"Modified Content" Når jeg går inn på BF2: EU serv
HEI!
Får En F******* plagsom error når jeg går inn på battlefield 2 euro forces server..
This server only allows players with unmodified content to join. Revert your version of Battlefield 2 to the current offical version to join.
Bruker 2.3 patchen.
Hvordan kan jeg få fikset dette?
Takk for alle svar!
Jeg for også denne meldingen når jeg prøver å komme meg inn for å få prøvd EF, skulle ikke forundre meg om at det er på grunn av 1.3 patchen :( .
6197180[/snapback]
Ok, håper jeg får no svar snart :cry:
Fikk samme melding idag, eneste som funka for meg var å reinstallere.
"Must have unmodified content" or "Data differs from Server" errors.
Answer
If your Battlefield 2 or Battlefield 2 Special Forces installation has become corrupt, either through the use of unsupported modifications to the game, or a corrupted patch or installation, you may receive one of these errors when attempting to connect to an online game.
To resolve this issue, Battlefield 2 and any expansions must be uninstalled from your computer and reinstalled from scratch. This replaces corrupted game files and will allow you to connect to online games successfully
If you have Special Forces installed, you will need to uninstall that expansion first, then the regular version of Battlefield 2. These uninstalls can be done automatically by using the Uninstall Battlefield 2 or Uninstall Battlefield 2 Special Forces programs located in the respective game's Program folder in the Start menu. If the automatic uninstalls do not work, manual uninstalls can be performed by following the instructions located here for Battlefield 2 and Battlefield 2 Special Forces.
Once the games have been successfully uninstalled, reinstall them as you did before. You should now be able to access online games successfully.
Answer
6197732[/snapback]
Tusen takk, skal teste det etterpå, har installert noen mods, kanskje det er det :thumbup:
Hadde det samme problemet med EF, det du må gjøre er å innstalere patchen etter du har innstalert EF, så det er bare til å innstalere patchen.
fra EA sine supportsider:
If you have the Euro Forces Booster Pack the 1.3 patch must be installed after you install Euro Forces, otherwise content errors will arise. If you have installed the 1.3 patch before you have installed Euro Force, please re-install the 1.3 patch and try the game again.
If you still receive an unmodified content error there will be a corruption in one of the data files. Please follow the steps below:
Uninstall Battlefield 2: Special Forces (if applicable), and the Battlefield 2 base game using the uninstall program, Add/Remove Programs, or manual uninstall for Battlefield 2 and Battlefield 2 Special Forces (if applicable).
Install Battlefield 2.
Install Battlefield 2: Special Forces (if applicable).
Install the latest patch.
Install Battlefield 2: Euro Forces
Once you have completed installation please try the game again. If you still have an issue please Install the latest patch once again
