[GTA]Hvordan komme seg til Liberty City i SA
Here's a video of someone doing it:
http://www.maxbot.com/misc/LibertyCityViaGym.wmv (<-- Watch the video first it'll show you where you need to postion the red dot on the map like it tells you to do in the 5th step (below) )
1st Step - Go to the Los Santos gym
2nd Step - Kill the 4 people when you enter
3rd Step - Enter jetpack cheat (L1, L2, R1, R2, UP, DOWN, LEFT, RIGHT, L1, L2, R1, R2, UP, DOWN, LEFT, RIGHT)
4th Step - Go through the hole by the door in the ceiling
5th Step - Click start then zoom in on your map pick a location on the picture by clicking CIRCLE on your map.
6th Step - Follow the red marker u made on the map then there you are (there may be invisible walls that get in your way so check your map every few secs to see if you are moving any closer)
  • 2 uker senere...
