Runecloth for reputation.
Ca. hvor mye penger må jeg bruke på å dra en character fra starten av friendly til exalted av en faction?
Og ca. hvor mange runecloth blir det?
Takker for svar.
"Found out myself. The initial Donation of 60 runecloth gives 150 Rep. points. Each additional stack of 20 Runecloth gives 50 Rep. points. So:
To get from Friendly to Honored you need 6000 pts. or 120 stacks of Runecloth.
Honored to Revered you need 12000 pts. or 240 stacks of Runecloth.
Revered to Exalted you need 21000 pts. or 420 stacks of Runecloth.
In total from Friendly to Exalted it would take 15,600 pieces of Runecloth. But seeing as you can only do the Runecloth quest at lvl 60, it's going to be a lot less depending on how much Reputation you've gain during you leveling. I would suggest if you start an alt and want to get another Racial Mount, that you start out at that race's beggining area. Can't say much about Trolls and Gnomes since they don't have they're own starting area."
http://wow.allakhazam.com/db/quest.html?wquest=7832
Hvis jeg var deg ville jeg bare betalt for epic ridingskill, og så pvp'a i 2 dager, og kjøpt pvpmounten. Da kan du få black war kodo, eller noe, uten endeløs farming :yes:
