skraml Skrevet 23. november 2007 Skrevet 23. november 2007 I går kveld las jeg litt om 2.3.2, men var så trøtt at jeg ikke fikk med meg stort. Eneste jeg husker er at hunter-pets vil lvl'e kjappere og at mage'er vil få "Ice Block" som trainable skill på lvl 30 (erstattet i talenttredet av "Cold Snap", som igjenn fikk sin plass i tredet erstattet av et talent som vil gi -20% cast-time på alle spells i 20 sekund [3 min CD]) Noen som gidder å poste flere class-forandringer? (Har ikke tilgang på noen wow-relaterte sider for øyeblikket [jobb :S])
Pomfri Skrevet 23. november 2007 Skrevet 23. november 2007 Her World of Warcraft PTR Patch 2.3.2 The latest test realm patch notes can always be found at http://www.worldofwarcraft.com/patchnotes/...patchnotes.html The latest patch notes can always be found at http://www.worldofwarcraft.com/patchnotes/ General /timetest is a command that can be run to provide information on game performance. /timetest 0 turns the command off. When the command is issued, the next time a player uses a flight master to travel, certain statistics will be measured and displayed at the end of that flight. All weather effects and spawns are shutdown during the test. Quest givers with blue question marks no longer show up on the minimap. NPC's who you have completed a quest for will display a question mark on mouseover rather than an exclamation point. The bank controls for the guildmaster level of a guild is now grayed out. A guildmaster always has full access to a guild bank and this cannot be changed. A "Withdraw-Repair Only" button has been added to the guild bank controls. If this is set for a guild rank, then that rank cannot actually withdraw funds from the guild bank, but they can still use that daily amount of money for repairs. You will now automatically stand up when attacked, even if the attack doesn’t land. Hunters Arcane Shot: Ranks 1-5 will once again deal bonus damage based on attack power. Aspect of the Viper effect increased. Freezing Trap is no longer limited to one target at a time. Pet leveling speed has been increased. Mages Cold Snap (Frost) cooldown reduced. It is now in the Ice Block position in the talent tree. This ability will no longer reset the cooldown on Fire Ward. Conjure Mana Gem (Rank 6 - Emerald) now restores 1800 to 3000 mana and has three charges. Ice Block (Frost) is now available on the trainer to all mages at level 30. Icy Veins (NEW Frost Talent) decreases casting time of all spells by 20% and increases the chance your chilling effects will freeze the target by 25%. Lasts 20 sec. 3 min cooldown. It is now in the Cold Snap position in the talent tree. Paladins Crusader Strike (Retribution) now causes 110% of weapon damage and no longer gains any bonus from spell damage. Righteous Fury: This spell will no longer cost twice the listed mana to cast. Sanctified Judgements (Retribution) now returns 80% of the Seal's mana cost, increased from 50%. Rogues Cheat Death: When multiple attacks land simultaenously, all those resolved after the attack which triggered Cheat Death will now have their damage reduced by 90% as intended. However, the combat log will still report them doing full damage. Hemorrhage: Rank 4 of this ability no longer has its charges consumed by non-physical attacks and spells. Shaman Earth Shield (Restoration) mana cost reduced. Lightning Shield mana cost reduced. Water Shield now restores mana periodically regardless of how many charges remain. Duration increased to 10 minutes. Warlock The health cost taken from the Warlock after using Health Funnel will now remain consistent between uses. Warrior Defiance (Protection) weapon expertise will now work in all stances. This was a bug that has been fixed. Warriors no longer lose rage when using a macro to enter a stance they’re already in. Professions Cooking Goldthorn Tea was erroneously unlearned by most players who had learned the recipe. The recipe has been re-enabled and can be learned again from Henry Stern in Razorfen Downs at no cost. Enchanting: Enchant Shield - Resilience now requires a Runed Fel Iron Rod instead of a Runed Adamantite Rod. Leatherworking: Increased the range of leatherworking drums to 40 yards. Drums of Panic remains unchanged at 8 yards. Items Amani Charm of the Witch Doctor: Tooltip typo corrected. Hearthstone: The cast time on this item is no longer affected by spell