Aiven Skrevet 8. juni 2005 Skrevet 8. juni 2005 (endret) TRADISJONELL KJEKS KAPPER 31/20 Specced for maksimal damage. Til dags dato er det ingen warriorbuilds som gjør mere skade. Merk at noen liker andre arms specs enn øks (jeg hadde mace med en hammer of the titans fordi dette er bedre pvp). Endel liker å ha 31/5/15 pga "improved revenge" som er veldig bra i pve. Arms Talents (31 points) # Deflection - 4/5 points Increases your Parry chance by 4%. # Improved Rend - 3/3 points Increases the bleed damage done by your Rend ability by 35%. # Tactical Mastery - 5/5 points You retain up to 25 of your rage points when you change stances. # Improved Charge - 2/2 points Increases the rage generated by your Charge ability by 6. # Anger Management - 1/1 point Increases the time required for your Rage to decay while out of combat by 30%. # Improved Overpower - 2/2 points Increases the critical strike chance of your Overpower ability by 50%. # Deep Wounds - 3/3 points Your critical strikes cause the opponent to bleed, dealing 60% of your melee weapon's average damage over 12 seconds. # Impale - 2/2 points Increases the critical strike damage done by your abilities in Battle, Defensive, and Berserker stance by 20%. # Axe Specialization - 5/5 points Increases your chance to get a critical strike with Axes by 5%. # Sweeping Strikes - 1/1 point You next 5 melee weapon swings strike an additional nearby opponent. # Improved Hamstring - 2/2 points Increases the movement slow effect of your Hamstring ability by 20%. # Mortal Strike - 1/1 point A vicious strike that deals 200% weapon damage and wounds the target, reducing the effectiveness of any healing by 50% for 10 seconds. Fury Talents (20 points) # Cruelty - 5/5 points Increases your chance to get a critical strike with melee weapons by 5%. # Unbridled Wrath - 5/5 points Gives you a 40% chance to generate an additional Rage point when you deal melee damage. # Improved Battle Shout - 5/5 points Increases the Attack Power bonus of your Battle Shout by 25%. # Enrage - 5/5 points Gives you a 40% melee damage bonus for 4 swings any time you are the victim of a critical strike. PVE INTERCEPT BUILD 7/22/22 "The ultimate pve gimp build". Denne builden fjerner alt som heter skade og er slik sett en motsetning til kake kapperen. Hvis du speccer slik, har du endel gode verktøy, som er gode å ha som tank. Spesielt hjelper det i gruppesammenheng, der man bare er 5 eller 10. Jeg nevner i fleng: 1. 20 sekunders intercept, nyttig for å redde papir-rustning folka 2. Buffede shouts, hvis man ikke gjør skade kan man hvertfall ha bra buffs/debuffs 3. ca 10% damage reduction (fra parry, def og armor) 4. Last stand, kanskje den beste 1 poengs abilityen? Lifesaver! 5. Improved taunt, svært god å ha. 6. Concussion blow og improved revenge, et must mot alt utenfor MC! Arms Talents (7 points) # Deflection - 5/5 points Increases your Parry chance by 5%. # Tactical Mastery - 2/5 points You retain up to 10 of your rage points when you change stances. Fury Talents (22 points) # Booming Voice - 5/5 points Increases the duration of your Battle Shout and Demoralizing Shout by 50%. # Improved Demoralizing Shout - 5/5 points Increases the attack power reduction of your Demoralizing Shout by 25%. # Improved Battle Shout - 4/5 points Increases the Attack Power bonus of your Battle Shout by 20%. # Blood Craze - 3/3 points Allows 15% of your Health regeneration to work during combat for 20 seconds after being the victim of a critical strike. # Piercing Howl - 1/1 point Causes all enemies near the warrior to be dazed for 6 seconds. # Improved Execute - 2/2 points Reduces the Rage cost of your Execute ability by 5. # Improved Intercept - 2/2 points Reduces the cooldown of your Intercept ability by 10 seconds. Protection Talents (22 points) # Anticipation - 5/5 points Increases your Defense skill by 10. # Improved Bloodrage - 2/2 points Reduces the duration required to generate rage from your Bloodrage ability by 4 seconds. # Toughness - 5/5 points Increases your armor value from items by 10%. # Last Stand - 1/1 point When activated, this ability temporarily grants you 30% of your maximum hit points for 20 seconds. After the effect expires, the hit points are lost. # Improved Revenge - 3/3 points Gives your Revenge ability a 40% chance to stun the target for 3 seconds. # Improved Taunt - 2/2 points Reduces the cooldown of your Taunt ability by 2 seconds. # Improved Sunder Armor - 2/3 points Increases the armor reduction of your Sunder Armor by 20%. # Concussion Blow - 1/1 point A brutal strike that deals weapon damage and stuns the opponent for 5 seconds. # Improved Shield Wall - 1/2 point Increases the effect duration of your Shield Wall ability by 3 seconds. Endret 8. juni 2005 av Munch
