SQL=Specified key was too long. hvordan fikse?
ve_gard
SQL=Specified key was too long; max key length is 1000 bytes:
# Table structure for table `mos_core_acl_aro`
CREATE TABLE `mos_core_acl_aro` (
`aro_id` int(11) NOT NULL auto_increment,
`section_value` varchar(240) NOT NULL default '0',
`value` varchar(240) NOT NULL default '',
`order_value` int(11) NOT NULL default '0',
`name` varchar(255) NOT NULL default '',
`hidden` int(11) NOT NULL default '0',
PRIMARY KEY (`aro_id`),
UNIQUE KEY `section_value_value_aro` (`section_value`,`value`),
UNIQUE KEY `mos_gacl_section_value_value_aro` (`section_value`,`value`),
KEY `hidden_aro` (`hidden`),
KEY `mos_gacl_hidden_aro` (`hidden`)
) TYPE=MyISAM
hvordan kan jeg øke makslengden?
mvh Vegard Ofstad
