God grindebuild til warlock
Hei, jeg startet en warlock igår, jeg har aldri spilt warlock før og lurer på hvor jeg skal sette talents? Skal levle til 60.
Vil si at Affliction desidert er den beste veien og gå.
Selv levlet jeg warlock fra 58-60 på runt om 6timer med rested dog, men uansett så er affiliction vannvittig mana efficient hvilket gjør du har lite downtime :)
1. Dark Pact (Grinding build) (32/8/11)
A leveling build, considered by many to be the best grinding talent build in the game. Get to Dark Pact ASAP, then get Shadowburn, then DE then Improved Imp IMO. Please read my FAQ (also stickied) for information on "drain tanking" and grinding.
The problem with grinding with builds like SL/NF and SM/Ruin is that you will never have the main benefits of either tree until near level 60. While Soul Link definately is a powerful option by level 40, you're going to lack good grinding talents such as Improved Corruption, Fel Concentration, and Amplify Curse. At level 40 with a Dark Pact build, you will have almost no downtime as well as all the grinding options given to you by Affliction.
That being said, there are Warlocks who prefer to level with DS. Please read the FAQ about this debate.
Dark Pact is a grinding build, and is considered to be a weak build once your Warlock hits level 60. This is because Demonic Sacrifice becomes a much better option has you have more HP and talents, and Improved Life Tap regenerates mana more than twice as fast as Dark Pact. Dark Pact eventually just becomes a mana regaining ability that doesn't suck up healer mana or bandages. Most Warlocks respec near level 60.
Link
