and one is in Cenarion Expedition.
o Flask of Petrification can no longer be turned off during its duration, but it now will clear all threat from all monsters for the duration of the effect. Though monsters may reacquire you after the effect ends.
o Cooldown time on Earthstorm and Skyfire Diamond transmutes has been reduced to 1 day.
o Invulnerability potions now stop the first 120 damage per hit for 8 seconds, rather than making the imbiber physically immune.
o The major protection potions made by Alchemy now require more Mana Thistle and vials, but create 5 potions instead of just one.
o Fel Strength elixirs now work correctly with elixir mastery.
o Elemental Absorption potions now have a 2 minute duration rather than the 60 min duration they used to have.
o Alchemy transmute of Heart of Fire to Elemental Fire changed to 15 minute cooldown.
o Reagent costs and potency of all flasks has been reduced.
o The cost of Imbued Vials has been reduced.
o The chance to find a Fel Lotus while picking an herb has been increased.
o Juju Chill and Juju Ember are now considered Guardian Elixirs and do not stack with other resistance buffs.
o Juju Flurry is now considered a Battle Elixir and has been converted from haste to haste rating.
o Ground Scorpok Assay,Juju Might,Juju Power, Lung Juice Cocktail, and R.O.I.D.S are now considered Battle Elixirs.
o Crystal Force, Crystal Ward,Gizzard Gum, Infallible Mind,Juju Escape, Juju Guile, Sheen of Zanza and Swiftness of Zanza are all now considered Guardian Elixirs.
o Sheen of Zanza is now considered a Guardian Elixir. Stamina and Spirit bonuses have been reduced to 25.
o Elixir of Fortitude now correctly displays its name in its buff tooltip.
o The Alchemist's Stone bonus now works on potions that restore both health and mana.
o Super Mana Potions now require 2 Dreaming Glory instead of 2 Netherbloom to create.
o Super Healing Potions now require 2 Netherbloom instead of 2 Dreaming Glory to create.
o Reduced the number of Stonescale Oil required to make Greater Stoneshield Potions.
* Enchanting
o Enchant Bracer-Spellpower had its primal costs reduced slightly.
o Enchanting recipes that increase spell damage now also increase healing as well.
o The Major Defense Bracer enchantment has been moved from Ethereum Researchers to Ethereum Nullifiers.
* Engineering
o 11 new epic goggles have been introduced at 350 engineering skill and are available from the trainer. They range from cloth to plate, and have a variety of stats to appeal to most talent specs.
o A recipe for Frost Grenades and the Icy Blasting Primers needed to make them are now on engineering trainers.
o Engineering recipes can now be placed in engineering bags, as can engineer made fireworks.
o Many engineering recipes will now give skillups for longer than the previously did.
o An engineering recipe to make Fused Wiring can be found in both Everlook and Shattrath.
o Engineering Skill required to make the Felsteel Stabilizer, Hardened Adamantite Tube and Khorium Power Core have been reduced slightly.
o Adamantite Shells now require less adamantite and do slightly more damage.
o The recipe for Elemental Blasting Powder now gives 4 powder when creating it, though it now requires an additional mote of earth.
o Engineers now make 3 Smoke Flares instead of just one when they create them. Also Smoke Flares now have a buy/sell price.
o Seaforium now opens locked chests as well as locked doors.
o The Consortium Vendor Karaaz now sells the engineering recipe for an Elemental Seaforium Charge if you are revered with them.
o The Poultryizer has a smaller chance of getting malfunction effects and is now a superior quality item.
o The Nigh Invulnerability Belt now has a smaller chance of failure.
o Healing Potion Injectors and Mana Potion Injectors created by engineers now have new icons.
o Goblin Rocket Launcher now has a 2 minute cooldown, and had its casting time reduced to 3.5 sec.
* Fishing
o The fishing timer has been reduced from 30 to 20 seconds and it now takes less time to fish.
o The fishing timer can no longer run through its duration without a fish biting.
o Fishing has been removed from Arathi Basin and Alterac Valley.
o You can now fish in Underbog.
* Jewelcrafting
o The jewelcrafting UI now has gems split up by color so it is easier to find gems of a specific color to create.
o A new set of more powerful gems can be found by raiding Hyjal and Black Temple. Their stats exceed those of previous gems that could be found.
o A number new gem cuts to existing gems have been added to the game. Included among them are a spell hit gem and more multi-stat gems that have attack power on them.
o Jewelcrafters can make two new melee oriented meta gems. One is found randomly as a world drop and the other sold by the reputation vendor.
o Thorium Setting only requires 2 thorium bars now
o Many Jewelcrafting recipes that required 200-280 skill to learn now have changed/reduced materials required to make them
o Mithril filigree has a slightly reduced range that it gives skillups.
o A number of jewelcrafting gems now give skill increases for slightly longer than they used to.
o Pendant of Blasting and Necklace of Battle will now grant their click effects to players correctly, previously they only worked on characters higher than level 47.
o Jewelcrafting Onslaught ring thorium cost reduced
o The vendor value for the raw green gems have been reduced. This will also make these gems cheaper to put up on the auction house (Blood Garnet, Golden Draenite, etc...)
o Prospecting now always yields at least 1 gem.
o Grand Master Jewelcrafters Hamanar (Shattrath City), Jazdalaad (The Stormspire), Kalaen (Thrallmar) and Tatiana (Honor Hold) may teach all levels of Jewelcrafting.
o The recipe for Figurine - Golden Hare no longer requires a Cut Citrine. It now requires copper bars.