Marsan Skrevet 8. juni 2005 Skrevet 8. juni 2005 Hey... Ikke diss folk som spiller uten talents...Jeg spilte NE priest til lvl 60 uten å bruke talents...easy peasy.. WoW er for enkelt... Marsan
M@R7!N Skrevet 8. juni 2005 Skrevet 8. juni 2005 (endret) Er det der den "tradisjonelle" builden da? 1. Folk kjører bare 4/5 points i battleshout, dermed 31/20.. 2. Og ikke ubridled warth, men improved demo shout Kjører en litt modifisert versjon ser det ut for, med improved hamstring, charge og ingen anger management (som jeg klarer meg helt fint uten). Edit: Hmm, og hvorfor når kutte ned på deflection når du kan kutte ned på feks Anger management? Deflection er jo såklart bedre i pvp "Min" build: Arms Talents (31 points) Deflection - 5/5 points Increases your Parry chance by 5%. Improved Rend - 3/3 points Increases the bleed damage done by your Rend ability by 35%. Tactical Mastery - 5/5 points You retain up to 25 of your rage points when you change stances. Improve Charge - 2/2 points Increases the rage generated by your Charge ability by 6. Deep Wounds - 3/3 points Your critical strikes cause the opponent to bleed, dealing 60% of your melee weapon's average damage over 12 seconds. Improved Overpower - 2/2 points Increases the critical strike chance of your Overpower ability by 50%. Impale - 2/2 points Increases the critical strike damage done by your abilities in Battle, Defensive, and Berserker stance by 20%. Axe Specialization - 5/5 points Increases your chance to get a critical strike with Axes by 5%. Sweeping Strikes - 1/1 point You next 5 melee weapon swings strike an additional nearby opponent. Improved Hamstring - 2/2 points Increases the movement slow effect of your Hamstring ability by 20%. Mortal Strike - 1/1 point A vicious strike that deals 200% weapon damage and wounds the target, reducing the effectiveness of any healing by 50% for 10 seconds. Fury Talents (20 points) Cruelty - 5/5 points Increases your chance to get a critical strike with melee weapons by 5%. Improved Demoralizing Shout - 5/5 points Increases the attack power reduction of your Demoralizing Shout by 25%. Piercing Howl - 1/1 point Causes all enemies near the warrior to be dazed for 6 seconds. Improved Battle Shout - 4/5 points Increases the Attack Power bonus of your Battle Shout by 20%. Enrage - 5/5 points Gives you a 40% melee damage bonus for 4 swings any time you are the victim of a critical strike. Protection Talents (0 points) Endret 8. juni 2005 av M@R7!N
mobilfreek Skrevet 8. juni 2005 Forfatter Skrevet 8. juni 2005 TRADISJONELL KJEKS KAPPER 31/20 Specced for maksimal damage. Til dags dato er det ingen warriorbuilds som gjør mere skade. Merk at noen liker andre arms specs enn øks (jeg hadde mace med en hammer of the titans fordi dette er bedre pvp). Endel liker å ha 31/5/15 pga "improved revenge" som er veldig bra i pve. Arms Talents (31 points) # Deflection - 4/5 points Increases your Parry chance by 4%. # Improved Rend - 3/3 points Increases the bleed damage done by your Rend ability by 35%. # Tactical Mastery - 5/5 points You retain up to 25 of your rage points when you change stances. # Improved Charge - 2/2 points Increases the rage generated by your Charge ability by 6. # Anger Management - 1/1 point Increases the time required for your Rage to decay while out of combat by 30%. # Improved Overpower - 2/2 points Increases the critical strike chance of your Overpower ability by 50%. # Deep Wounds - 3/3 points Your critical strikes cause the opponent to bleed, dealing 60% of your melee weapon's average damage over 12 seconds. # Impale - 2/2 points Increases the critical strike damage done by your abilities in Battle, Defensive, and Berserker stance by 20%. # Axe Specialization - 5/5 points Increases your chance to get a critical strike with Axes by 5%. # Sweeping Strikes - 1/1 point You next 5 melee weapon swings strike an additional nearby opponent. # Improved Hamstring - 2/2 points Increases the movement slow effect of your Hamstring ability by 20%. # Mortal Strike - 1/1 point A vicious strike that deals 200% weapon damage and wounds the target, reducing the effectiveness of any healing by 50% for 10 seconds. Fury Talents (20 points) # Cruelty - 5/5 points Increases your chance