Pinnacle ikke indstillet til PAL
I pinnacle studio 9 siger den at den ikk er indstillet til PAL når man skal redigere. Hvordan indstiller man programmet til det?
På forhånd tak
I Pinnacle Studio 8 finner man følgende i dropp down menyen :
Setup - Capture source - tvstandard - PAL
Du har vel kanskje allerede captured filmen i NTSC da ??
Lykke til :thumbup:
Jeg har samme problem med Studio DV/AV, kjøpt i USA. Les svar fra Pinnacle support:
Pinnacle capture hardware / software purchased in North America will support only NTSC. There is no patch or update available to make it PAL compatible. For PAL video capturing / editing, you will need to purchase a new PAL supported Studio package. Or, you may purchase Studio 9 or 9 plus upgrade to make your Studio software PAL compatible. However, in this way, you will only get your Software PAL enabed.
Noen tips???