* Leatherworking
o Knothide Armor kits now require less leather to make and give skill increases for longer.
o Leatherworking made primalstrike set now has an attack power set bonus rather than a strength set bonus.
o Additional snakes that drop cobra scales are in the highlands of nagrand as well as in shadowmoon valley.
o Leatherworker made Drums of Restoration had their health/mana effects reduced slightly.
o Nethercobra Leg Armor and Nethercleft Leg Armor have been slightly improved.
o Heavy Clefthoof Boots, Heavy Clefthoof Leggings,and Heavy Clefthoof Vest have had their armor increased at the expense of some stamina and defense rating.
* Additional Profession Changes
o You can now unspecialize in tailoring and alchemy, and then select a new specialization. This is a repeatable choice, but costs gold each time.
o Skinning higher level creatures will give more leather; you will no longer get a single leather scrap.
o Gathering skills no longer fail when you have reached the maximum skill possible.
o The Stoneforged Claymore model has been updated.
o Fel Iron Bars now have an icon unique from Felsteel Bars.
o Felsteel Bars are now good quality (green items).
o The Tailoring recipe Ebon Shadowbag no longer drops on Spirit Walkers.
o Profession recipes that had 24 hour or longer cooldowns, have had their cooldowns reduced by 1 hour.
o Added Warped Flesh to high level warpstalkers.
o Alliance Cooks can now purchase the Mok'Nathal Shortrib and Crunchy Serpent recipes at Toshley's Station.
o Monsters will now attack players who are mining mineral nodes near to them, even if they didn't notice them previously.
o Golden Spellthread and Runic Spellthread have been slightly improved.
o Enchant Weapon- Major Spellpower enchant has been stolen from the Razaani spell thieves by the Bash'ir spell thieves. The Bash'ir are more likely to have the recipe than the Razaani previously did, however.
o Imbued Netherweave Tunic and robe recipes are vendor purchased so are now white instead of blue.
o Nightmare Seed found with herbalism now requires level 60 to use.
o The location of many of the Outland mineral nodes have been adjusted both to put them in locations that are more traveled and to make them more likely to be near creatures.
o Essences (Earth, Fire, Air, Water, Living) have had their drop rates significantly increased. Also Outland creatures that dropped motes will now have a chance of dropping essences as well.
o Materials required to make the Blacksmithing Adamantite plate armor have been reduced.
o The Epic bind on equip Blacksmith weapon recipes now require more materials to make.
Quest
* You can now interact with wanted posters while mounted.
* Grishnath Orbs can no longer be interacted with unless the character is on the quest, Exorcising the Trees.
* The Ammen Vale quest, Rescue the Survivors! is now properly flagged as draenei-only. Non-draenei who have this quest in their log should abandon it.
* Fixed a grammatical error in the quest, The Ring of Mmmrrrggglll.
* The quest, Defiling Uther's Tomb no longer has a time limit attached to it.
* The level for the Hellfire Peninsula quest, Natural Remedies has been dropped from 64 to 63.
* The Shadowy Disguise for the quest, Who Are They? can no longer be gained while shapeshifted.
* Adjusted a few Restless Bones piles in the Bone Wastes so that they were not under the ground.
* Fixed an issue with the quest, Sabotage the Warp-Gate!, which would sometimes fail the escort as it began.
* The Blade's Edge Mountains quest, On Spirit's Wings is no longer shareable.
* Fixed some typos in the quest, Reunion.
* Completing the Horde quest, Reunion, will now auto-launch the next quest in the series, On Spirit's Wings.
* Directions to the Bloodmaul Camp are now included in the quest, The Smallest Creatures.
* The Horde version of the quest, Gorgrom the Dragon-Eater is no longer shareable.
* Completing the Horde version of the quest Gorgrom the Dragon-Eater will now auto-launch the quest, Prisoner of the Bladespire.
* Directions to Gruul's Lair are now included in the quest, Prisoner of the Bladespire.
* The Scrap Reaver X6000 from the quest, You, Robot, no longer has its Repair ability.
* Matron Varah of Mok'Nathal Village no longer offers the quest, Understanding the Mok'Nathal. Now, only Leoroxx has that distinction, as was intended.
* Minimap arrow for the quest, Report to the Allerian Post fixed.
* Whispers of the Raven God: Understanding Ravenspeech will now hit players at range.
* Bash'ir Landing and Razaan's Landing in Blade's Edge Mountains have been significantly expanded to support questing.
* Skettis in Terokkar Forest has had some adjustments to support questing.
* Millhouse Manastorm will now only award players credit for completing the Trial of the Naaru: Tenacity upon the death of Harbinger Skyriss and only ONCE. Players will no longer receive credit through a gossip option on Millhouse.
* Goliathon, involved in the Natural Remedies quest, is now
Anbefaler Mirror 2 herfra
Nede på 1 minutt :p
8679771[/snapback]
Les første post en gang til..
Nede på 1 minutt :p
8679771[/snapback]
8679788[/snapback]
Hihi :blush:
Jaja. Skulle vel vært i en annen tråd, sånn egentlig. men men.
(Nå fikk jeg lagt den til på riktig plass)
Endret av kristteo
