BIOS setup og Radeon 9800 Pro
KriB
Jeg lurer på hvilke BIOS settings jeg bør har for å få mest ut av mitt RADEON 9800 PRO.
Man har jo slike gøye ting som Fast Write og VGA cacheable og jeg vet ikke hva.
Er det noen som har en guide eller liknende?
På ATI's sider står det bare at de anbefaler at alt schnackz er skrudd av, men at man kan få bedre ytelse med andre innstillinger. DOH!
Anyone?
Anyone?
Ta en titt på Omega sine tips om hvordan bios bør være stillt inn.
http://www.omegacorner.com/bios.htm
Fast Gate A20 Option : ENABLED
Video BIOS shadowing : DISABLED
Video BIOS cacheable : DISABLED
xxxxx - xxxxx Shadow : ALL DISABLED
IDE prefetch mode : ENABLED
Init Display First : AGP or PCI (SELECT YOUR CARD TYPE)
IDE HDD Block Mode : ENABLED
IDE 32-bit transfer mode : ENABLED
Assign IRQ for USB : DISABLED (UNLESS YOU USE USB DEVICES)
Assign IRQ for VGA : ENABLED
PCI/VGA palette snoop : DISABLED
PNP OS Installed : ENABLED (UNLESS YOU WANT TO MANUALLY ASSIGN IRQ's)
Resource Controlled By : AUTO (UNLESS YOU WANT TO MANUALLY ASSIGN IRQs AND DMAs)
AGP aperture size : 128 (USE 64MB IF YOU EXPERIENCE TEXTURE CORRUPTION)
AGP master 1 WS write : DISABLED***
AGP master 1 WS read : DISABLED***
Bank 0/1, 2/3 DRAM timing : TURBO***
CPU to PCI write buffer : ENABLED
Delayed Transaction : DISABLED (ENABLE IF YOU EXPERIENCE PROBLEMS WITH CREATIVE SOUND CARDS)
DRAM speculative leadoff : ENABLED***
DRAM Data Integrity Mode : NON-ECC (UNLESS YOU HAVE ECC MEMORY)
Delay DRAM read latch : (THE LOWER, THE FASTER)***
Fast writes : DISABLED
Memory parity/ECC check : DISABLED***
Passive Release : ENABLED
PCI Concurrency : ENABLED
PCI master 0 WS write : ENABLED***
RAS active time : (THE LOWER, THE FASTER)***
RAS to CAS delay : (THE LOWER, THE FASTER)**
Read around write : ENABLED
SDRAM Bank Interleave : 4-bank/way
SDRAM CAS Latency Time : 2**
SDRAM cycle length : 2**
SDRAM Precharge control : ENABLED
Spread spectrum (modulation): DISABLED
System BIOS cacheable : DISABLED
Video RAM cacheable : DISABLED
8 bit I/O Recovery Time : 1
16 bit I/O Recovery Time : 1
Turbo frequency : ENABLED
** = ONLY IF YOUR MEMORY SUPPORT IT, OTHERWISE USE THE NEXT
HIGHER VALUE
*** = WILL IMPROVE SPEED BUT DECREASES STABILITY, IF YOU HAVE
PROBLEMS CHANGE IT
Well, that's all for the BIOS.
This settings should increase you framerates with your video card, if you want do a benchmark before and after the changes, it will give you a good idea of the gain obtained.
Burde gi deg en pekepinn på hva som er best...
