Talent point på rogue?
Gjest member-60584
Assassination Talents (21 points)
# Improved Eviscerate - 3/3 points
# Malice - 5/5 points
# Murder - 2/2 points
# Ruthlessness - 3/3 points
# Relentless Strikes - 1/1 point
# Lethality - 5/5 points
# Improved Expose Armor - 1/3 point
# Cold Blood - 1/1 point
Combat Talents (8 points)
# Improved Sinister Strike - 2/2 points
# Improved Gouge - 3/3 points
# Improved Backstab - 3/3 points
Subtlety Talents (22 points)
# Master of Deception - 5/5 points
# Opportunity - 5/5 points
# Initiative - 5/5 points
# Improved Ambush - 3/3 points
# Improved Rupture - 3/3 points
# Preparation - 1/1 point
vanlige 21/8/22 builden.. noen points kan variere men det går på CB/imp BS/prep
denne builden kaller jeg selv "very easy mode every 10mins"
FUnker denne lista for sword? (altså ikke daggers) :p
Der stakk læreren gitt...
30/8/13
Assassination Talents (30 points)
Increases the damage done by your Eviscerate ability by 15%.
Malice - 5/5 points
Increases your critical strike chance by 5%.
Murder - 2/2 points
Increases your chance to hit while using your Sap, Ambush, Garrote, or Cheap Shot abilities by 5%.
Gives your finishing moves a 60% chance to add a combo point to your target.
Increases the critical strike damage bonus of your Sinister Strike, Gouge, Backstab, Ambush, Ghostly Strike, or Hemorrhage ability by 30%.
Your finishing moves have a 20% chance per combo point to restore 25 energy.
Improved Instant Poison - 5/5 points
Increases the chance to apply Instant Poison to your target by 10%.
When activated, increases the critical strike chance of your next Sinister Strike, Backstab, Ambush, or Eviscerate by 100%.
Seal Fate - 5/5 points
Your critical strikes from abilities that add combo points have a 100% chance to add an additional combo point.
Reduces the Energy cost of your Sinister Strike ability by 5 Energy.
Increases the effect duration of your Gouge ability by 1.5 seconds.
Increases the critical strike chance of your Backstab ability by 30%.
Subtlety Talents (13 points)
Camouflage - 5/5 points
Increases your speed while stealthed by 15%.
Increases the damage dealt when striking from behind with your Backstab, Garrote, or Ambush abilities by 20%.
Increases the critical strike chance of your Ambush ability by 40%.
Går selv for en backstab-build med dual-daggers.
# Murder - 1/2 point
Increases your chance to hit while using your Sap, Ambush, Garrote, or Cheap Shot abilities by 3%.
# Improved Expose Armor - 3/3 points
Increases the armor reduced by your Expose Armor ability by 45%.
# Improved Kidney Shot - 3/3 points
Reduces the cooldown of your Kidney Shot ability by 5 seconds.
# Seal Fate - 5/5 points
Combat Talents (21 points)
# Lightning Reflexes - 2/5 points
Increases your Dodge chance by 2%.
# Deflection - 5/5 points
Increases your Parry chance by 5%.
# Precision - 2/5 points
Increases your chance to hit with melee weapons by 2%.
# Riposte - 1/1 point
A strike that becomes active after parrying an opponent's attack. This attack deals 150% weapon damage and disarms the target for 6 seconds.
# Dagger Specialization - 5/5 points
Increases your chance to get a critical strike with Daggers by 5%.
Når det gjelder rekkefølgen på hvordan du setter poengene, så ville jeg prøvd å komme ned til Seal Fate så fort som mulig.
Improved Sap er et must hvis du skal være en best mulig snikmorder. Da er det stor sjanse for at du fortsatt er i stealth etter å ha sappa en!
Går 30/8/13
Assasination (30): 3 Imp. Evsicerate, 5 Malice, 2 Murder, 1 Relentless Strikes, 2 Ruthlessness, 5 Lethality, 5 Vile Poison, 1 Cold Blood, 5 Seal Fate.
Combat (8): 3 Imp. Gouge (Brukes bare til energy-load for Backstab, oe. bandasjering), 2 Dodge (pga. jeg vil heller dodge 2% mer enn å ha 5 mindre energy brukt per SS, som jeg bruker lite uannsett), 3 Imp. Backstab.
Subtlety (13): 5 Master of Deception, 5 Opportunity, 3 Imp. Ambush
HKoN-  Skrevet 02/05/2005 : 22:09
Nei og nei.. :no:
Endret av Artex
Da er Sunder Armor for Warrior's mye bedre, siden den funker opptil 5 ganger og i tillegg holder aggro på Warrior.
Jepp. Og Expose og sunder stacker ikke.
Gjest member-60584
btw: expose armor suger.
hvorfor? godt å bruke det mot mail/plate users og i solo PvE mot heavy armor creeps..
mot heavy armor creeps: CS > SS > expose armor
i PvP: CS > SS > expose armor > spring vekk og restealth
Hva med 3 poeng på setup, 1 på preparation og 2 på improved evasion?
Du vil kunne bruke evasion i opptil 38 sekunder, hele tiden har du ~90% sjanse for å dodge angrep. Med 3 poeng på setup har du 45% sjanse for å få 1 combopoint hver gang du dodger, med 90% dodgerate blir det en del combopoints etter hvert. Preparation bruker du midtveis i kampen eller litt tidligere.
Stealth -> CS -> Backstab -> Evasion -> Vanish -> CS -> Preparation -> KS-> Backstab -> Vanish -> CS -> Gauge -> Eviscerate.
Cooldown på Evasion fjernes av preparation så denne kan du igjen aktiverere når den holder på å gå tom. Hvis fi lever enda kan en bruke Sprint og springe som et lyn bak han og trykke på Backstab som en gal. Du er raskest så du vil ha kontroll mens fi vil få mange beskjeder som sier "You are facing the wrong direction." og han vil ikke treffe deg så mye som han kanskje ellers ville gjort. Hvis han får inn slag og spesielt hvis han har raske våpen så heller han igrunn bare bensin på bålet, du har enda 19 sekunder med omkring 90% dodgechance og 45% for å få combopoint hver gang du dodger. Dette er foreløpig builden jeg beveger meg mot. Cloth-brukere sliter uansett så mye mot rogues at jeg satser på å tåle mest mulig juling fra melee-fiender.
Jeg har ikke testet alt dette i praksis så noen erfarne rogues får greie ut om dette funker.. :hmm:
Sprint-Backstab-Backstab-Backstab-Backstab-Backstab-Backstab-Backstab funker voldsomt bra hvis fienden ikke er forberedt på det.
Endret av Pycnopodia
Gjest member-60584
har du peiling i det hele tatt? :/
Grunnen til at jeg har satser på expose armor i min build er mest pga pvp (mot heavy-armor classes og mot andre rogues).
Litt off topic men gadd ikke ta meg bryet om å lage en ny tråd...
Hvor mye armor har en rouge på lvl30-35?
Bare sånn ca. snitt eller noe sånt..?
