Applikasjoner til NVIDIA skjermkort drivere
Eijnar
Hei!
Har akkurat installert nye nVidia drivere og ser at det er 2 applikasjoner til den som starter opp med Windows: "NvCplDeamon" og "NvMediaCenter".
Er disse nødvendige eller kan jeg fjerne dem med god samvittighet?
Mvh.
ZinnX
Tiltredes.
Gå gjerne inn i kontrollpanel/administrative verktøy/tjenester og deaktiver nvidia driver helper også.
5761304[/snapback]
Deaktiverer jeg ikke selve driveren da? :dontgetit:
http://www.pcstats.com/articleview.cfm?art...id=1590&page=32
98. Disable the Nvidia driver helper service
This service, included with recent NVIDIA Detonator driver packages, is of indeterminate function. Nothing is found on the NVIDIA site about it, and the only thing that people in the hardware community can seem to agree on is that it can considerably slow down boot up time and especially shutdown time.
Hence, if you do have an Nvidia video card, consider searching for and disabling this service. Chances are it will improve your shutdown times.
:thumbup:
