HW.no Diablo 2 team
Nei, ingen reset enda.
Trekker tilbake alt jeg sa om tider på resetten, alt er/var bare brukere som antok når det kom til skje. Det er ikke kommet et tidspunkt fra noen offisielle personer enda så det eneste en kan gjøre er være tålmodig.
Endret av Spilloman
Har litt info til dere noen kan sikkert masse av dette fra før men dette er kjekt og vite.
http://www.battle.net/diablo2exp/items/cube.shtml
1 Lum Rune + 1 Pul Rune + 1 Perfect Emerald + Exceptional Unique Weapon = Elite Version of Weapon (Ladder Only)
This formula changes the base item type from the exceptional to elite version. For example a Cleaver is turned into a Small Crescent. This does NOT convert the item to the Elite Unique version of the Exceptional Unique Item. Unique item bonuses remain the same; only the item it's based on is upgraded. This can be used to upgrade Ethereal Items also. They will continue to be Ethereal after they are upgraded. You cannot do this formula unless you are using a Ladder Character. Also if the item is socketed, then jewels or runes and their mods will also remain.
1 Ko Rune + 1 Lem Rune + 1 Perfect Diamond + Exceptional Unique Armor = Elite Version of Armor (Ladder Only)
This formula changes the base item type from the exceptional to elite version. For example Ghost Armor is turned into a Dusk Shroud. This does NOT convert the item to the Elite Unique version of the Unique Item. Unique item bonuses remain the same; only the item it's based on is upgraded. This can be used to upgrade Ethereal Items also. They will continue to be Ethereal after they are upgraded. You cannot do this formula unless you are using a Ladder Character. Also if the item is socketed, then jewels or runes and their mods will also remain. Armor refers to any sort of armor, including helms, boots, belts, gloves and shields, not just body armor.
1 Ral Rune + 1 Sol Rune + 1 Perfect Emerald + Normal Unique Weapon = Exceptional Version of Weapon
This formula changes the base item type from the normal to exceptional version. For example an Axe is turned into a Cleaver. This does NOT convert the item to the Exceptional Unique version of the Unique Item. Unique item bonuses remain the same; only the item it's based on is upgraded. This can be used to upgrade Ethereal Items also. They will continue to be Ethereal after they are upgraded. Also if the item is socketed, then jewels or runes and their mods will also remain.
1 Tal Rune + 1 Shael Rune + 1 Perfect Diamond + Normal Unique Armor = Exceptional Version of Armor
This formula changes the base item type from the normal to exceptional version. For example Quilted Armor is turned into Ghost Armor. This does NOT convert the item to the Exceptional Unique version of the Unique Item. So you cannot for example use this formula to transform Greyform into The Spirit Shroud. Unique item bonuses remain the same; only the item it's based on is upgraded. This can be used to upgrade Ethereal Items also. They will continue to be Ethereal after they are upgraded. Also if the item is socketed, then jewels or runes and their mods will also remain. Armor refers to any sort of armor, including helms, boots, belts, gloves and shields, not just body armor.
Dette kan gjøre en eth skuldersire til nesten ca 2k def!
linker til guider:
Sorc:
http://strategy.diabloii.net/searchcat?cid=39&type=1.10
pala:
http://strategy.diabloii.net/searchcat?cid=35&type=1.10
nekro:
http://strategy.diabloii.net/searchcat?cid=33&type=1.10
Druid:
http://strategy.diabloii.net/searchcat?cid=31&type=1.10
Barbar:
http://strategy.diabloii.net/searchcat?cid=27&type=1.10
Azza:
http://strategy.diabloii.net/searchcat?cid=29&type=1.10
amazon:
http://strategy.diabloii.net/searchcat?cid=25&type=1.10
Gjest Slettet-IBL5Pam9QB
Blizzard holder på og stenger serverne nå, så det blir snart.
Da ble det realm down, så reset er like rundt hjørnet. :w00t:
noen som blir med å tar diablo nå??
Må lvle opp litt mer først jeg :whistle:
Edit Helvete jeg hater dette spillet :p
Endret av Ø.B.
Hva er account-navnene deres? Min er Tvk