to get a critical strike with melee weapons by 5%. # Unbridled Wrath - 5/5 points Gives you a 40% chance to generate an additional Rage point when you deal melee damage. # Improved Battle Shout - 5/5 points Increases the Attack Power bonus of your Battle Shout by 25%. # Enrage - 5/5 points Gives you a 40% melee damage bonus for 4 swings any time you are the victim of a critical strike. PVE INTERCEPT BUILD 7/22/22 "The ultimate pve gimp build". Denne builden fjerner alt som heter skade og er slik sett en motsetning til kake kapperen. Hvis du speccer slik, har du endel gode verktøy, som er gode å ha som tank. Spesielt hjelper det i gruppesammenheng, der man bare er 5 eller 10. Jeg nevner i fleng: 1. 20 sekunders intercept, nyttig for å redde papir-rustning folka 2. Buffede shouts, hvis man ikke gjør skade kan man hvertfall ha bra buffs/debuffs 3. ca 10% damage reduction (fra parry, def og armor) 4. Last stand, kanskje den beste 1 poengs abilityen? Lifesaver! 5. Improved taunt, svært god å ha. 6. Concussion blow og improved revenge, et must mot alt utenfor MC! Arms Talents (7 points) # Deflection - 5/5 points Increases your Parry chance by 5%. # Tactical Mastery - 2/5 points You retain up to 10 of your rage points when you change stances. Fury Talents (22 points) # Booming Voice - 5/5 points Increases the duration of your Battle Shout and Demoralizing Shout by 50%. # Improved Demoralizing Shout - 5/5 points Increases the attack power reduction of your Demoralizing Shout by 25%. # Improved Battle Shout - 4/5 points Increases the Attack Power bonus of your Battle Shout by 20%. # Blood Craze - 3/3 points Allows 15% of your Health regeneration to work during combat for 20 seconds after being the victim of a critical strike. # Piercing Howl - 1/1 point Causes all enemies near the warrior to be dazed for 6 seconds. # Improved Execute - 2/2 points Reduces the Rage cost of your Execute ability by 5. # Improved Intercept - 2/2 points Reduces the cooldown of your Intercept ability by 10 seconds. Protection Talents (22 points) # Anticipation - 5/5 points Increases your Defense skill by 10. # Improved Bloodrage - 2/2 points Reduces the duration required to generate rage from your Bloodrage ability by 4 seconds. # Toughness - 5/5 points Increases your armor value from items by 10%. # Last Stand - 1/1 point When activated, this ability temporarily grants you 30% of your maximum hit points for 20 seconds. After the effect expires, the hit points are lost. # Improved Revenge - 3/3 points Gives your Revenge ability a 40% chance to stun the target for 3 seconds. # Improved Taunt - 2/2 points Reduces the cooldown of your Taunt ability by 2 seconds. # Improved Sunder Armor - 2/3 points Increases the armor reduction of your Sunder Armor by 20%. # Concussion Blow - 1/1 point A brutal strike that deals weapon damage and stuns the opponent for 5 seconds. # Improved Shield Wall - 1/2 point Increases the effect duration of your Shield Wall ability by 3 seconds. takk for tipset tror jeg kjører tankbuilden
Aiven Skrevet 10. juni 2005 Skrevet 10. juni 2005 Er det der den "tradisjonelle" builden da? 1. Folk kjører bare 4/5 points i battleshout, dermed 31/20.. 2. Og ikke ubridled warth, men improved demo shout Kjører en litt modifisert versjon ser det ut for, med improved hamstring, charge og ingen anger management (som jeg klarer meg helt fint uten). Edit: Hmm, og hvorfor når kutte ned på deflection når du kan kutte ned på feks Anger management? Deflection er jo såklart bedre i pvp 1. Er enig i at piercing howl bør med. 2. Ser på improved demo shout som en defensiv skill. Her må det være bedre å få litt ekstra rage i pvp og dette er en pvp build. 3. Anger management er bugget og er derfor bedre enn på papiret. Har du den får du i tillegg 1 ekstra rage pr tick (2sec). Derfor er denne etter min mening bedre enn 1% parry. Egentlig er jo dette bare småpirk, tror vi er nokså enige. Warrior treet har så mange ubrukelige skills, at de som er igjen bare må med
Doga Skrevet 10. juni 2005 Skrevet 10. juni 2005 Respecc koster 1g første gangen, 5g neste, så 10, 15, 20, 25 osv helt til 50 som er maks, bare så det er klarhet i det
mobilfreek Skrevet 10. juni 2005 Forfatter Skrevet 10. juni 2005 Respecc koster 1g første gangen, 5g neste, så 10, 15, 20, 25 osv helt til 50 som er maks, bare så det er klarhet i det ca.10 folk har sakt det allerede velkommen etter
M@R7!N Skrevet 10. juni 2005 Skrevet 10. juni 2005 Aha, er anger management bugga? Kanskje jeg skal respecce?
