Alle console komanndoer i CS/S
CS Source
+attack primary fire
+attack2 secondary fire - special action (zoom, burst fire, silencer)
+back move backwards
+duck crouches
+forward moves forward
+jump jumps
+klook enables the keyboard to look around
+left strafes left
+lookdown looks down
+lookup looks up
+mlook enables mouse to look around
+movedown moves player down - *climbing down a ladder, swimming down
+moveleft strafes left
+moveright strafes right
+moveup moves player up - *climbing up a ladder, swimming up
+reload reloads current weapon
+right strafes right
+speed forces player to walk if 'always run' is enabled
+strafe strafe modifier - while this is held down, use direction keys to strafe in different directions
+use uses an item - such as a defuser, c4
+zoom Zooms weapon (if available)
cl_autowepswitch Automatically switch to picked up weapons (if more powerful) - * 1 is 'on', 0 is 'off'
chooseteam Choose a new team
drop Drops current weapon
force_centerview forces the player's view to look straight ahead
impulse 100 enables flashlight
impulse 201 sprays logo decal
hud_fastswitch 0 toggles fast weapon switching - * 1 is 'on', 0 is 'off'
jointeam 0=Autojoin, 1=Spectator, 2=Terrorist, 3=CT
kill player suicides to respawn again
use Use a particular weapon Arguments: <weapon_name>
autobuy Buys a predetermined set of weapons and equipment, setup in autobuy.txt
rebuy Buys all the equipment that you had when the last snapshot of your equipm
buy
buyammo1 This buys one primary magazine or clip
buyammo2 This buys one pistol clip
buyequip Show equipment buy menu
buymenu Show main buy menu
alias Alias a command
bind Bind a key to a command or set of commands (bind <cmd>)
BindToggle Creates a "bind toggle" for specific commands (Ex. BindToggle "key" "command")
con_enable 1 Allows the console to be activated
con_notifytime 8 How long to display recent console text to the upper part of the game window
contimes Number of console lines to overlay for debugging.
clear clears the console screen
cvarlist Show the list of convars/concommands.
developer 0 toggles on/off developer debug console messages - * 1 is 'on', 0 is 'off'
differences Show all convars which are not at their default values.
echo echos text to the console
exec executes a script of .cfg file
exit exit game engine without confirmation
find Find concommands with the specified string in their name/help text.
help Find help about a convar/concommand.
hideconsole Hide the console.
incrementvar Increment specified convar value.
key_findbinding Find key bound to specified command string.
key_listboundkeys List bound keys with bindings.
key_updatelayout Updates game keyboard layout to current windows keyboard setting.
mem_dump dump memory stats.
quit Exit the engine.
status Display map and connection status.
stuffcmds Parses and stuffs command line + commands to command buffer. In your valve.rc file
toggleconsole Show/hide the console.
unbind Unbind a key
unbindall Unbind all keys
wait Stop command parsing until next frame
cl_autohelp Enable/Disable Autohelp
cl_c4progressbar Draw progress bar when defusing the C4
cl_righthand Use right-handed view models.
