Hvor skal eg bruke resten av talent pointene?
Jeg har nå nådd lvl 53, og jeg lurer på hvordan jeg skal bruke de siste 8 talent pointsene..... Jeg har vurdert å bruke resten i Holy, ettersom jeg ikke har noe å bruke de på i Shadow, og jeg har imp. shield og focused casting. Burde jeg bruke de på holy, ettersom jeg er healer i instancer, eller burde jeg bruke de på disc?
Talents
Talents
31/20 ftw!
:ermm: hva i skoggudenes navn er det for en bulid ?
shadow specc UTEN blackout? og reduced threat ?
slenger heller opp en ny en så du kan respecce!
Discipline Talents (10 points)
Unbreakable Will - 5/5 points
Increases your chance to resist Stun, Fear, and Silence effects by 15%.
Improved Power Word: Shield - 3/3 points
Reduces the duration of your Power Word: Shield's Weakened Soul effect by 15 seconds.
Martyrdom - 2/2 points
Gives you a 100% chance to gain the Focused Casting effect that lasts for 6 seconds after being the victim of a critical strike. The Focused Casting effect prevents you from losing casting time when taking damage.
Holy Talents (0 points)
None
Shadow Talents (32 points)
Spirit Tap - 5/5 points
Gives you a 100% chance to gain a 100% bonus to your Spirit after killing a target. For the duration, your Mana may regenerate at a 50% rate while casting. Lasts 15 seconds.
Blackout - 5/5 points
Gives your Shadow damage spells a 10% chance to stun the target for 3 seconds.
Improved Shadow Word: Pain - 2/2 points
Increases the duration of your Shadow Word: Pain spell by 6 seconds.
Improved Mind Blast - 2/5 points
Reduces the cooldown of your Mind Blast spell by 1 second.
Improved Psychic Scream - 2/2 points
Reduces the cooldown of your Psychic Scream spell by 4 seconds.
Mind Flay - 1/1 point
Assault the target's mind with Shadow energy, causing 75 damage over 3 seconds and slowing the target to 50% of their movement speed.
Level 28: 126 damage over 3 seconds
Level 36: 186 damage over 3 seconds
Level 44: 261 damage over 3 seconds
Level 52: 330 damage over 3 seconds
Level 60: 426 damage over 3 seconds
Shadow Reach - 3/3 points
Increases the range of your Shadow damage spells by 20%.
Silence - 1/1 point
Silence the target, preventing them from casting spells for 5 seconds.
Shadow Weaving - 5/5 points
Your Shadow damage spells have a 100% chance to cause your target to be vulnerable to Shadow damage. This vulnerability increases the Shadow damage dealt to your target by 3% and lasts 15 seconds. Stacks up to 5 times.
Darkness - 5/5 points
Increases your Shadow spell damage by 10%.
Shadowform - 1/1 point
Assume a Shadowform, increasing your Shadow damage by 15% and reducing Physical damage done to you by 15%. However, you may not cast Holy spells while in this form.
prøv det først du så kan du fortsette med shadow focus til den er 5\5 og kansje VAMP. embrace er lurt og ta med seg?
EDIT: imo PW.fortitude er også digg samtidig som mental agility er viktig så det blir de neste talentene og satse på tror jeg
Endret av digitalglenn
