MATLAB på XP x64 (ACML, BLAS og andre buskvekster)
dravisher
Heisan.
Jeg skal snart gå til anskaffelse av MATLAB i forbindelse med studie på UiO. Jeg bruker Windows XP x64 ed., og har funnet ut at å få MATLAB til å fungere på XP x64 kan være vanskelig. Jeg spurte mathworks support om dette:
Hi,
There are no current Student Versions of MATLAB that support a 64-bit processor.
While running MATLAB Student Version on a 64-bit processor is not supported,
some users have reported success after updating their BLAS version to work with
the 64-bit processor. See the following solution for more information:
http://www.mathworks.com/support/solutions...olution=1-18QUC
We don’t know if the next MATLAB Student Version will support a 64-bit
processor and we don’t either know when it will be released.
We do not offer an upgrade from previous Student Versions to the most current
version you need to purchase a new copy of the Student Version.
Best Regards,
Anna Källander
-----Original Message-----
Subject:  MATLAB student version on Windows XP x64
I am considering buying a MATLAB student version (I would be purchasing the
most current version), and I am wondering if this version will work in its
current state on Windows XP x64 (x86-64, not Itanium). I have seen mention
of a beta for XP x64, but I have not been able to find out if this is a
necessary release to be able to run MATLAB on XP x64, or if it is simply for
performance benefits. If the current (32-bit) version of MATLAB for students
does not work on XP x64, will the x64 version be available to me (when it is
out of beta) if I purchase the current MATLAB student version, or will these
be two different licenses?
Thank you for any help.
Når jeg følger linken oppgitt skjønner jeg det slik at jeg burde skaffe ACML (AMD Core Math Library) 3.0, siden denne inneholder en BLAS (Basic Linear Algebra Subroutines) versjon som vil fungere samme med MATLAB på XP x64. Problemet er at ACML ser ut til å være tilgjengelig kun for medlemmer av AMD Developer Program. Det jeg lurer på er om noen vet om andre måter å skaffe dette på (men det er vel antageligvis ikke lovlig å skaffe det gjennom andre enn AMD), eller om det er andre BLAS versjoner som kanskje kan fungere? Jeg har ikke prøvd MATLAB enda, men utifra svaret fra mathworks så vil jeg tro jeg trenger en annen BLAS versjon enn den som følger med XP eller MATLAB (har ikke peiling på hva BLAS er, så jeg vet ikke om det er en versjon med OS eller ikke).
Takker for hjelp.