cl_showfps Draw fps meter at top of screen (1 = fps, 2 = smooth fps)
cl_showtextmsg Enable/disable text messages printing on the screen
gameui_hide Hides/closes GUI menu
hud_centerid 0 Toggles player ID display - * 1 is 'on', 0 is 'off'
hud_deathnotice_time Sets how long death messages remain onscreen
hud_drawhistory_time Sets how long messages remain onscreen
hud_saytext_time 5 Sets how long chat messages remain onscreen
hud_showtargetid Shows target ID at cursor
messagemode Display player message globally (to all)
messagemode2 Display player message to team
name View or change a player's name
radio1 This opens up Radio1 Menu
radio2 This opens up Radio2 Menu
radio3 This opens up Radio3 Menu
revert Revert convars to their default values
scr_centertime 2 Sets how long server messages remain on the screen
say Display player message globally (to all)
say_team Display player message to team
timeleft Displays the amount ouf time remaining in the round
cl_crosshairalpha Use to change crosshair alpha, must have cl_crosshairusealpha set to "1"
cl_crosshaircolor 0=Green, 1=Red, 2=Blue, 3=Yellow, 4=Light Blue
cl_crosshairscale Use to change crosshair scale, must have cl_scalecrosshair set to "1"
cl_crosshairusealpha Enable or disable the use of crosshair alpha
cl_dynamiccrosshair Enable or disable the use of dynamic crosshair, on will make crosshair shrink when you duck for better accuracy
cl_observercrosshair Enable or disable the use of the Observer crosshair (1= On, 0=Off)
cl_scalecrosshair Enable or disable the use of crosshair scale
crosshair Enable or disable the use of crosshair (1= On, 0=Off)
cl_radaralpha Use to change radar alpha, must have cl_radartype set to "1"
cl_radartype 0=Transparent Radar, 1=Solid radar with options to change alpha using cl_radaralpha
drawradar Draws HUD radar
hideradar Hides HUD radar
cancelselect Cancels current selection
escape Escape key pressed
invnext selects next item in inventory
invprev selects previous item in inventory
lastinv selects previous item in inventory
menuselect Selects item in that slot (0-9)
slot0 select weapon group 0 (or menu item 0) see 'use' or cancels selection
slot1 select weapon group 1 (or menu item 1) see 'use'
slot2 select weapon group 2 (or menu item 2) see 'use'
slot3 select weapon group 3 (or menu item 3) see 'use'
slot4 select weapon group 4 (or menu item 4) see 'use'
slot5 select weapon group 5 (or menu item 5) see 'use'
slot6 select weapon group 6 (or menu item 6) see 'use'
slot7 select weapon group 7 (or menu item 7) see 'use'
slot8 select weapon group 8 (or menu item 8) see 'use'
slot9 select weapon group 9 (or menu item 9) see 'use'
slot10 select weapon group 10 (or menu item 10) see 'use' or cancels selection
m_filter Mouse filtering (set this to 1 to average the mouse over 2 frames)
m_forward sets the mouse forward speed sensitivity multiplier
m_pitch sets the mouse pitch (up and down motion) speed sensitivity multiplier - * negative numbers result in an inverted mouselook
m_side sets the mouse strafing speed sensitivity multiplier
m_yaw sets the yaw speed sensitivity multiplier
sensitivity Adjusts the Mouse sensitivity
zoom_sensitivity_ratio Additional mouse sensitivity scale factor applied when FOV is zoomed in
+graph Draw the network usage graph
cl_allowdownload toggles download of maps, models and decals when joining a server - * 1 is 'on', 0 is 'off'
cl_allowupload toggles upload of maps, models and decals when joining a server - * 1 is 'on', 0 is 'off'
cl_cmdbackup For each command packet, how many additional history commands are sent (helps in case of packet loss)
cl_cmdrate Max number of command packets sent to server per second
cl_interp Turns on or off whether you will interpolate object positions starting this many seconds in past
cl_interpolate Interpolate entities on the client
cl_lagcomp_errorcheck Player index of other player to check for position errors
cl_rate Sets the max bytes/sec the host can send data (Upload)
cl_updaterate Number of packets per second of updates you are requesting from the server
connect Connects to server (connect <IP>)
disconnect Disconnect game from server
net_channels Shows net channel info, a great way to determine your optimal cmdrate and updaterate settings
net_graph Draw the network usage graph
net_graphheight Sets the net_graph height
net_graphpos Sets the net_graph position onscreen (1=right, 2=center, 0 or 3=left)
net_maxfragments Max fragment bytes per packet (Ex. 1280)
net_scale Sets the net_graph scale, larger number creates larger visual graph
rate Sets the max bytes/sec the host can receive data (download)
ping Display ping to server
retry Retry connection to last server
+score Toggles score panel
+showscores Toggles score panel
togglescores Toggles score panel
jpeg Takes a jpeg screenshot: jpeg <filename> <quality 1-100>
jpeg_quality Sets jpeg screenshot quality (1 is lowest quality, 100 is highest quality) Default = 90
screenshot Take a screenshot
+voicerecord Records input from voice input device (microphone)
bgmvolume CD sound playback volume
cd Play or stop a cd track
cl_customsounds Enable customized player sound playback
play Play a sound
soundscape_fadetime Time to crossfade sound effects between soundscapes
soundscape_flush Flushes the server & client side soundscapes
stopsoundscape Stops all soundscape processing and fades current looping sounds
voice_enable Turns Voice on / off
voice_overdrive Voice Chat to Game volume ratio
voice_scale Voice Chat volume
volume Sound volume
cl_smooth Turns Smooth view/eye origin after prediction errors on and off (0 and 1)
cl_smoothtime Smooth client's view after prediction error over this many seconds (0.01 - 2.0)
fog_enable Can turn fog on or off.
