Lj script til 1.6
(...)og til dere som skal whine....script er ikke ulovelig.
Hva/hvem bestemmer om script er lovelig eller ulovelig? De fleste spill-portalene i Norge ønsker ikke scripts som forenkler spillet.
Edit: Om jeg hadde laget en cheat (programfil) som hadde modifisert HL-motoren til å gjøre det like enkelt å "longjumpe", hadde det da vært ulovlig? Det hadde i hvert fall vært imot vALVEs "User Agreement":
5. ONLINE CONDUCT, CHEATING AND ILLEGAL BEHAVIOR
You agree that you will be personally responsible for the use of your Account and for all of the communication and activity on Steam that results from use of your Account. Your online conduct and interaction with other subscribers should be guided by common sense and basic etiquette. Specific requirements may also be found in the Steam Online Conduct rules at http://steampowered.com/index.php?area=online_conduct, other Rules of Use, the Subscription Terms, or in terms of use required by third parties who host particular games or other services.
Steam and the Steam Software may include functionality designed to identify software or hardware processes or functionality that may give a player an unfair competitive advantage when playing multiplayer versions of any Steam Software, other Valve products, or modifications thereof ("Cheats"). You agree that you will not create or assist third parties in any way to create Cheats. You agree that you will not directly or indirectly disable, circumvent, or otherwise interfere with the operation of software designed to prevent or report the use of Cheats. You acknowledge and agree that either Valve or any online multiplayer host may refuse to allow you to participate in certain online multiplayer games if you use Cheats in connection with Steam or the Steam Software. Further, you acknowledge and agree that an online multiplayer host may report your use of Cheats to Valve, and Valve may communicate your history of use of Cheats to other online multiplayer hosts for Valve products. Valve may terminate your Account or a particular Subscription for any conduct or activity that Valve believes is illegal, constitutes a Cheat, or which otherwise negatively affects the enjoyment of Steam by other Subscribers. You acknowledge that Valve is not required to provide you notice before terminating your Subscriptions(s) and/or Account, but it may choose to do so.
Sitat fra vALVEs Steam-support om VAC (Valve Anti Cheat):
The VAC system reliably detects cheats using their cheat signatures. Any third-party modification to a game designed to give one player an advantage over another is classified as a cheat or hack and will trigger a VAC ban. This includes modifications to a game's core executable files and dynamic link libraries.
Endret av Jooakim
