ULØST "could not load OpenGL subsystem"
hver gang jeg prøver å starte spille for jeg denne feil mellingen:
JK2: v1.02a win-x86 Mar 4 2002
Initialising zone memory .....
----- FS_Startup -----
Current search path:
C:\Program Files\LucasArts\Star Wars JK II Jedi Outcast\GameData\base\assets1.pk3 (8011 files)
C:\Program Files\LucasArts\Star Wars JK II Jedi Outcast\GameData\base\assets0.pk3 (6674 files)
C:\Program Files\LucasArts\Star Wars JK II Jedi Outcast\GameData/base
14685 files in pk3 files
execing default.cfg
couldn't exec jk2config.cfg
couldn't exec autoexec.cfg
...detecting CPU, found Intel Pentium IV
------- Input Initialization -------
Skipping check for DirectInput
Joystick is not active.
------- Force Feedback Initialization -------
...inhibited, not initializing
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
--- Common Initialization Complete ---
Working directory: C:\Program Files\LucasArts\Star Wars JK II Jedi Outcast\GameData
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\Windows\system32\opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using desktop display depth of 32
...calling CDS: failed, DISP_CHANGE_FAILED
...trying next higher resolution: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...35 PFDs found
...GLW_ChoosePFD failed
...GLW_ChoosePFD( 32, 24, 0 )
...35 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (3)
...using colorsbits of 16
...GLW_ChoosePFD( 16, 16, 0 )
...35 PFDs found
...35 PFDs found
...shutting down QGL
...unloading OpenGL DLL
----- CL_Shutdown -----
RE_Shutdown( 1 )
GLW_StartOpenGL() - could not load OpenGL subsystem
hva skal jeg gjøre?
Endret av arnt90
  • 2 uker senere...
Kan noen sende meg link eller noe til drivere? Jeg har lett overalt i opengl sin hjemmeside uten hell, windows sin opdateringstjeneste fungerer heller ikke særli bra da det står at jeg har versjon 1.1 mens de skal ha kommet ut med 2.0 og over =(
Ettersom hvilket kort du har, gå inn på en av disse sidene
ATi-kort: ati.com
nVidia-kort: nvidia.com
Jeg har allerede lett dær en del
Gjest Slettet-aNZFa3
Trådstarter: Hva slags skjermkort har du?