fps_max Frame rate limiter (Best to use the max Hz of your monitor)
mat_antialias Antialias setting
mat_bumpmap Bumpmap Setting
mp_decals Sets the maximum number of decals
mat_dxlevel The DirectX Level. Default is optimal, but you can adjust manually here
mat_fastspecular Enable/Disable specularity for visual testing. Will not reload materials and will not affect perf.
mat_forceansio Ansio Setting
mat_monitorgamma Adjusts monitor gamma (typically 2.2 for CRT and 1.7 for LCD). Try 2.0 for a CRT
mat_specular Enable/Disable specularity for perf testing. Will cause a material reload upon change.
mat_vsync Force sync to vertical retrace / V-sync
r_decals Sets the maximum number of decals
r_propsmaxdist Maximum visible distance of props (boxes, etc)
r_rainalpha Changes rain alpha values (0=Off, higher number makes darker rain)
r_RainSimulate Enable/disable rain simulation (0=Off, 1=On)
r_shadows Enable shadows
r_WaterDrawReflection Enable water reflection
r_WaterDrawRefraction Enable water refraction
benchframe Takes a snapshot of a particular frame in a time demo
cl_demoviewoverride Override view during demo playback
demo_debug Demo debug info
demo_fastforwardfinalspeed Go this fast when starting to hold FF button
demo_fastforwardramptime How many seconds it takes to get to full FF speed
demo_fastforwardstartspeed Go this fast when starting to hold FF button.
demo_interpolateview Do view interpolation during dem playback
demo_pauseatservertick Pauses demo playback at server tick
demo_quitafterplayback Quits game after demo playback
demo_recordcommands Record commands typed at console into .dem files
demogototick Skips to a tick in demo
demolist Print demo sequence list
demopause Pauses demo playback
demoresume Resumes demo playback
demos Demo demo file
demotimescale Sets demo replay speed
demotogglepause Toggles demo playback
demoui Show/hide the demo player UI
listdemo List demo file contents
nextdemo Play next demo in sequence
playdemo Play a recorded demo file (.dem )
record begins to record a demo and saves it as a .dem file
startdemos Play demos in demo sequence
stop Finish recording demo
stopdemo Stop playing back a demo
timedemo Play a demo at max fps and report performance info and average fps
timedemoquit Play a demo, report performance info, and then exit
endmovie Stop recording movie frames
startmovie Start recording movie frames
CS
+duck crouches
+jump jumps
+left strafes left
+lookup looks up
+showscores shows player scores and pings
+speed forces player to walk if 'always run' is enabled, and forces player to run if 'always run' is disabled
+use uses an item- such as a button, machine gun, etc.
