Naiits Skrevet 3. juni 2008 Skrevet 3. juni 2008 Når jeg prøver å logge på onlinebrukeren min kommer det bare opp ''The server has refused the connection'' Serveren har avvist tilkoblingen? Det virket for noen dager siden, å har ikke gjort noe med dataen. Å eg e helt sikker på at det e rett passord? Hjelp pliz
Ståle Skrevet 3. juni 2008 Skrevet 3. juni 2008 Det kommer avogtil hos meg også, er bare å prøve igjen. Eller så kan det være en brannmur.
Kjøleskapmannen Skrevet 3. juni 2008 Skrevet 3. juni 2008 (endret) What are the maintenance times for Battlefield 2, Battlefield 2 Modern Combat, and Battlefield 2142? Why can't I connect or properly access Battlefield services during these times? The Battlefield franchise has many moving parts, and at times needs to be re-synched, updated, or restarted to make sure that errors and issues with the service are avoided or repaired. Electronic Arts reserves the times listed below to perform maintenance on Battlefield 2, Battlefield 2 Modern Combat, and Battlefield 2142. Standard Maintenance Window Tuesday: 12 a.m. - 3 a.m. Pacific Time 1 a.m. - 4 a.m. Mountain Time 2 a.m. - 5 a.m. Central Time 3 a.m. - 6 a.m. Eastern Time Emergency Maintenance Window Thursday: 12 a.m. - 3 a.m. Pacific Time 1 a.m. - 4 a.m. Mountain Time 2 a.m. - 5 a.m. Central Time 3 a.m. - 6 a.m. Eastern Time Although the maintenance windows are not necessarily used every week, if you cannot connect or have issues with authentication, statistics, buddy lists, servers, etc. during these times, it is likely due to some form of maintenance and you should try again after the maintenance period is over. http://forums.ea.com/mboards/thread.jspa?s...threadID=139054 Endret 3. juni 2008 av Kjøleskapmannen
