WorldCraft mapping (counter-strike)
Jeg visste ikke helt hvor jeg skulle poste dette men tror kanskje det går bra.
Jeg prøver meg frem med å lage counter-strike maps i WorldCraft (Valve Hammer).
Hadde 1 problem når jeg skulle Compile mappet mitt.
Når jeg var NESTEN ferdig å compile, kom det en feilmelding.
ps: ikke les alt, feilmeldingen kommer nederst
** Executing...
** Command: Change Directory
** Parameters: "C:\spill\steam"
** Executing...
** Command: C:\spill\steam\mapping\compile\hlcsg.exe
** Parameters: "c:\spill\steam\steamapps\daniel_berg01@hotmail"
hlcsg v2.5.3 rel Custom Build 1.7 (Dec  9 2002)
Zoner's Half-Life Compilation Tools -- Custom Build
Based on code modifications by Sean 'Zoner' Cavanaugh
Based on Valve's version, modified with permission.
Submit detailed bug reports to ([email protected])
-----  BEGIN  hlcsg -----
Command line: C:\spill\steam\mapping\compile\hlcsg.exe c:\spill\steam\steamapps\daniel_berg01@hotmail
Error: Error opening c:\spill\steam\steamapps\[email protected]: No such file or directory
-----   END   hlcsg -----
** Executing...
** Command: C:\spill\steam\mapping\compile\hlbsp.exe
hlbsp v2.5.3 rel Custom Build 1.7 (Dec  9 2002)
-----  BEGIN  hlbsp -----
Command line: C:\spill\steam\mapping\compile\hlbsp.exe c:\spill\steam\steamapps\daniel_berg01@hotmail
>> There was a problem compiling the map.
>> Check the file c:\spill\steam\steamapps\[email protected] for the cause.
-----   END   hlbsp -----
** Executing...
** Command: C:\spill\steam\mapping\compile\hlvis.exe
hlvis v2.5.3 rel Custom Build 1.7 (Dec  9 2002)
-----  BEGIN  hlvis -----
Command line: C:\spill\steam\mapping\compile\hlvis.exe c:\spill\steam\steamapps\daniel_berg01@hotmail
-----   END   hlvis -----
** Executing...
** Command: C:\spill\steam\mapping\compile\hlrad.exe
hlrad v2.5.3 rel Custom Build 1.7 (Dec  9 2002)
-----  BEGIN  hlrad -----
Command line: C:\spill\steam\mapping\compile\hlrad.exe c:\spill\steam\steamapps\daniel_berg01@hotmail
-----   END   hlrad -----
** Executing...
** Command: Copy File
** Parameters: "c:\spill\steam\steamapps\[email protected]" "C:\spill\steam\SteamApps\[email protected]\counter-strike\cstrike\maps\[email protected]"
The command failed. Windows reported the error:
  "The system cannot find the file specified."
Det var helt nederst feilmeldingen kom, jeg vet selv ikke hva problemet er men jeg håper noen kan hjelpe meg :cry:
Spør viss dere lurer på noe :thumbup:
Endret av ggp
Tror ikke compile toolsene liker "@" i verken path eller navn. Prøv å compiler brettene til en mappe uten "@" i og endre navnet til noe uten "@" i.