adjust_crosshair Use to change crosshair color
alias "cmd1; cmd2" binds commands together in an alias to perform mutiple tasks at the hit of one button
allowupload toggles the uploading of local decals and models to the server on/off
ambient_fade 100 sets the distance at which ambient sounds fade away
ambient_level 0.300 sets the sound level for ambient sounds
appenddemo records a demo and appends it to the demo file in existence at Half-Life/Valve/demo.dem
bind combines a with a command or alias
bottomcolor 6 sets the bottom color of the player model
brightness 1 enables glare reduction - *the higher the value, the brighter it gets
buy This opens the Buy Menu
buyequip This opens the Buy Equipment Menu
cancelselect cancels selection
chooseteam displays the team change menu
cl_allowdownload 0 toggles download of maps, models and decals when joining a server - * 1 is 'on', 0 is 'off'
cl_allowupload 0 toggles upload of maps, models and decals when joining a server - * 1 is 'on', 0 is 'off'
cl_anglespeedkey 0.670 sets the speed that the direction keys change the view angle
cl_backspeed 400 sets the backup speed of a player - number can only go as fast as a particular server allows
cl_bob 0.010 sets the amount that the view bobs while the player is running
cl_bobcycle 0.800 sets how frequently the view of a player bobs while running
cl_bobup 0.500 sets the amount that the view of a player bobs while running
cl_download_ingame 0 toggles downloads of models and decals during a game - * 1 is 'on', 0 is 'off'
cl_forwardspeed 400 sets the forward speed of a player - *can only go as fast as the server allows
cl_gaitestimation 1 enables estimated player stepping motion
cl_hidefrags Set to 1 to hide all frag/death counts on the Scoreboard but your own, 0 to show
cl_gg 0 toggles game gauge mode - * 1 is 'on', 0 is 'off'
cl_himodels toggles higer quality player models - * 1 is 'on', 0 is 'off'
cl_messages shows server messages
cl_movespeedkey 0.300 sets movement speed for keyboard use
cl_nopred 0 toggles client-side prediction - * 1 is 'on', 0 is 'off'
cl_observercrosshair set to 1 to enable crosshairs in Observer mode, 0 to disable
cl_pitchdown sets the maximum angle to look down - *default is 89
cl_pitchspeed 225 sets the speed at which the pitch changes
cl_pitchup sets the maximum angle to look up - *default is 89
cl_showfps 1 This shows your FPS, default is 0 off, and 1 is on. Better than netgraph for saving FPS
cl_shownet 0 toggles the display of network packet numbers - * 1 is 'on', 0 is 'off'
cl_slist 10 sets the number of servers in the serverlist
cl_solid_players 1 toggles solid player models - * 1 is 'on', 0 is 'off'
cl_upspeed 320 sets the speed of a player when he climbs up
cl_waterdist 4 sets the underwater distance
cl_yawspeed 210 sets the turning speed - * only will go as fast as a server allows
cmd can use this in conjunction with a command
cmdlist lists all of the console commands - * if you type 'cmdlist a', it will only list those commands that begin with the letter a, and so on - also, 'cmdlist log logfile writes the list to C:\logfile
concolor "XXX XXX XXX" changes the color of your HUD, where the XXX is a value from 0-255
connect connects to a server with the used ip address
cvarlist lists all the console variables in the console - * 'cvar log filename' will write this list to the file C:\filename
developer 0 toggles on/off special developer debug console messages - * 1 is 'on', 0 is 'off'
disconnect disconnects a player from a server
drawradar This shows your friendly radar; "hideradar" hides it
drop This drops whatever is in your hands at the time you use it
echo "message" echos text to the console - * useful for letting a player know that a script or .cfg file was loaded successfully
enableconsole enables the console screen
escape acts as key by hiding the console and cancelling selections
exit closes a game or dedicated server program to windows without confirmation
fakelag 0 simulates lag - * the higher the number, the more simulated lag
fakeloss 0 simulates packet loss - * the higher the value, the more simulated packet loss
fastsprites X x=0:regular smoke grenade,1:simple smoke grenade(default),2:very simple smoke grenade
