Får ikke logga på MSN
Hei.
Jeg bruker Windows Live Messanger 8.0 BETA.
Når jeg starta dataen idag, og skulle logge på, så måtte jeg oppdatere versjonen min.
Jeg trykka "ja", og den begynte å laste ned.
Men når den driver å instalerer så får jeg denne erroren;
Hvordan får jeg fikset det? :hmm:
Gjest member-96408
Restarte PCen :)
Mvh Ruben
Tuuuusen takk :love:
Gjorde som han ene sa;
Uninstall ANY version of MSN Messenger you have...
Now... First delete the following folders:
• C:\Documents and Settings\<username>\Application Data\Microsoft\MSN Messenger [Note you will lose any content you have downloaded from Blue Mountain]
• C:\Program Files\MSN Messenger
Then download whichever MSNM you want (Link to 7.5.0244 - ENG)
Then using WinRAR extract only MsnMsgs.msi from Install_MSN_Messenger.exe. You can do this by opening WinRAR first then by double click on the Install_MSN_Messenger.exe - then click and drag MsnMsgs.msi to your desktop.
Reboot.
Log back in and run the MSI - continue as normal.
^^^That's what I would do^^^
@heliologue, Sphere - Stay on topic. BigOne asked how to fix the error not which alternative IM client he should use.
Nok en takk til deg :love:
