god pvp warlock build
Hei
Jeg er en lvl 15 gnome warlock, lurer på hvordan build jeg skal begynne med. lag gjerne en template
(her)
noen ideèr? (PvP build)
takker på forhånd :)
Hei
(her)
5050977[/snapback]
Saved Template
Class: Warlock
Level: 60
Affliction Talents (7 points)
Improved Corruption - 5/5 points
Reduces the casting time of your Corruption spell by 2 seconds.
Improved Life Tap - 2/2 points
Increases the amount of Mana awarded by your Life Tap spell by 20%.
Demonology Talents (7 points)
Improved Healthstone - 2/2 points
Increases the amount of Health restored by your Healthstone by 20%.
Demonic Embrace - 5/5 points
Increases your total Stamina by 15%, but reduces your total Spirit by 5%.
Destruction Talents (37 points)
Improved Shadow Bolt - 5/5 points
Your Shadow Bolt critical strikes increase the next 4 sources of Shadow damage dealt to the target by 20%. Effect lasts a maximum of 12 seconds.
Bane - 5/5 points
Reduces the casting time of your Shadow Bolt and Immolate spells by 0.5 seconds.
Aftermath - 2/5 points
Gives your Destruction spells a 4% chance to daze the target for 5 seconds.
Shadowburn - 1/1 point
Instantly blasts the target for 87 to 99 Shadow damage. If the target dies from Shadowburn, and yields experience or honor, the caster gains a Soul Shard.
Level 24: 115 to 131 damage
Level 32: 186 to 210 damage
Level 40: 261 to 293 damage
Level 48: 350 to 392 damage
Level 56: 450 to 502 damage
Devastation - 5/5 points
Increases the critical strike chance of your Destruction spells by 5%.
Destructive Reach - 2/2 points
Increases the range of your Destruction spells by 20%.
Improved Searing Pain - 3/5 points
Increases the critical strike chance of your Searing Pain spell by 6%.
Intensity - 2/2 points
Gives you a 70% chance to resist interruption caused by damage while channeling the Rain of Fire or Hellfire spell.
Ruin - 1/1 point
Increases the critical strike damage bonus of your Destruction spells by 100%.
Improved Immolate - 5/5 points
Increases the initial damage of your Immolate spell by 25%.
Emberstorm - 5/5 points
Increases the damage done by your Fire spells by 10%.
Conflagrate - 1/1 point
Ignites a target that is already afflicted by Immolate, dealing 197 to 251 Fire damage and consuming the Immolate spell.
Level 48: 259 to 325 damage
Level 54: 315 to 393 damage
Level 60: 367 to 457 damage
Påstand: Vel, til å begynne med burde du gå Affliction eller Demonology, uansett, på level 40 burde du ta Dark pact.
Begrunnelse: med dark pact + imp eller felhunter kan du holde det gående evig, null nedetid altså.
På level 60 er det litt av hvert å prøve egentlig, selv er jeg trofast tilhenger av ShadowMastery/Ruin (30/0/21) mens mange andre liker MasterDemo/Ruin (0/30/21) og noen igjen går for conflag, men da ville jeg kjørt 7/8/36. Samme som over her, men ville hatt impoved imp i stedet for healthstone. Intensity var bortkasta, ikke blitt så mye bedre egentlig, ville gått for improved Imp i destro , jeg hadde 140dps på Impen tidligere. Improved Shadowbolt hører ikke helt hjemme i en Conflagbuild, men 5% mindre mana er ikke all verden uansett så..
Min conflag: http://www.wow-europe.com/en/info/basics/t...550105102505151
Current build: http://www.wow-europe.com/en/info/basics/t...050025102000100
Har forøvrig +353dmg på gear.
Endret av Sub-Lock