fps_lan sets the maximum framerate on a LAN game
fps_modem sets the maximum framerate in an internet game
fps_single sets the maximum framerate in a single playergame
fullinfo displays user information
fullserverinfo displays server information
gamma 3 sets the gamma level
getcertificate gets certificate from WON
getsv lists each server's ip address and the total number of servers
gl_alphamin 0.250 sets the minimum alpha blending level
gl_clear 0 toggles visual quality - * cracks between textures show when set to 1
gl_cull 1 toggles rendering of visible objects only - * 1 is 'on', 0 is 'off', and 0 will lower fps
gl_d3dflip 0 toggles reversed rendering order for D3D
gl_dither 1 toggles dithering - * 1 is 'on', 0 is 'off'
gl_dump lists the data for the video card: vendor, renderer, version, and extensions used
gl_flipmatrix 0 toggles special crosshair fix when using the 3DNow! 3Dfx MiniGL - * 1 is 'on', 0 is 'off'
gl_keeptjunctions 0 toggles showing of cracks between textures - * 1 is 'on', 0 is 'off', with 1 being the better quality and slower fps
gl_lightholes 0 toggles light holes - * 1 is 'on', 0 is 'off'
gl_max_size 256 sets the maximum texture size
gl_monolights 0 toggles a uniform light source with no shadows - * 1 is 'on', 0 is 'off', and works in OpenGL only
gl_overbright 0 toggles maximum brightness mode - * 1 is 'on', 0 is 'off'
gl_palette_tex 0 toggles paletted textures - * 1 is 'on', 0 is 'off'
gl_picmip 0 sets the rendering quality - * higher the number is faster but lower quality
gl_playermip 0 sets the player rendering quality - * higher the number is faster but lower quality
gl_polyoffset 4 sets the polygon offset - try out different values for texture flickering problems
gl_round_down 3 sets the texture rounding down value - * higher the number faster but lower quality
gl_smoothmodels 0 toggles model smoothing - * 1 is 'on', 0 is 'off'
gl_spriteblend 0 toggles blending sprite graphics - * 1 is 'on', 0 is 'off'
gl_texels reports the number of texels uploaded to the video card
gl_texsort 0 toggles a texel sort - * 1 is 'on', 0 is 'off'
gl_texturemode [type] sets the rendering mode in order from the lowest quality but fastest to highest quality which is slower - * [type] options are: gl_nearest_mipmap_nearest, gl_linear_mipmap_nearest (these two deal with bilinear filtering) and gl_nearest_mipmap_linear, gl_linear_mipmap_linear (which deals with trilinear filtering)
gl_zmax 4096 sets the maximum size for the Z-Buffer
gl_ztrick 1 toggles the speeding up of 3Dfx rendering - * 1 is 'on', 0 is 'off'
graphheight 64 sets the height of the r_netgraph display
graphhigh 512 sets the maximum value of the r_netgraph display
graphmean 1 sets the mean value of the r_netgraph display
graphmedian 128 sets the median value of the r_netgraph display
hideconsole hides the console
hideradar hides the radar
hisound 1 toggles high-quality sound - * 1=22kHz, 0=11kHz
hud_centerid 0 toggles player ID display - * 1 is 'on', 0 is 'off'
hud_saytext_time 5 sets how long chat messages remain onscreen
lightgamma 2.500 sets the lighting gamma value
listdemo lists information about
lookspring 0 toggles automatic view centering when 'mlook' is deactivated - * 1 is 'on', 0 is 'off'
lookstrafe 0 toggles mouse strafing when 'mlook' is active - * 1 is 'on', 0 is 'off'
m_filter 0 toggles mouse filtering (smoothing) - * 1 is 'on', 0 is 'off'
m_pitch 0.022 sets the mouse pitch (up and down motion) speed sensitivity multiplier - * negative numbers result in an inverted mouselook
m_side 0.800 sets the mouse strafing speed sensitivity multiplier
m_yaw 0.022 sets the yaw speed sensitivity multiplier
max_shells X X = maximum number of shells at one time
max_smokepuffs X X = max. number of smoke puffs at one time
menuselect X selects item X from a menu
messagemode displays to all other players on a server
messagemode2 displays to only other players on same team
motd displays the Message Of The Day from the server's motd.txt file
name used to change a player's name
net_graph 1 this shows your fps, network latency, up & downstream bandwidth, and your client and server update rate. net_graph 0 turns it off, net_graph 3 shows the info without the graph and saves some fps.
