Nero - verify disc , hva menes med det?
zarz
Verify data on disc after burning: It verifies that the data that was suppose burned, was burned. Most likely, the CD will burn fine, and if it doesn't, it'll tell you during the burn. You can leave this on (on by default) if you to feel extra safe. This, of course, doesn't protect you from what you wanted to burn, but dragged the wrong file into the burning window.
