Talent Points Druid
Er level 46 Tauren Druid på Silvermoon, og føler at jeg ikke har vært konsekvent nok på mine fordelinger av Talent Points og ønsker derfor å endre disse.
Er det noen som har en link til en guide som kan hjelpe meg med dette, da jeg ikke får bestemt meg for hva jeg ønsker?
Endret av gstavdal
Er lvl 60 no og:
Har 1 i balance: Natures grasp
11 i feral for å få chargen,
og 39 i restoration,
kan godt greie deg med 31 i restoration for å si det sånn,
Eneste jeg anbefaler deg å ikke bruke talent points på er cat-formen.
Gjest Slettet+987123897
Balance Talents (5 points)
# Improved Wrath - 5/5 points
Reduces the cast time of your Wrath spell by 0.5 seconds.
Feral Combat Talents (13 points)
# Ferocity - 5/5 points
Reduces the cost of your Maul, Swipe, Claw, and Rake abilities by 5 Rage or Energy.
# Improved Bash - 2/2 points
Increases the stun duration of your Bash ability by 1 second.
# Sharpened Claws - 5/5 points
Increases your critical strike chance while in Bear, Dire Bear or Cat form by 5%.
# Feral Charge - 1/1 point
Causes you to charge an enemy, stopping its movement and interrupting any spell being cast for 4 seconds.
Restoration Talents (33 points)
# Improved Mark of the Wild - 5/5 points
Increases the effects of your Mark of the Wild spell by 35%.
# Nature's Focus - 5/5 points
Gives you a 60% chance to avoid interruption caused by damage while casting the Healing Touch or Regrowth spells.
# Combat Endurance - 5/5 points
Allows 10% of your Health regeneration to work while in combat.
# Gift of Nature - 1/1 point
Increases the effect of your Healing Touch, Rejuvenation, Regrowth, and Tranquility spells by 5%.
# Reflection - 5/5 points
Allows 15% of your Mana regeneration to continue while casting.
# Nature's Swiftness - 1/1 point
When activated, your next Nature spell becomes an instant cast spell.
# Subtlety - 5/5 points
Reduces the threat generated by your healing spells by 20%.
# Improved Regrowth - 5/5 points
Increases the critical effect chance of your Regrowth spell by 50%.
# Innervate - 1/1 point
Increases the target's Mana regeneration by 400% and allows 100% of the target's Mana regeneration to continue while casting. Lasts 20 seconds.
Er dette en god blanding?
Jeg ville byttet ut Combat endurance med Furor. Furuor gir deg 10 rage når du går i bear form, noe som er meget nytting når du slåss mot caster-typer (og for så vidt alle andre klasser). Feral charge er ikke som Warriorens charge og kan brukes i combat. Det krever at du har 5 rage, så derfor er Furor et must. Ihvertfall i min mening.
Nja, ville ikke ha brukt 5 poeng i Furor, er bare til å bruke den spellen som minker armoren din litt og gir deg en viss sum rage over tid, tar ikke lang tid å få 5 rage da.