nosound 0 toggles sound - * 1 is 'on', 0 is 'off'
pingsv pings a server at
play plays a .wav designated by
playdemo plays .dem at normal speed
playvol 9 sets demo playback volume
pushlatency -100 set this number to the inverse of your ping to help latency
quit exits to windows without confirmation
r_decals 250 sets the maximum number of decals
r_drawviewmodel 0 toggles drawing player weapon model - * 1 is 'on', 0 is 'off'
r_dynamic 0 toggles dynamic lighting - * 1 is 'on', 0 is 'off'
r_mmx 0 toggles MMX calculations for MMX cpu's - * 1 is 'on', 0 is 'off'
r_netgraph 0 toggles graph of network conditions - *0 is 'off', 1 shows green = good, yellow = bad, red = horrible, 2 shows packetsize
rate 5000 sets client data rat -*1000 - 5000 for modems, 10000+ for LAN
reconnect reconnects to the current server
record begins to record a demo and saves it to Half-Life\Valve\.dem
retry tries four more times to connect to a server that has already failed four connect attempts
s_2dvolume 1 maximum volume at which 2D sounds are played - * range from 0 to 1.0
s_a3d 0.000000 toggles A3D support - * 1 is 'on', 0 is 'off'
s_automax_distance 30 sets the distance for maximum sound volume
s_automin_distance 2 sets the distance for minimum sound volume
s_bloat 2.0 bloat factor for polygons in A3D 2.0 only
s_buffersize 65536 sets the buffer size
s_disable_a3d 0 toggles disabling a3D - * 1 is 'on', 0 is 'off'
s_distance 60 adjust the ratio of game units to meters, affecting velocity, positioning and distance - * higher the number, the closer everything gets in audio terms - range from 0 to infinity
s_doppler 0.0 adjusts the doppler - * 1 is 'on', 0 is 'off', range from 0 to 10, and is very sensitive
s_eax 0 toggles EAX support - * 1 is 'on', 0 is 'off'
s_enable_a3d enables A3D support
s_geometry 0 toggles geometry rendering in A3D 2.0 only - * 1 is 'on', 0 is 'off'
s_max_distance 1000 maximum distance from the listener before rolloff is no longer applied - * valid range from 's_min_distance' to infinity
s_min_distance 5 minimum distance a source will be from the listener before rolloff is applied - * range from 0 to 's_max_distance'
s_numpolys 200 maximum polygons to be rendered in A3D 2.0 only - setting this to 0 is the same as turning off 's_geometry' - * range from 0 to infinity
s_occfactor 0.250 transmission value of material - the smaller the number, the less sound passes through material - * range from 0 to 1.0
s_occlude 0 toggles sound passing throug material (occlusions) in A3D 2.0 only - * 1 is 'on', 0 is 'off'
s_refdelay 4 delays between a source and its closest reflection in A3D 2.0 only - higher the delay, the more time it takes between when the source and its first reflection is played - * range from 0 to 100
s_refgain 0.4 adjusts the gain on each reflection in A3D 2.0 only, where the effects of distance are increased: high frequencies are filtered and volume lowered - * range from 0 to 10
s_verbwet 0.25 controls the wet/dry mix of reverb for A3D only - higher the number, the more wet the sounds - * range from 0 to 1.0
say "message" chat with all other players on a server
say_team "message" relay a message to only your teammates
scr_centertime 2 sets how long server messages remain on the screen
scr_conspeed 600 sets the console scroll speed
scr_printspeed 7 sets the screen message print speed
