Trash Talk (Xbox 360)
Trash Talk by Datel - Insult your enemies at the push of a button…
-Taunt your opponents at the touch of a button
- Don't get lost for words!
- Blast other online players with up to 16 different phrases
- Add new sound clips from absolutely any source in seconds, with simple drag'n'drop functionality
- Soundbits and recordings at the push of a button.
- Simply drag'n'drop new sounds into Trash Talk from your PC via the USB lead supplied
- Trash Talk fits between your Xbox360 controller and headset. Now you can choose from 16 sound clips ready to trash your opponent.
- Trash Talk has 4 sound banks with 4 clips in each bank. That's 16 sounds to taunt your opponent.
- Because Trash Talk clips are transfered directly from you PC you can download and use sounds from almost anywhere - movies, TV, ad's, MP3, ringtones, games and more!
- Sound clips can be any length from 1 second up to a minute - The length is fixed automaticaly.
- USB cable supplied means storing new sounds couldn't be simpler.
- High quality Arm processor with 20khz sampling means Trash Talk delivers crystal clear sounds to your opponent.
- Unique feedback feature means you can also hear the clips in your headset for maximum effect!
- Easy to use.
Trash Talker for Xbox 360 is the ultimate weapon to flame, taunt and ridicule your buddies over Xbox Live. Sitting between your game controller and your plug-in headset, Trash Talker gives you a bank of buttons which activate pre-recorded sound clips, letting you assemble your own messages and activate them at will.
You can record your own taunts and insults if you wish, but Trash Talker’s capable of much more. Why not slip in a soundbite from your favourite film or TV show, to activate during the game? If you’re injured, you could utter “I ain’t got time to bleed” in Jessie Ventura’s sepulchral growl from Predator. If you’re killed, play Arnie’s catchline, “I’ll be back!”. If a talkative opponent is getting on your nerves, play him BA from The A-Team saying, “Shut up, you crazy fool”. The possibilities are endless…
Trash Talker for Xbox 360 contains everything you need. There’s the Trash Talker unit, a USB cable to connect it to your PC and a PC application with which to manage your sounds. You can store up to 16 samples at a time, and the device has a total storage capacity of one minute.
Som om ikke det var nok av slikt fra før :D
Å herre! Er det noe vi ikke trenger mere av på LIVE er det nettopp dette.. Tror ikke denne kommer til å slå helt ann her i landet.. Men amerikanerne lever jo på det å disse andre på LIVE så kanskje noe for det markedet.. Men den kan jo mates med hva som helst.. så kanskje eg skulle kjøpt en og matet den med blomster og gode komplimenter..
