www.wow-europe.com Forums - Får ikke logget inn
Heei
Jeg prøver å logge inn på forumene på den offisielle community siden, hvorfor funker ikke dette? burde ikke jeg klare det? Noen som har samme problemet?
Christer
Endret av ChristerN
Samme problemet.
Blizzards svar fra tech support.
"Hello,
The problem you are experiencing when you try and log into the forums is on our side. It is caused because characters from some of the realms are not yet registered to log in to the forums. We are very sorry for the inconvenience, and are working to get this fixed as soon as we can for you.
In the meantime, you could create a character on another realm in order to log in to the forums.
Best Regards
Blizzard Entertainment Europe
Andreas U
Technical Support
http://www.wow-europe.com"
Lage tidenes onlinespill klarer de, men å få et forum til å fungere ble litt for krevende...
