Left Blank Skrevet 29. april 2005 Skrevet 29. april 2005 (endret) fra hl2.net: på engelsk fordi jeg er lat. First off my philosophy with this script is to not have any useless aliases like duck jump or "plant c4". Most of the changes are visually, but it of course also includes a new buyscript. Features: 1. A complete buy script with a visual gui where you can bind all your weapon buy binds in the controls menu. (no config file editing needed). 2. All names in the vgui menus and hud menus have been reverted back to their original 1.5(and real life) names. 3. A custom background of a desert eagle in the main menu screen. 4. More options in controls > advanced menu, for example a net graph toggle and where to position the net graph. 5. Cooler names for everything 6. New hud colors and font Screenshots: www.c0ax.org/stuff/cs_italy0007.jpg http://www.c0ax.org/images/hybrid.jpg Todolist: Make a custom hybrid menu background Echo all purchases to screen Download: http://www.c0ax.org/stuff/hybrid_css_1.5.zip This script will be updated whenever valve adds a new function by the way, like a command menu, so you can safely know that it won't be abandoned. Suggestions and feedback is welcomed! To install do the following: 1. Extract the contents to E:\Valve\Steam\SteamApps\[email protected]\counter-strike source\cstrike\ 2. Overwrite any files it asks for 3. Delete config.cfg in your \cfg folder 4. Boot up CS:S and go to keyboard controls and bind your keys. 5. Play the game Jeg kommer til å oppdatere scriptet hvis valve putter i noen nye funksjoner, som f eks en command menu, så ikke vær redd for at scriptet blir "out of date" Se i signaturen for link til scriptet. Feedback og ideer hadde vært kult å fått. Du kan og snakke med meg på msn: [email protected] Screenshot: http://www.c0ax.org/images/hybrid.jpg Endret 30. april 2005 av joltaire
Left Blank Skrevet 29. april 2005 Forfatter Skrevet 29. april 2005 er dette lov i kamper da? jau da, er ikke noe ulumskheter her er bare default config med buyscript og det andre stæsjet, ikke noen rare aliaser