screenshot captures the screen and saves it in the Half-Life/Valve directory
sensitivity 9 sets the sensitivity of the mouse
serverinfo displays the server infromation
setdemoinfo info adds information to a demo, such as a text title, play 'tracknum', fade or
setinfo - * i.e., 'setinfo "ts" "0"' or 'setinfo "dc" "0"'
showbriefing This shows the map briefing
showinfo 0 toggles display of all packets - * 1 is 'on', 0 is 'off'
showpackets 0 toggles network packet info display - * 1 is 'on', 0 is 'off'
showpause 0 toggles pause of graphic display - * 1 is 'on', 0 is 'off'
showram 0 toggles display of available ram - * 1 is 'on', 0 is 'off'
sizedown decreases screen size and increases fps
sizeup increases screen size and decreases fps
setinfo vgui_menus X X = 0 or 1, 0 disables VGUI menus, 1 enables VGUI menus
snapshot takes a screenshot
speak to say something over the intercom - * try: hello, #000000, mesa, you, go alert
startdemos begins playing demos in a loop
stop stops the recording of a demo
stopdemo stop the playing of a demo
stopsound stops playing the current sound
swapdemo swaps two segments' positions inside a demo
timedemo plays .dem at max fps and reports average fps
timeleft displays the amount ouf time remaining in the round
toggleconsole toggles the console screen - * usually bound to '~'
topcolor 30 sets the model top color
unbind removes binding to key
unbindall removes all key bindings
use uses an item or weapon, such as 'use weapon_crowbar'
vid_config_x 800 sets horizontal screen resolution
vid_config_y 600 sets vertical screen resolution
vid_d3d 0 toggles Direct3D support - * 1 is 'on', 0 is 'off'
vid_describemode displays video mode settings
vid_mode 0 sets video mode
vid_nopageflip 0 toggles disabling video page flipping - * 1 is 'on', 0 is 'off'
vid_wait 0 toggles video sync - * 1 is 'on', 0 is 'off'
viewframe enables wire-frame display - * OpenGL only
violence_ablood 0 toggles blood - * 1 is 'on', 0 is 'off'
volume 1.0 sets game volume
weapon_ Pistols - glock18/usp/deagle/p228/elite/fiveseven
Submachineguns - mp5navy/p90/tmp/mac10/ump45
Assault Rifles - ak47/sg552/m4a1/aug ~Shotguns - m3/xm1014
Sniper Rifles - scout/awp/g3sg1/sg550 ~ Machinegun - m249
Other - c4/knife ~Grenades -flashbang/hegrenade/smokegrenade
- This selects the weapon directly, by binding a key like "h" to weapon_knife, and pressing "h", you pull out the knife
wait pauses for 1 tick during running an alias or script
Endret av Erelend
  • 2 måneder senere...
Ligger de ikke igjen hele runden?
7118248[/snapback]
Ikke på day of defeat source, hadde vært helt rått å se alle ligge igjen. Sikkelig kirgs følelse ^^
Hva skal dette være godt for?
Er jo bare en liste over kommandoer du kan finne rundt 1000 andre steder på internett, og det er vel ikke gjort noe mer med den enn å poste den her på forumet?
Det skal ligge tid bak en god guide, og ikke bare kopier + lim.
Hadde du oversatt alt og forklart bedre på norsk hva de forskjellige kommandoene gjør, hadde det nok blitt en sticky, og ganske interessant.
For dumt med slike tråder på hele forumet all the time.
Rapportert for spam
Guider skal ikke bare kopieres og limes inn fra andre steder, da det da er snakk om kopibeskyttelse etc. Ikke minst er dette et norsk forum så jeg vil tro at norske guider er ønsket here.
Gjest
