Steam funker ikke...
Hver gang jeg prøver å åpne steam kommer denne meldingen opp:
Steam.EXE(main excption): unable to load libary steam.dll
Takker for svar!
Takker for svar!
Tror ikke denne er på riktig spor.
Men hva med å slette steam å laste inn på nytt.
Takker for svar!
Har prøvd, men med samme resultat...
Takker for svar!
hva er din email , kan prøve å sende min Steam dll.
men du kan jo også kontakte Steam.
www.steampowered.com
Takker for svar!
Den er [email protected]
Endret av the_dudesons
  • 3 uker senere...
Takker for svar!
Funka ?
Takker for svar!
Funka ?
Nope
  • 1 måned senere...
Hmm.. Brannmur?
Firewall Provider Resources
If you are using a firewall program listed above and have questions about setting permissions, please take the opportunity to open the program and use its Help feature or review the support site for the software:
* Microsoft provides support for the Windows XP firewall (included with Windows XP Service Pack 2, enabled by default)
* Norton provides support for Norton Personal Firewall
* McAfee provides support for McAfee Personal Firewall and the McAfee Internet Security Suite
* Zone Labs provides support for ZoneAlarm
* nVidia - nVidia's Network Access Manager is bundled with some nVidia products. Unfortunately, this product is not compatible with Steam - please see the Nothing appears on the Storefront screen in Steam topic for more information.
If allowing permissions does not seem to affect the connection to Steam, please try disabling your firewall completely before launching Steam to test this issue.
