P-in-P Skrevet 21. mai 2007 Skrevet 21. mai 2007 Hepp! Har installert LOTR:O og oppdatert men når jeg skal prøve å starte det kommer det opp: ----------------------- Game update progress Connect - done Examine programs - done ***Update programs - Retry (59 sec)*** Examine game data Update game data Disconnect An update error occured: HTTP 404 - Not found. ----------------------- Noen som vet hva en skal gjøre da?
Nosferatu Skrevet 21. mai 2007 Skrevet 21. mai 2007 Se her for en mulig løsning: http://community.codemasters.com/forum/sho...93&page=1&pp=10
P-in-P Skrevet 21. mai 2007 Forfatter Skrevet 21. mai 2007 (endret) Ahh, det løste det! Takk så mye for raskt svar! Edit: Hvis flere skulle ha problemet så er dette løsningen; Hi, I'm having this problem right now i notice that in the file TurbineLauncher.exe.config some of the configuration parameter still make reference to the BETA So i asked a friend of mine that have the full game to give to me the XML section of the settings Open the file with a notepad and substitute the <appSettings> section with this: <appSettings> <add key="Launcher.DataCenterService.GLS" value="http://lotroeugls.com/GLS.DataCenterServer/Service.asmx" /> <add key="DataCenter.GameName" value="LOTROEU"/> <add key="DataCenter.DefaultCenter" value="LOTROEU"/> <add key="Product.DocumentFolder" value="The Lord of the Rings Online"/> <add key="Launcher.DocumentFolder" value="Launcher"/> </appSettings> save and start the launcher then click on Continue for patching after the patch the launcher will restart.. reclick Continue (i'm doing this right now lol, the first time he download the Updater upgrade) GG Endret 21. mai 2007 av P-in-P
