[Løst] Trenger hjelp med RevoDrive...
Hei,
Har bygd meg ny pc.
Satt sammen av følgende komponenter:
"ASUS M4A89GTD PRO/USB3, Socket-AM3"
"AMD 890GX+SB850, ATX, DDR3 , 6xSATA 6Gb"
"ASUS Radeon HD 5550 1GB DDR3"
"PCI-Express 2.0, DVI-I, native-HDMI, LP"
"OCZ DDR3 8 GB Gold Ultra Low Voltage"
"PC3-10666 2x4GB 1333MHz. (9.9.9.24)"
"AMD Phenom II X6 1090T Black Edition"
"AM3 3,2/3,6GHz Turbo Core 9MB cache,125W"
"Corsair H50 Hydro Series CPU Kjøler"
"Socket 775/1156/1366, AM2/AM2+/AM3"
"Western Digital 500GB S-ATA II 7200 RPM"
"Caviar Special Edition 16MB -Recertified"
"Netshop Miditower "Formula 1""
"Rød/Sort u/powersupply"
"MIST 1000W avtagbare kabler, rev. 2"
"Japanske kondensatorer, kabel kit inkl."
"D-Link DWA-525 Trådløst PCI, 802.11n"
"802.11b/g/n, PCI" <<<------ Må vente til win 7 er installert da driver må legges inn først.
Skal kjøpe: Plextor Blu-ray leser/brenner PX-B940SA senere.
Venter på at den skal falle i pris...
Bruker i mellomtiden en gammel plextor dvd brenner koblet i ide porten.
Som dere ser så er hovedkortet: "ASUS M4A89GTD PRO/USB3, Socket-AM3"
Og vil bruke denne SSD som boot for win 7 ultimate:
"OCZ 120 GB SSD PCI-E 4x MLC"
"RevoDrive, Read/Write 540/530MBsec."
Har sjekket litt rundt på nettet da denne SSD er litt vanskelig å få til...
Fant denne "oppskriften":
"Successful setup with Revo
I just built a system with the same board and REVO as bootable drive.
Started with ALL SATA controllers set to IDE mode and CD-ROM on SATA5/6 the first start-up device.
I did not connect my HDD to SATA at this point.
The bios (1456) correctly identified my REVO 50G as RAID 0 of two 23G drives.
After loading the setup files for Win 7 64-bit Ultimate, I loaded the OCZ driver (from their download section).
After that, Windows installed no prob on REVO.
Reboot, turn off, plug in the HDD SATA cables; after reboot went back into the BIOS and changed: the boot sequence (removable device:1, REVO:2 CD-ROM :3 etc.), changed the SATA speed to SATA 6G (have two 1TB SATA6 drives) and SATA mode to AHCI, except for SATA 5 and 6 that remain on IDE.
In Windows, went to storage management and initialized the drives, setting them up under windows as a mirroring RAID. Everything is working like a charm "
Så mine spørsmål er som følger:
Min dvd brenner er koblet i ide porten, har det noen betydning?
"After loading the setup files for Win 7 64-bit Ultimate, I loaded the OCZ driver (from their download section). "
Noen som skjønner hva dette innebærer? Usikker på hva han fyren mener med dette...
Håper noen kan forklare det på norsk....
Generelt: All hjelp mottas med stor takk! :thumbup:
Kanskje noen har erfaring med disse SSD?