haste. Icy Chill Enchant: The triggered effect from this enchantment will now cause a melee slow and movement snare as intended. Idol of the Unseen Moon: This item now has a 30 second cooldown on being triggered. Idol of Terror: The triggered agility buff from this item no longer overwrites other agility buffs. The Netherscale Ammo Pouch is no longer a Unique item. The Knothide Quiver is no longer unique. Dungeons and Raids Heroic Coilfang Resevoir- Steamvaults Mekgineer Steamrigger's Main Chambers Access Panel is no longer interactable until Mekgineer Steamrigger has been killed. Tempest Keep- The Eye The number of Blood Elves guarding Prince Kael'Thas' room has been reduced. Zul'Aman The Amani'shi Warrior's Charge ability now has a minimum range. The melee haste provided by Halazzi's Frenzy has been reduced to 100%. Dragonhawks in Zul'Aman can now be skinned. This doesn't include dragonhawks that do not have loot. Quests Blade's Edge Mountains: Players accepting the bombing run quests in Blade's Edge Plateaus will no longer cause other players in the region to stand up. User Interface There is now an option to turn off the screen edge damage flash when you have a fullscreen UI up. You can sell stacks by dropping them on the merchant window again. Ready check (/readycheck) will now display a visual display of each party/raid member's status next to their name. This will display in the Party UI, the Raid UI and the Raid pullout UI. A player will get a check mark if they are ready, a question mark if they have not replied and a red X if they are not ready or are afk. You can now see raid members on the minimap as dark blue dots in addition to party members which still display as light blue dots. You can now shift click names while the petition window is open to paste them into the petition. Fixed various problems with /castsequence getting stuck. /cast will toggle spells again unless the name is prefixed with an exclamation mark, e.g. /castsequence Steady Shot, !Auto Shot Bug Fixes Fixed “Spell/Ability is not ready yet” message when clicking quickly at the beginning of a cast. Fixed a server disconnect when moving the mouse over recipes in the guild bank. Gnomish Universal Remote will now work properly with the Fel Cannon. Disconnecting a USB HeadSet will no longer cause problems with the Voice Chat dropdown menus. Clockwork Rocket Bots will no longer attack each other in Shattrath City. Channel changes will now appear properly in the chat log after zoning in or out of instances. Unplugging headphones/speakers then plugging them back in while in WoW no longer disables all sound in WoW If the original owner of a custom channel gives leadership away their options menu will no longer show that they have moderation privileges. The first custom created guild ranking will now properly show up in the Guild Control pane drop down menu. Control-clicking on inventory items that teach recipes will now properly display you wearing the item made by the recipe in the dressing room UI. Fixed an issue that was not allowing all charges of a Field Repair Bot to be used.
Skogslik Skrevet 23. november 2007 Skrevet 23. november 2007 ingen som har peiling på når den kommer?
Freak627 Skrevet 23. november 2007 Skrevet 23. november 2007 Herregud. Mages blir jo bare enda kraftigere!
skraml Skrevet 23. november 2007 Forfatter Skrevet 23. november 2007 Off... jeg hadde et håp om at feral ville få en buff som gjorde de sterkere i arena :S Tragisk når man kan komme lenger som resto-spec selv om s2 gearet er dragonhide (feral)
Dev- Skrevet 23. november 2007 Skrevet 23. november 2007 (endret) OMFG! "Freezing Trap is no longer limited to one target at a time." Så sykt bra. Slutt på å ganke huntere nå, vi bare freezer dere og løper unna Endret 23. november 2007 av Dev-
Empire of the Sub Skrevet 23. november 2007 Skrevet 23. november 2007 Icy Veins er latterlig,imo. Latterlig imba. Mage trenger ikke mer dmg og survivability, dem trenger enten en større manapool eller større mana regeneration.
bandreas Skrevet 23. november 2007 Skrevet 23. november 2007 Uff, frostmages blir ufattelig seige i pvp nå. Som om de ikke hadde bra nok surv fra før av -.-
Orcuz Skrevet 23. november 2007 Skrevet 23. november 2007 Hmm. Vurderte å rerolle tailoringa til spellfire og bli firemage her for noen dager siden jeg, men blir kanksje gøy å være frost mage igjen da =-)
