Tregner hjelp med Hitman 2
Jeg sliter med oppdrag 18 tror jeg det er, starter ved en båt som er på reprasjon, jeg har drept det kvinnemenneske, og jeg skal ta hu til det hemmlige rommet, men jeg finner ikke den ¤%&/() nøkkelen....kan noen forklare meg hvor den ligger?
Har du lest i walkthrough?
M18 - The Death of Hannelore
Objectives -Pick up door key to hiding place
-Kill Dr. Von Kamprad
-Hide the body of Dr. Von Kamprad- Check your map
-No civilians must be killed
-Prelude-
Here's another level which sounds a lot like a movie. It's pretty fun,
very easy to beat, the whole thing. The objectives to this level are
pretty self-explanatory. Dr. Von Kamprad is your target. She's very
dumb and not very careful so killing her is easy enough if it were'nt
for those dumb civilians. Anyways, here we go:
-Mission-
Alright, so we start out behind a canoe of some sort. Check around
you to make sure there are no guards. A guard who comes quite close
to your location should be heading away from you through a little
hole in the hills before you move. When he does that, go forward
in the direction your facing (west). Stick to the hills. However, if
a stationary guard is westwards preventing you from advancing (
although he is facing the opposite direction), then stick to the
beachy area, and go west and you should reach a sewer entrance (not
ladder, just walk-in type). Now check your map and head towards the
only ladder there is (but once you get there, do not go up the ladder,
it's suicide). Instead, go through the first sewer opening to the right,
and go up that ladder, but halfway through, when you can see above
you, make sure there are no guards there.
Now move to the nearest room on the right as long as there is no one
inside, from here, hide and sneak your way to the room with the (!)
up north. Change into the patient clothes, and you have a decent
disguise as of now. Now move back to where you came from and
towards the storage area where your agency pickup is. Get the poison,
and the door key. Now move towards the stairway which
is at the north of this little ring. You can't see the stairs, it's behind
doors which are guarded by......guards. When they move to ther right,
to smoke, go through the left doorway, then right to get to the
main area. If you keep going straigh to the right a little after you
enter this area, you'll end up in the hallway with stairs. If not, just
check your damn map, that's why it's there.
(Note: Get close to the nurse and she'll take you to the target's
office).
Now the target will start talking to you and then get up and look outside
the window. Use this chance to pour poison into her drink. When
she drinks it, drag her into the room behind her desk immediately.
Then through the other door into the tiny connecting room. Wait
for the patient who comes in to come, look around, and then leave
because you don't want him to accidentally come in while you're taking
the doctor to her hiding place. Now when he leaves go back to the
office, drag her through the door you came from, and put her in her
hiding spot.
Now it's your choice how you want to escape. Either go back the
way you came in, or climb through the window in the middle of the
pool. Then go to your speedboat to exit the level.
-Extras/Hints-
-From far away, you're patient disguise works but up close, susupicions
arise, although nothing serious
-Don't be an idiot in front of patients
-Make sure the patient cannot see before emerging from sewers
-If you go up the main ladder from sewers, you emerge right
in the middle of the garden pool with guards all staring right at you
-Forgot the poison? Fibre-wire works too
-Run along the beach to the speedboat when exiting before the
guards get suspicious about a patient running around outside
the compound
-Weapons-
*Items
Poison - Agency Pickup
Door Key - Agency Pickup
*Weapons
9mm Pistol - Agency Pickup, guards
AK - Agency pickip
*Ammo
None
Har desverre ikke spilt mer enn de første brettene, men ser jo ut som man skal finne den samme sted som giften:
and the door key.
and the door key.
Jeg fant den tilslutt
